Home » Eclipse Projects » Eclipse Platform » File search & replace programatically?
File search & replace programatically? [message #327404] Thu, 17 April 2008 12:48 Go to next message
Is there any simple API for doing a search & replace within a single
file? I'm looking at the IFile interface and it looks like I could use
some combination of getContents() and setContents() but there would
still be a lot of coding to bridge the gap.
Is there a cleaner/simpler way?
Thanks in advance,
Eric
Re: File search & replace programatically? [message #327417 is a reply to message #327404] Fri, 18 April 2008 03:14 Go to previous message
Use file buffers to get the document (this handles all the encoding woos
for you) and then use org.eclipse.jface.text.FindReplaceDocumentAdapter
which also supports regex.
Dani
> Thanks in advance,
> Eric
Previous Topic:Re: Can I customize when the plug-in be loaded?
Next Topic:Getting the default modifier key for hyperlinks from the preference store
Current Time: Tue Oct 21 18:29:25 EDT 2025
Powered by FUDForum. Page generated in 0.04837 seconds
