Saving Template causes Eclipse to hang [message #327547] |
Thu, 24 April 2008 08:28  |
I am using Eclipse 3.3.1.1. I want to define a new code template so when
I'm
coding I can just use the Ctrl-space shortcut to insert some code.
I go into Preferences | Java | Editor | Templates and add a new template.
After typing in the code I want (I also insert the variable
"${enclosing_type}") and click OK, Eclipse hangs and I have to end the
task.
I've tried this many times with same result. Looks like a bug to me. How do
I report it? Is there a workaround? If I knew what file on the filesystem
was being updated I'd just go in there and put in the code but I don't know
where.
Any help would be appreciated.
Thanks!
PS-I wasn't sure if this was the right forum to post this on. If not,
please
let me know where I should post it.
FUDForum. Page generated in 0.08406 seconds
