Home » Eclipse Projects » Eclipse Platform » Recover from update
Recover from update [message #327518] Wed, 23 April 2008 06:05 Go to next message
Originally posted by: Ben_Engbers.yahoo.com
After I finished an update on my Europa-installation (running on a
Linux/Fedora desktop), Eclipse said that it should be restarted.
(Re)starting however fails and the error.log looks like this:
!SESSION 2008-04-23 11:51:56.640
eclipse.buildId=M20071023-1652
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.equinox.app 2008-04-23 11:51:58.533
!MESSAGE Product org.eclipse.sdk.ide could not be found.
!ENTRY org.eclipse.osgi 4 0 2008-04-23 11:51:58.575
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:98)
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:112)
at org.osgi.util.tracker.ServiceTracker
$Tracked.trackAdding(ServiceTracker.java:1064)
$Tracked.trackInitialServices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:54)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl
$2.run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at org.eclipse.osgi.framework.eventmgr.EventManager
$EventThread.run(EventManager.java:297)
!ENTRY org.eclipse.osgi 2 0 2008-04-23 11:51:59.170
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-04-23 11:51:59.171
!MESSAGE Bundle
This followed by > 4200 lines telling me that eclipse is missing
required bundles.
How can I recover or go back to the previous state?
Ben Engbers
Re: Recover from update [message #327524 is a reply to message #327518] Wed, 23 April 2008 09:53 Go to previous message
Originally posted by: ekukac.hotmail.com
You can try to issue
eclipse -clean
command, maybe it will recover from the errors.
David
Previous Topic:[releng] Junit bundles with Gentoo
Next Topic:Eclipse classpath variables programmatically
Current Time: Mon Jul 21 22:22:10 EDT 2025
Powered by FUDForum. Page generated in 0.03528 seconds
