Home » Eclipse Projects » Eclipse Platform » Plugin doesn't get loaded after deployment
Plugin doesn't get loaded after deployment [message #327434] Sat, 19 April 2008 04:47 Go to next message
Originally posted by: kulkarni1.avaya.com
I am getting some weired problem and not able to find the solution.
I have developed a plugin and tested by "Run" and "Debug" mode.
Everything works perfect when I launch runtime Eclipse session.
But when I deploy the plugin to existing eclipse installation, then
it doesn't get loaded. The plugin is neither listed in Help->About Eclipse
SDK
nor I can see my functionality.
The way I deploy the plugin is: Select the plugin, with RMB, Export, then
"Deployable Plugins and Fragments", enter destination directory of my
eclipse
installation.
Interestingly, when I do the same steps for a sample "Hello World" plugin,
then also everything works fine.
Any suggestions would be greatly appreciated. Please help.
Santosh
Re: Plugin doesn't get loaded after deployment [message #327438 is a reply to message #327434] Sun, 20 April 2008 01:29 Go to previous message
I got the resolution of the problem. I was not taking care of dependencies.
No need to reply.
Santosh
Previous Topic:entering unicodes into text editors. How?
Next Topic:Issue with deletion of a file and refresh
Current Time: Fri Jul 25 23:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.04399 seconds
