Home » Eclipse Projects » Eclipse Platform » Saving Template causes Eclipse to hang
Saving Template causes Eclipse to hang [message #327547] Thu, 24 April 2008 08:28 Go to next message
I am using Eclipse 3.3.1.1. I want to define a new code template so when
I'm
coding I can just use the Ctrl-space shortcut to insert some code.
I go into Preferences | Java | Editor | Templates and add a new template.
After typing in the code I want (I also insert the variable
"${enclosing_type}") and click OK, Eclipse hangs and I have to end the
task.
I've tried this many times with same result. Looks like a bug to me. How do
I report it? Is there a workaround? If I knew what file on the filesystem
was being updated I'd just go in there and put in the code but I don't know
where.
Any help would be appreciated.
Thanks!
PS-I wasn't sure if this was the right forum to post this on. If not,
please
let me know where I should post it.
Re: Saving Template causes Eclipse to hang [message #327553 is a reply to message #327547] Thu, 24 April 2008 09:37 Go to previous messageGo to next message
I just found that if I use Alt-Shift-Z to bring up the templates I can
create a new template and save it as expected.
So I have a workaround for my issue but I'd still like to report the "bug"
with the other way of trying to do it.
Thanks.
Re: Saving Template causes Eclipse to hang [message #327558 is a reply to message #327553] Thu, 24 April 2008 12:15 Go to previous messageGo to next message
> "bug" with the other way of trying to do it.
Please add your comments to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201098
Dani
> Thanks.
Re: Saving Template causes Eclipse to hang [message #327570 is a reply to message #327558] Thu, 24 April 2008 21:16 Go to previous message
Done!
Thanks.
Previous Topic:org.eclipse.ui.handlers - enableWhen - selection count
Next Topic:anonymous cvs checkout
Current Time: Thu Jul 17 20:42:13 EDT 2025
Powered by FUDForum. Page generated in 0.05204 seconds
