Home » Eclipse Projects » Eclipse Platform » How to set 2 identical plugins in one Eclipse Platform?
How to set 2 identical plugins in one Eclipse Platform? [message #327582] Fri, 25 April 2008 06:57 Go to next message
For example, there two plugins A, and B which are completely the same in
codes and paths except the differnt extension names in plugin.xml. It means
that two different plugins will be striggered by different extensions of
filenames.
Here is the problem. It seems that these two identical plugins confuses the
eclipse playform. In some cases, ocassionally, plugin A calls its method
FUN() but runs into FUN() in plugin B. I guess that there might be some
confusion of objects between plugin A and B since they all have the same
names and paths.
My idea is to review all pages in plugin.xml and set all related ID items to
different names, and reset the relationship of dependencies. Is there any
other things I should do to achieve this goal?
I guess the worst way to achieve this is to explicitly create different
signatures of objects by changing all the file names . It should be able to
avoid confusion of objects. But it is just to troublesome. My projects are
based on GEF framework. Please give any advices, very apprecitaed!
Brandon
Re: How to set 2 identical plugins in one Eclipse Platform? [message #327584 is a reply to message #327582] Fri, 25 April 2008 08:04 Go to previous message
Brandon,
As long as you ensure that you're using a unique plugin ID, you should
be able to support this. I assume there's no downstream plugin that
ends up importing both...
> filenames.
> names and paths.
> Cheers,
> Brandon
Previous Topic:[Databinding] Valuebinding: Model To Target Synchronisation
Next Topic:TabbedPropertySheetPage tab orientation
Current Time: Sat Nov 08 23:55:46 EST 2025
Powered by FUDForum. Page generated in 0.24014 seconds
