Home » Eclipse Projects » Eclipse Platform » Suggestions on design using Extension and Extension points.
Suggestions on design using Extension and Extension points. [message #327165] Fri, 11 April 2008 23:12
Originally posted by: kathir.atc.tcs.com
My earlier post went in a wrong place..so posting it again. sorry.
Is it a good idea to implement Business Logics using extension points ,
extensions concept?
I am planning to develop a simple application platform to which
different applications will be plugged in. All the applications will have
the same perspectives and views but the business logic changes.
So i was thinking of creating a platform with all the perspectives and
views and give extension points to include the logic. Is this a good idea?
So when the application type changes, the perspective should behave as
per its logic defined through the extension point.
Is there any other better approach? Any help would be appreciated.
BR,
Kathir.
Previous Topic:The JAR of this class file belongs to a container "Plugin Depenedencies" which does not al
Next Topic:Teneo installation corrupts basic Ant installation
Current Time: Thu Nov 06 17:08:59 EST 2025
Powered by FUDForum. Page generated in 0.05165 seconds
