Home » Eclipse Projects » Eclipse Platform » Reusing Handler in plugin
Reusing Handler in plugin [message #327170] Sat, 12 April 2008 12:30 Go to next message
Originally posted by: tom.eiswind.de
HI Paul tried to answer this already, but I dont get it.
I have a generic extensible Handler in my core plugin.
I want it to be active for a certain view part in core.
<handler
class="de.eiswind.paris.client.core.ui.EditHandler"
commandId="de.eiswind.mango.client.core.command.edit">
<activeWhen>
<with
variable="activePartId">
<equals
value="de.eiswind.paris.client.core.ui.lastused.LastUsedView ">
</equals>
</with>
</activeWhen>
<enabledWhen>
<with variable="selection">
<count value="1" />
</with>
</enabledWhen>
Plugin no. two contributes a new view, for which I want that hanlder to
be active too. If I redeclare it in plugin.xml only ony of them works.
<handler
<activeWhen>
<with
<equals
value="de.eiswind.mango.client.search.ui.Search">
</equals>
</with>
</activeWhen>
<enabledWhen>
<count value="1" />
</with>
</enabledWhen>
</handler>
How can I extend the activeWhen clause of the handler ?
Re: Reusing Handler in plugin [message #327181 is a reply to message #327170] Sun, 13 April 2008 10:07 Go to previous messageGo to next message
Thomas wrote:
> <handler
> <activeWhen>
> <with
> <equals
> </equals>
> </with>
> </activeWhen>
> <enabledWhen>
> <count value="1" />
> </with>
> </enabledWhen>
Although they'll be 2 separate instances of the EditHandler, your
activeWhen clause looks correct (i.e. one will be active when
LastUsedView is active, and the other instance will be active when
Search is active).
What part is not working? Nothing is executing your handlers at all?
To find out what is going on, you can have a look at:
http://wiki.eclipse.org/Platform_Command_Framework#Tracing_O ption
You care about sources and handlers from the debugging options listed.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Reusing Handler in plugin [message #327270 is a reply to message #327181] Tue, 15 April 2008 02:35 Go to previous messageGo to next message
Hi Paul,
only the LastUsedView works, the other says
HANDLERS >>> resolveConflicts: eval:
HandlerActivation(commandId=de.eiswind.mango.client.core.com mand.edit,
handler=de.eiswind.paris.client.core.ui.EditHandler,
expression=org.eclipse.core.internal.expressions.WithExpression@8e59bed8,sourcePriority=4194304)
HANDLERS >>> Resolved conflict detected. The following activation won:
HANDLERS >>>
HANDLERS >>> Command('de.eiswind.mango.client.core.command.edit') has
changed to 'de.eiswind.paris.client.core.ui.EditHandler' as its handler
Paul Webster schrieb:
> Thomas wrote:
>> <handler
>> <activeWhen>
>> <with
>> <equals
>> </equals>
>> </with>
>> </activeWhen>
>> <enabledWhen>
>> <count value="1" />
>> </with>
>> </enabledWhen>
>> to be active too. If I redeclare it in plugin.xml only ony of them works.
> Search is active).
> PW
Re: Reusing Handler in plugin [message #327323 is a reply to message #327270] Tue, 15 April 2008 10:46 Go to previous message
Thomas wrote:
> Hi Paul,
> HANDLERS >>>
Unfortunately, that doesn't tell us anything since it appears to be a
conflict of "1" (which shouldn't happen, but OK).
What is the trace from the SOURCE >>> where the activePartId changes to
your search view?
PW
Paul Webster
Previous Topic:[Databinding] EMF Observables / Commands
Next Topic:building the eclipse.exe from cvs
Current Time: Mon Sep 01 02:42:59 EDT 2025
Powered by FUDForum. Page generated in 0.06906 seconds
