Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse Events
Eclipse Events [message #33120] Sat, 15 November 2008 13:51 Go to next message
Hello all,
I would like to create a plug-in that captures events within the Eclipse
IDE. For example, if a user opens a file, types text, or uses the
debugger. I am actually to capture the opening a file, and typing text
event. I can also capture the debugging event.
I would like to know if anyone has ever tried to do this? Also, is there a
way to capture all events?
Thanks in advance,
Jason
Re: Eclipse Events [message #33415 is a reply to message #33120] Mon, 17 November 2008 09:43 Go to previous messageGo to next message
On 11/15/2008 1:51 PM, Jason Carter wrote:
> Hello all,
> a way to capture all events?
There is really no definition of "all events" - it is too broad a term.
As you've seen, there are various mechanisms and API to receive
different kinds of events.
You might want to look at the Usage Data Collector (UDC):
http://dev.eclipse.org/blogs/mike/2008/06/05/collecting-usag e-data/
Hope this helps,
Eric
Re: Eclipse Events [message #34110 is a reply to message #33415] Sat, 22 November 2008 00:11 Go to previous messageGo to next message
Thanks so much for you reply Eric.
I am interested in getting the text the user is typing in an editor. I
have actually be able to get the text and store it in a log. What I would
like to do next is to take that text and programmatically enter it into an
editor.
This is the code I use to insert the text from the file. I use the
document.replace function.
while(e.hasMoreElements())
entry = e.nextElement();
int offset = Integer.parseInt(entry.getOffset());
int length = Integer.parseInt(entry.getLength());
String text = entry.getText();
try
document.replace(1,0,"some text");
catch(BadLocationException ex)
ex.printStackTrace();
The problem is every time I insert text I get a BadLocationException. I
noticed that this exception only occurs when the text file is empty or
when there is no text at the offset to replace.
Any help would be greatly appeciated.
Jason
Re: Eclipse Events [message #34144 is a reply to message #33415] Sat, 22 November 2008 00:15 Go to previous message
Thanks Eric.
I am interested in getting the text that a user has typed. I am able to
get this text and store it in a XML file.
I would like to programmatically insert this text into an editor. I am
able to get the current active editor, but when I insert text using the
document.replace(offset,0,text) function I get a BadLocationException
exception. I noticed that this exception only occurs when the text file is
empty or when there is no text at the offset to replace.
Any help is greatly appreciated
Jason
Re: Eclipse Events [message #585396 is a reply to message #33120] Mon, 17 November 2008 09:43 Go to previous message
> Hello all,
Hope this helps,
Eric
Re: Eclipse Events [message #585686 is a reply to message #33415] Sat, 22 November 2008 00:11 Go to previous message
editor.
try
Jason
Re: Eclipse Events [message #585694 is a reply to message #33415] Sat, 22 November 2008 00:15 Go to previous message
Thanks Eric.
Jason
Previous Topic:PluginRegistry.getExternalModels ???
Next Topic:Custom icons for workbench content
Current Time: Sun Nov 23 04:35:09 EST 2025
Powered by FUDForum. Page generated in 1.07580 seconds
