Home » Eclipse Projects » Eclipse Platform » Eclipse Tabs
Eclipse Tabs [message #327195] Mon, 14 April 2008 01:07 Go to next message
Originally posted by: anupgokhale.rediffmail.com
Hi all.
Within eclipse itself, all the views and editors are displayed in tabs
that appear as curved. But in the RCP application that I create, the
views/editors appear in normal rectangular tabs. How do I use the curved
tabs in my RCP app?
Anup
Re: Eclipse Tabs [message #327211 is a reply to message #327195] Mon, 14 April 2008 05:00 Go to previous messageGo to next message
Hi!
I have not tried myself yet, but you can have curved tabs by simply
calling "setSimple(false)" on the "TabFolder" object. Also try
"setBorderVisible(false)".
Matthias
PS: Also check this document:
http://www.ibm.com/developerworks/edu/os-dw-os-eclipse-rcp1. html?S_TACT=105AGX44&S_CMP=EDU
Re: Eclipse Tabs [message #327213 is a reply to message #327211] Mon, 14 April 2008 06:20 Go to previous messageGo to next message
The technique you mention below can very well be used to customize the
appearance of a tabfolder/CTabFoler that has been placed inside a view
or editor. What I am looking for is the curvy tabs Eclipse displays for
each editor and view.
> Hi!
> Best regards,
> Matthias
My hunch is that I will be able to achieve this by using the setProperty
of IFolderLayout in Perspective.java's createInitialLayout method. But I
am not able to get it work as I have no idea regarding teh property ID
and value to set.
Anup
Re: Eclipse Tabs [message #327217 is a reply to message #327213] Mon, 14 April 2008 06:53 Go to previous messageGo to next message
Hi!
That one is easy!
In your custom WorkbenchAdvisor class override the "initialize" method!
Code snippet:
public void initialize(IWorkbenchConfigurer configurer) {
super.initialize(configurer);
PlatformUI.getPreferenceStore().setValue(
IWorkbenchPreferenceConstants.SHOW_TRADITIONAL_STYLE_TABS, false);
For me it worked this way!
Matthias
Re: Eclipse Tabs [message #327219 is a reply to message #327217] Mon, 14 April 2008 07:18 Go to previous message
Matthias wrote:
> Hi!
> That one is easy! In your custom WorkbenchAdvisor class override the
> Code snippet:
> @Override
> Best regards,
> Matthias
Exactly what I was looking for. Thanks a lot.
Anup
Previous Topic:A slight problem in Tree Viewer
Next Topic:TreeViewer and VIRTUAL style
Current Time: Wed Oct 29 02:24:32 EDT 2025
Powered by FUDForum. Page generated in 0.26525 seconds
