Home » Eclipse Projects » Eclipse Platform » Checked tool bar item appearance
Checked tool bar item appearance [message #327645] Mon, 28 April 2008 03:23 Go to next message
I have an IAction added in a tool bar. It has an icon and its text isn't
shown.
Programmatically I call the setChecked(), but its visual appearance
doesn't change. I expect to appear sunken or something similar.
I'll try to change the icon when checked.
Is this normal?
Any workaround?
Thanks for any help.
David
Re: Checked tool bar item appearance [message #327651 is a reply to message #327645] Mon, 28 April 2008 04:01 Go to previous messageGo to next message
I've studied a little the scroll lock action on the Console view as an
example.
I've observed this:
public class ScrollLockAction extends Action {
public ScrollLockAction(IConsoleView consoleView) {
super(ConsoleMessages.ScrollLockAction_0);
setToolTipText(ConsoleMessages.ScrollLockAction_1);
setHoverImageDescriptor(...);
setDisabledImageDescriptor(...);
setImageDescriptor(...);
boolean checked = fConsoleView.getScrollLock();
setChecked(checked);
It uses 3 different icons.
I've tried to set a different hover image, but it is used always instead
of the normal one.
> shown.
> Is this normal?
> Any workaround?
Re: Checked tool bar item appearance [message #327698 is a reply to message #327645] Tue, 29 April 2008 05:34 Go to previous message
Solved!
1) Use style IAction.AS_CHECK_BOX
2) In my code I did
void run() {
setChecked(!isChecked());
With the AS_CHECK_BOX style, I don't need to set the new check state.
> shown.
> Is this normal?
> Any workaround?
> David
Previous Topic:Eclipse 3.4 strange project naming upon import
Next Topic:Newbie help topic plugin question
Current Time: Thu Jul 17 06:48:48 EDT 2025
Powered by FUDForum. Page generated in 0.05150 seconds
