Home » Eclipse Projects » Eclipse Platform » eclipse cannot resolve domain names
eclipse cannot resolve domain names [message #327466] Mon, 21 April 2008 13:53 Go to next message
Very strange issue, Eclipse cannot resolve domain names. I'm on debian
linux, testing distro, 2.6.23-AMD64 kernel. I dont use any proxies, and
eclipse is setup to work without proxies. My /etc/resolv.conf is just:
nameserver 4.2.2.5
Evidence that DNS resolving does not work:
Help -> Software Update -> Find and Install cannot connect to anything, if
I hit finish to start updating a "problem occured, network connection
problems encountered during search" dialog with the following details:
"""Network connection problems encountered during search. Unable to
access " http://hudson-eclipse.googlecode.com/svn/trunk/hudson-update /".
Error parsing site stream. [Premature end of file.]
Premature end of file."""
CVS perspective is a little bit clearer, if I add a site using a hostname
it says:
"could not locate host"
However if I change it to an IP address it works fine.
Anyone have any suggestions for how to fix Eclipse to get DNS resolves
working again?
Re: eclipse cannot resolve domain names [message #327467 is a reply to message #327466] Mon, 21 April 2008 14:37 Go to previous messageGo to next message
Also, I'm using the 32 bit winter build against the 32bit
ia32-sun-java6-bin package. I just wiped my ~/.eclipse folder and
/usr/local/eclipse but am still experiencing this grievously annoying
issue (I cannot install remote plugins).
Re: eclipse cannot resolve domain names [message #327468 is a reply to message #327466] Mon, 21 April 2008 14:46 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
> nameserver 4.2.2.5
I'm guessing a properly-working DNS server is reacheable at 4.2.2.5 ?
Denis
> if I hit finish to start updating a "problem occured, network connection
> hostname it says:
> working again?
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: eclipse cannot resolve domain names [message #327470 is a reply to message #327468] Mon, 21 April 2008 15:03 Go to previous messageGo to next message
4.2.2.2 is a high performant public DNS server hosted by L3, it should
work for anyone. it works for all my other apps. :)
JDK is pooched [Was: eclipse cannot resolve domain names] [message #327471 is a reply to message #327466] Mon, 21 April 2008 15:52 Go to previous messageGo to next message
Error appears to lie in my JDK. Again for reference I am using the
ia32-java-6-sun package on Debian Testing. I have filed a bug report
against it at: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=477211
I used the following program to test whether the JDK can resolve domain
names:
// code modified from
// http://www.rgagnon.com/javadetails/java-0452.html
import java.net.InetAddress;
public class SimpleDNS {
public static void main( String args[] ) {
if( args.length == 0 ) {
System.err.println( "Usage: SimpleDNS host" );
System.exit( 99 );
for( int i = 0; i < args.length; i++ ) {
try {
System.out.println( args[i] + " is " +
doLookup( args[i] ));
catch( Exception e ) {
System.out.println(args[i] + " : " + e.getMessage());
e.printStackTrace();
static String doLookup( String hostName ) throws Exception {
InetAddress addr = InetAddress.getByName( hostName );
return addr.getHostAddress();
Excepted:
slashdot.org is 66.35.250.150 [ed: or permutation thereof]
Result:
slashdot.org : slashdot.org
java.net.UnknownHostException: slashdot.org
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$1.lookupAllHostAddr(InetAddress.java:84 9)
java.net.InetAddress.getAddressFromNameService(InetAddress.j ava:1200)
at java.net.InetAddress.getAllByName0(InetAddress.java:1153)
at java.net.InetAddress.getAllByName(InetAddress.java:1083)
at java.net.InetAddress.getAllByName(InetAddress.java:1019)
at java.net.InetAddress.getByName(InetAddress.java:969)
at SimpleDNS.doLookup(SimpleDNS.java:25)
at SimpleDNS.main(SimpleDNS.java:14)
Re: JDK is pooched [Was: eclipse cannot resolve domain names] [message #327475 is a reply to message #327471] Mon, 21 April 2008 17:17 Go to previous message
Originally posted by: wegener.cboenospam.com
"rektide" <rektide@gmail.com> wrote in message
news:06cada9a28126d134cd44b1eb2275d18$1@www.eclipse.org...
> names:
> System.exit( 99 );
> try {
> Excepted:
> Result:
> at
Have you tried to perform the lookup manually outside of a Java application?
What does "nslookup slashdot.org" give you back?
Previous Topic:XSL transform on eclipse platform
Next Topic:hyperlink detector in the text framework
Current Time: Sat Aug 30 23:29:07 EDT 2025
Powered by FUDForum. Page generated in 0.24775 seconds
