| Invalid thread access [message #33141] |
Wed, 25 April 2007 02:34  |
Originally posted by: swetha.yahoo.co.in
I am developing a Gallery View using nebula gallery widget,
the createPartControl method is,
public void createPartControl(Composite parent)
gallery = new Gallery(parent, SWT.V_SCROLL);
noGroupRenderer = new NoGroupRenderer();
defaultGalleryItemRenderer = new DefaultGalleryItemRenderer();
(some other code)---------
the error is coming at the line
in DefaultGalleryItemRenderer class the error is at the line,
foregroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_FOREGROUN D);
public DefaultGalleryItemRenderer() {
foregroundColor =
backgroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_BACKGROUN D);
selectionForegroundColor = foregroundColor;
selectionBackgroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_SELECTION );
// Create drop shadows
createColors();
The error is,
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Display.error(Display.java:978)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:638 )
at org.eclipse.swt.widgets.Display.getSystemColor(Display.java: 1931)
org.eclipse.nebula.widgets.gallery.DefaultGalleryItemRendere r. <init>(DefaultGalleryItemRenderer.java:63)
com.sequenom.everest.ui.project.GalleryView.createPartContro l(GalleryView.java:335)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:3915)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2929)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2857)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1665)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigur
Please help me in this,
Thanks in advance,
Swetha
| Re: Invalid thread access [message #33176 is a reply to message #33141] |
Wed, 25 April 2007 03:40   |
Well the root cause see seems to be that your createPartControl isn't
executed in the GUI-Thread or better said something is calling
createPartControl() in another thread than the GUI is running in. Could
you try simply calling:
public void createPartControl(Composite parent) {
If this also produces an exception please log a bug against platform-ui.
The nebula-code is not the culprit here I think although I have only
looked at the parts you presented here.
Tom
Swetha schrieb:
> the error is coming at the line defaultGalleryItemRenderer = new
> foregroundColor =
> foregroundColor =
> backgroundColor =
> createColors();
> The error is,
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Swetha
| Re: Invalid thread access [message #33346 is a reply to message #33311] |
Wed, 25 April 2007 06:55  |
It seems the eclipse is starting a thread when starting up (because of
what ever reason but they forgot to sync the calls with to create part).
Please log a bug against Platform-UI attaching your stacktrace.
Tom
Swetha schrieb:
> This error is gone.. donno the reason.. I just copied my project in new
> workspace and I opened that workspace and run .. working as usual...
> In fact my friend also faced the same problem once.. he told to do like
> this.. and this is working.. what could be the reason..
> Swetha
| Re: Invalid thread access [message #581120 is a reply to message #33141] |
Tom
Swetha schrieb:
> foregroundColor =
> foregroundColor =
> backgroundColor =
> createColors();
> The error is,
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Swetha
| Re: Invalid thread access [message #581160 is a reply to message #33211] |
Wed, 25 April 2007 05:46  |
It's true that the createPart code should be run for the swt thread. I
think you should check your code that is calling this view, because the
problem should be fixed there.
But if you want fix it here, try something like this :
Display.getDefault().syncExec( new Runnable() {
void run( ) {
Nicolas
Swetha a écrit :
> That didn't work.. Before it used to run perfectly.. Suddenly the
> error is coming..
> Swetha
| Re: Invalid thread access [message #581179 is a reply to message #33211] |
Wed, 25 April 2007 05:52  |
I consider this a bug in the Eclipse-Platform and file a bug against it.
It's really a major bug if eclipse is calling createPartControl() out of
the GUI-Thread and many other plugins will fail miserably. So please log
a bug against platform-ui and provide a step to step instruction how to
make this happen!
The work-around from Nicolas will put you on the safe side but please
once more LOG A BUG!
Did you see this behaviour with 3.3M6 or one of the latest I-builds?
Tom
Swetha schrieb:
> error is coming..
> Swetha
| Re: Invalid thread access [message #581205 is a reply to message #33276] |
Wed, 25 April 2007 06:49  |
Swetha
| Re: Invalid thread access [message #581219 is a reply to message #33311] |
Tom
Swetha schrieb:
> Swetha
FUDForum. Page generated in 0.05592 seconds
