Plugin doesn't get loaded after deployment [message #327434] |
Sat, 19 April 2008 04:47  |
Originally posted by: kulkarni1.avaya.com
I am getting some weired problem and not able to find the solution.
I have developed a plugin and tested by "Run" and "Debug" mode.
Everything works perfect when I launch runtime Eclipse session.
But when I deploy the plugin to existing eclipse installation, then
it doesn't get loaded. The plugin is neither listed in Help->About Eclipse
SDK
nor I can see my functionality.
The way I deploy the plugin is: Select the plugin, with RMB, Export, then
"Deployable Plugins and Fragments", enter destination directory of my
eclipse
installation.
Interestingly, when I do the same steps for a sample "Hello World" plugin,
then also everything works fine.
Any suggestions would be greatly appreciated. Please help.
Santosh
FUDForum. Page generated in 0.05644 seconds
