Home » Eclipse Projects » Eclipse Platform » View loading dependency
View loading dependency [message #327130] Fri, 11 April 2008 05:07 Go to next message
Originally posted by: gemaspecial.yahoo.com.hk
Problem: Cannot find base viewId when initializing view positions
Situation:
Two plugins, say A and B and their dependency is:
A -> (depends on) B
Each plugin gets a view, say ViewA and ViewB
I want to put ViewA on top of ViewB by default.
================code================================
ViewA position in plugin.xml
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension targetID="org.mywork.perspective">
<view
id="org.mywork.ui.views.ViewA"
ratio="0.5"
relationship="bottom"
relative="org.mywork.ui.views.ViewB"/>
</perspectiveExtension>
ViewB position in plugin.xml
<extension
<view
id="org.mywork.ui.views.ViewB"
ratio="1.0"
relationship="top"
relative="org.eclipse.ui.editorss"/>
</extension>
Re: View loading dependency [message #327131 is a reply to message #327130] Fri, 11 April 2008 05:11 Go to previous messageGo to next message
Sorry, forget to post the problem
Here is the .log
======================.log===========================
!ENTRY org.eclipse.ui 4 4 2008-04-11 16:56:55.578
!MESSAGE Referenced part does not exist yet: org.mywork.ui.views.ViewB.
I suppose eclipse loads ViewA BEFORE ViewB, just opposite to the
specified dependency.
I am sure the line "Require-Bundle: org.mywork.pluginB" is present in
pluginA's plugin.xml
Do I missing something?
> Situation:
> A -> (depends on) B
> Thanks
> <extension
> <view
> ratio="0.5"
> <extension
> <view
> ratio="1.0"
> relationship="top"
> </extension>
Re: View loading dependency [message #327156 is a reply to message #327130] Fri, 11 April 2008 14:06 Go to previous message
> Situation:
They're both coming in as perspectiveExtensions, and there can be no
dependencies between perspectiveExtensions. A pE can only depend on a
perspective.
More specifically, the perspectiveExtensions are read in plugin-id
order, although that's an implementation detail, I don't think it is
spec'ed that way. So B will be processed after A.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:How to define Eclipse editor size
Next Topic:Modifying resources from outside the workbench
Current Time: Wed Nov 05 07:47:55 EST 2025
Powered by FUDForum. Page generated in 0.05302 seconds
