Home » Eclipse Projects » Eclipse Platform » plugin, ITokenScanner, nextToken --> SWT BUG
plugin, ITokenScanner, nextToken --> SWT BUG [message #327081] Wed, 09 April 2008 01:13
hi all, I try to make a plugin who can colorize some line like
FROM lkfsjdl IMPORT lskdfjl;
Based on my own grammar created with ANTLR 3.0.
for that, I overrided ITokenScanner.
public IToken nextToken() {
antCurrentToken = lexer.nextToken();
if (antCurrentToken.getType() == org.antlr.runtime.Token.EOF)
return Token.EOF;
switch (antCurrentToken.getType()) {
case LyaflplugLexer.TAG_END:
case LyaflplugLexer.TAG_DEFINITION_MODULE:
case LyaflplugLexer.TAG_FROM:
case LyaflplugLexer.TAG_IMPORT:
return keyword;
default:
return ident;
The problem is : if the file is empty then I can create twho line
he color eatch word etc... everything is perfect but if I save and I
reopen the file he bug cause theres are two line who are the same. (if
there is only one, no prob).
I ve tried to debug and he call every token. but after that there is a
exception error Argument No valid.
is any body has a idea: I there is the class code
http://paste.ubuntu-nl.org/62601/
thanks
a++
PS: this message is sended on antlr-interest and eclipse.platform
PPS: there is the stack.
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:3547)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.swt.custom.StyledText.setStyleRanges(StyledText. java:7776)
at org.eclipse.swt.custom.StyledText.setStyleRanges(StyledText. java:7870)
org.eclipse.jface.text.TextViewer.applyTextPresentation(Text Viewer.java:4429)
org.eclipse.jface.text.TextViewer.changeTextPresentation(Tex tViewer.java:4481)
org.eclipse.jface.text.presentation.PresentationReconciler.a pplyTextRegionCollection(PresentationReconciler.java:580)
org.eclipse.jface.text.presentation.PresentationReconciler.p rocessDamage(PresentationReconciler.java:569)
org.eclipse.jface.text.presentation.PresentationReconciler.a ccess$3(PresentationReconciler.java:565)
org.eclipse.jface.text.presentation.PresentationReconciler$I nternalListener.inputDocumentChanged(PresentationReconciler. java:119)
org.eclipse.jface.text.TextViewer.fireInputDocumentChanged(T extViewer.java:2685)
at org.eclipse.jface.text.TextViewer.setDocument(TextViewer.jav a:2734)
org.eclipse.jface.text.source.SourceViewer.setDocument(Sourc eViewer.java:518)
org.eclipse.jface.text.source.SourceViewer.setDocument(Sourc eViewer.java:473)
org.eclipse.ui.texteditor.AbstractTextEditor.initializeSourc eViewer(AbstractTextEditor.java:3786)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3332)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:378)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:286)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:139)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:316)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:613)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Previous Topic:Conditional Enablement for Handlers on a Workbench Part
Next Topic:Open Resource filePath in a Cheat Sheet
Current Time: Fri Nov 07 02:44:01 EST 2025
Powered by FUDForum. Page generated in 0.03220 seconds
