| Eclipse Events [message #33120] |
Sat, 15 November 2008 13:51  |
Hello all,
I would like to create a plug-in that captures events within the Eclipse
IDE. For example, if a user opens a file, types text, or uses the
debugger. I am actually to capture the opening a file, and typing text
event. I can also capture the debugging event.
I would like to know if anyone has ever tried to do this? Also, is there a
way to capture all events?
Thanks in advance,
Jason
| Re: Eclipse Events [message #33415 is a reply to message #33120] |
Mon, 17 November 2008 09:43   |
On 11/15/2008 1:51 PM, Jason Carter wrote:
> Hello all,
> a way to capture all events?
There is really no definition of "all events" - it is too broad a term.
As you've seen, there are various mechanisms and API to receive
different kinds of events.
You might want to look at the Usage Data Collector (UDC):
http://dev.eclipse.org/blogs/mike/2008/06/05/collecting-usag e-data/
Hope this helps,
Eric
| Re: Eclipse Events [message #34144 is a reply to message #33415] |
Sat, 22 November 2008 00:15  |
Thanks Eric.
I am interested in getting the text that a user has typed. I am able to
get this text and store it in a XML file.
I would like to programmatically insert this text into an editor. I am
able to get the current active editor, but when I insert text using the
document.replace(offset,0,text) function I get a BadLocationException
exception. I noticed that this exception only occurs when the text file is
empty or when there is no text at the offset to replace.
Any help is greatly appreciated
Jason
| Re: Eclipse Events [message #585396 is a reply to message #33120] |
> Hello all,
Hope this helps,
Eric
| Re: Eclipse Events [message #585686 is a reply to message #33415] |
Sat, 22 November 2008 00:11  |
Thanks so much for you reply Eric.
I am interested in getting the text the user is typing in an editor. I
have actually be able to get the text and store it in a log. What I would
like to do next is to take that text and programmatically enter it into an
editor.
This is the code I use to insert the text from the file. I use the
document.replace function.
while(e.hasMoreElements())
entry = e.nextElement();
int offset = Integer.parseInt(entry.getOffset());
int length = Integer.parseInt(entry.getLength());
String text = entry.getText();
try
document.replace(1,0,"some text");
catch(BadLocationException ex)
ex.printStackTrace();
The problem is every time I insert text I get a BadLocationException. I
noticed that this exception only occurs when the text file is empty or
Any help would be greatly appeciated.
Jason
| Re: Eclipse Events [message #585694 is a reply to message #33415] |
Thanks Eric.
Jason
FUDForum. Page generated in 0.04041 seconds
