| How to use MessageConsole? [message #327433] |
Fri, 18 April 2008 15:45  |
Originally posted by: NOSPAM_achan.progress.com
I'm trying to use MessageConsole in my view to show some messages. The
rate of adding these messages can be high, but MessageConsole seems to
handle it very well in terms of CPU usage.
However, I'm trying to make sure the highWater Mark is working. So I set
called setWaterMark(300, 500) to make sure it is doing the right thing. I
then set a timer to write the current date to the output stream every 5
seconds.
What I noticed is that when it is time to re-adjust the offset, there are
always a duplicate of the 1st line in the 0th line position.
Looks like the stream position is confused. I printed out the text from
document and they are correct. Just the text on the console is messed up.
Here is the code (it won't compile as a stand alone app):
public class TestMessageConsole {
final Display display = new Display();
final Shell shell = new Shell(display);
MessageConsole msgConsole = new MessageConsole("Test", null, false);
TextConsoleViewer textConsoleViewer = new TextConsoleViewer(shell,
msgConsole);
MessageConsoleStream msgConsoleStream = msgConsole.newMessageStream();
final BufferedWriter bw = new BufferedWriter(new
OutputStreamWriter(msgConsoleStream));
msgConsole.setWaterMarks(300, 500);
display.timerExec(2000, new Runnable() {
public void run()
try {
bw.write((new Date()).toString() + "\n");
bw.flush();
} catch (Exception e) {
display.timerExec(2000, this);
shell.setSize(300, 300);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Are there any sample code for using MessageConsole? Thanks.
-Aston
| Re: How to use MessageConsole? [message #327451 is a reply to message #327450] |
Mon, 21 April 2008 00:25  |
I may have found a solution. Instead of using watermarks, I enforce the
max # of lines myself:
doc.addDocumentPartitioningListener(new IDocumentPartitioningListener() {
public void documentPartitioningChanged(IDocument document)
int numOfLines = document.getNumberOfLines();
if (numOfLines > maxLine) {
int extra = numOfLines - maxLine;
IRegion region;
try {
region = document.getLineInformation(extra);
document.replace(0, region.getOffset(), ""); // replace
1st n lines with ""
document.set(document.get()); // this will move the
current pos to the end so next append will work...
} catch (BadLocationException e) {
e.printStackTrace();
Leave the watermark alone ( or probably set to -1 ).
-Aston
FUDForum. Page generated in 0.04168 seconds
