Home » Eclipse Projects » Eclipse Platform » Any thoughts to having Condtion Objects.
Any thoughts to having Condtion Objects. [message #327080] Tue, 08 April 2008 21:40 Go to next message
I have worked with Eclipse ActionSets and now 3.3 Menus, Commands, Handlers.
While I believe that the new 3.3 handlers are much more powerful and
flexible than Actions whe have previously.
However, I still think a more powerful mechanism whould be able to declare
and implement "Condition objects" which simply evaluate true/false. These
condition objects would be tied to classes for implementation and could be
listening to any change in application domain state then change there
true/false state.
Menu Contributions Enablement, Check, or even visiblity could be then tied
to previously defined condition objects, by id.
There could be OOTB define conditions for performing anding/or'ing/not of
conditions so people could construct arbitarily large networks of conditions
to be evaluated.
This would separate the commands handler which performs the commands action
from also have to decide UI considerations like check/uncheck or isEnabled.
Also more of this behavior could be more declarative in the plugin.xml
Re: Any thoughts to having Condtion Objects. [message #327086 is a reply to message #327080] Wed, 09 April 2008 06:50 Go to previous messageGo to next message
On Tue, 8 Apr 2008 21:40:04 -0400, "Stuart Pond" <Stuart.Pond@ugs.com>
>true/false state.
>to be evaluated.
If I understand your request correctly you can do all of this using
Activities (at least as of 3.4M6) and the Expression framework. The
Activities have been expanded to support more than just Commands. For
some examples have a look at
http://www.bredex.de/en/rcp-auth/paper.html
The 3rd example (Authorization using Activity) and the paper may be
helpful.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/career/eclipse.html
Re: Any thoughts to having Condtion Objects. [message #327094 is a reply to message #327086] Wed, 09 April 2008 09:33 Go to previous messageGo to next message
I read the examples you referenced while somewhat similar it is not quite
what I was thinking.
Condition objects would be more like context objects which are either active
or not. But Conditions typically monitor a very particular part of
application state and translate it to a binary condition on/off. It also
fires notification when its state changes. In this way it is more like a
Finite State Machine. By combining conditions in a declarative fashion you
can come up with very sophisticated and semantically powerful machines that
fundamentally resolve to either true/false. Though they need not be complex
at all either and can be just a single simple condition too.
These results can be then tied (declaratively) to the UI presentation like
Menu/Toolbar contributions which have up to three binary dimensions:
Enablement (Gray/UnGray), Toggle Status (Check/UnCheck), and Visibility.
These conditions could be useful in other parts of the application too. A
condition service could keep a registry of registered conditions and other
parts of code register themselves as listeners to particular conditions and
could then be triggered on state changed of these conditions.
"Achim L
Re: Any thoughts to having Condtion Objects. [message #327098 is a reply to message #327094] Wed, 09 April 2008 10:38 Go to previous messageGo to next message
On Wed, 9 Apr 2008 09:33:03 -0400, "Stuart Pond" <Stuart.Pond@ugs.com>
The Expression framework does allow you to bind (registered) variables
to Activities. You may change this variables in your program code and
notify interested parties. It's not done by introducing Condition
objects, but the result looks the same to me.
This code is available in the platform (at least for Commands, for
other things like Views, Perspectives etc. with 3.4). You may open an
enhancement request against RCP in Bugzilla, but since I know much
work was done by the committers on the Activities solution I doubt
that they will add a very similar construct.
Achim
Achim Lörke
Re: Any thoughts to having Condtion Objects. [message #327105 is a reply to message #327080] Wed, 09 April 2008 15:22 Go to previous message
It's an interesting thought ... it would lean much more towards
event-driven over request-driven UI state. For example, how important
is it to enable/disable a menu item until that menu is about to be shown
(not very). Tool items are different, of course.
There are tools to implement some of your condition objects in the core
expressions+IEvaluationService.
The IEvaluationService allows you to register an
org.eclipse.jface.util.IPropertyChangeListener against a core
expression. That expression cares about variables (from event driven
source providers) and property testers (implementations that take the
object in scope + some args and return true or false). The
IEvaluationService allows you to monitor events outside the source
provider variables and request that a property (a la property tester) be
re-evaluated.
Any change from between TRUE and FALSE will notify your property change
listener.
A scaled back, internal version of the IEvaluationService is what drives
declarative handler enablement and menu visibility in 3.3. In 3.4 it is
public API, and drives handler activation and optionally activity
enablement as well.
Once you have something that will fire events when its TRUE/FALSE value
changes, then you need to wire it up (it's already wired up to
declarative handler enablement and menu contribution visibility).
There are other ways to implement it as well, of course,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Context Sensitive help on linux
Next Topic:Overriding an action created in createdActions() from the AbstractTextEditor class.
Current Time: Thu Nov 20 22:35:59 EST 2025
Powered by FUDForum. Page generated in 0.03751 seconds
