Home » Eclipse Projects » Eclipse Platform » Try to understand SWT philosophy for extensibility.
Try to understand SWT philosophy for extensibility. [message #327064] Tue, 08 April 2008 05:55 Go to next message
I'm quite new in the SWT/RCP world.
Sometimes the builtin classes don't fully meet my needs. One way of
solving this kind of problems is inheritance.
Example 1:
Instead of this:
TableColumn column = new TableColumn(table, SWT.LEFT);
column.setText("Cabecera");
column.setWidth(150);
I like to write this (more compact):
new TableColumn(table, SWT.LEFT).sText("Cabecera").sWidth(150);
public class TableColumn extends org.eclipse.swt.widgets.TableColumn {
protected int index;
public TableColumn(Table parent, int style) {
super(parent, style);
index = parent.getColumnCount()-1;
public TableColumn sText(String string) {
super.setText(string);
return this;
public TableColumn sWidth(int width) {
super.setWidth(width);
return this;
protected void checkSubclass () {
The documentation says TableColumn cannot be derived.
So, I had to also override 'checkSubclass()'.
Example 2:
SWT Table only supports ordering by one column. I want to implement
multicolumn sorting.
Problem: TableColumn#setSortDirection() isn't public. It could be
protected.
Solution (None of them I like):
1- Changing source code of my private copy of SWT
2- Using AspectJ or similar
3- Use reflection to invoke non-public methods.
It's a little hard to work with a framework not designed for extensibility.
I know it's a project used by many other ones, and the public API must be
very well delimited.
Any ideas?
Re: Try to understand SWT philosophy for extensibility. [message #327065 is a reply to message #327064] Tue, 08 April 2008 06:29 Go to previous messageGo to next message
I forgot to mention that example 1 is perfectly working, even though
inheritance is forbidden.
David Perez wrote:
> Example 1:
> Instead of this:
> return this;
> return this;
Re: Try to understand SWT philosophy for extensibility. [message #327066 is a reply to message #327065] Tue, 08 April 2008 06:41 Go to previous messageGo to next message
Well instead of subclassing you could use a Builder-Pattern:
Builder.buildTableColumn(table,SWT.LEFT).setText("Cabecera").setWidth(150);
public class Builder {
public buildTableColumnn(Table table, int style) {
return new TableColumnBuilder(new TableColumn(table,SWT.LEFT));
public class TableColumnBuilder {
private TableColumn column;
public TableColumnBuilder(TableColumn column) {
this.column = column;
public TableColumnBuilder setText(String text) {
this.column.setText(text);
return this;
public TableColumnBuilder setWidth(int width) {
this.column.setWidth(width);
return this;
You already mentionned the reason SWT says you should not subclass it
because keeping an API contract up with subclassing is even harder than
without.
Tom
> David Perez wrote:
>> Example 1:
>> Instead of this:
>> return this;
>> return this;
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Try to understand SWT philosophy for extensibility. [message #327067 is a reply to message #327066] Tue, 08 April 2008 07:38 Go to previous message
Thanks Tom for your explanation.
Example 1 is a bad example, but shows that subclassing isn't such a bad
practice.
Luckily, the classes aren't declared final, so subclassing is possible
without patching SWT.
> return this;
> return this;
> without.
Previous Topic:How to embed the tabbed property view into a dialog?
Next Topic:how eclipse.exe call startup.jar
Current Time: Mon Oct 27 17:18:37 EDT 2025
Powered by FUDForum. Page generated in 0.04239 seconds
