Home » Eclipse Projects » Eclipse Platform » compile error for source tar ball
compile error for source tar ball [message #327563] Thu, 24 April 2008 13:41
I've downloaded the
eclipse-sourceBuild-srcIncluded-I20080415-1646.zip. However when I run
the command:
build -os win32 arch x86, I get the following error
C:\dev\cvs2\ball\plugins\org.eclipse.pde.api.tools.ui\build. xml:492: The
followi
ng error occurred while executing this line:
C:\dev\cvs2\ball\plugins\org.eclipse.pde.api.tools.ui\build. xml:449:
Compile fai
led; see the compiler error output for details.
Tracing it to the log file, I see the following:
123. ERROR in
C:\dev\cvs2\ball\plugins\org.eclipse.pde.api.tools.ui\src\or g\eclipse\pde\api\tools\ui\internal\wizards\ApiProfileWizard Page.java
(at line 285)
return ((String)o1).compareTo(o2);
The method compareTo(String) in the type String is not applicable for
the arguments (Object)
Just in case someone wonders what I am doing. I have a new job as
release engineer. I am asked to write plugins to generates build script
for our department. I am trying to understand the workings of eclipses
before I start because it's a long-term commitment.
Previous Topic:fragments for platform specific code
Next Topic:org.eclipse.ui.handlers - enableWhen - selection count
Current Time: Thu Jul 24 01:14:18 EDT 2025
Powered by FUDForum. Page generated in 0.24640 seconds
