| Switch off remembering last opened editor [message #326964] |
Thu, 03 April 2008 13:42  |
I have a problem with the opening of editors. I have two editors. One just
on just an object while the other is basically an editor which shows the
differences between two selected objects.
The problem I have is when I select two objects and open it with the
Diffing editor, The diffing editor is associated with that object. The
next time I double click on a single object, It tries to open the diffing
editor since the last open the diffing editor. I will have to again open
the actual editor using "open with" context menu. But, I want the basic
editor to open every time I double click and the diffing editor should
open only when I seect two objects and use "Open with" context menu.
Can someone let me know if I can switch off Eclipse's feature of
remembering the lsat opened editor on the object.I guess this could solve
my problem.
Thanks in advance,
Wishwas.
| Re: Switch off remembering last opened editor [message #327018 is a reply to message #326984] |
Fri, 04 April 2008 14:27  |
Voted for. Let us wait and see.
Eric Rizzo wrote:
> Wishwas wrote:
>> Hello,
>> just on just an object while the other is basically an editor which
>> shows the differences between two selected objects.
>> diffing editor since the last open the diffing editor. I will have to
>> again open the actual editor using "open with" context menu. But, I want
>> the basic editor to open every time I double click and the diffing
>> editor should open only when I seect two objects and use "Open with"
>> context menu.
>> solve my problem.
> No, there is no way to do it right now. I requested such a feature
> almost a year ago, but it has received no attention:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=184747
> Perhaps if you add your own comments and/or vote for that bug, it might
> get fixed in 3.4.x or 3.5...
> Eric
FUDForum. Page generated in 0.06528 seconds
