Home » Eclipse Projects » Eclipse Platform » using keybindings, menus, and context in a fragment
| using keybindings, menus, and context in a fragment [message #326960] |
Thu, 03 April 2008 13:08  |
I have a fragment, which defines a context, menu, commands, handlers and
keybindings. This works when I run the project through eclipse to debug,
but when I do a build and run the program, I no longer see my toolbar and
menu. I get a NotDefinedException for the context. Can I define the menus
in the fragment? The fragment is to contribute a page and menus to several
of our editors. In the page, I have the code:
IContextService contextService = (IContextService)
getSite().getService(IContextService.class);
contextService.activateContext("com.mycompany.context");
And have that context defined in fragment.xml for my fragment. Is there
anything I need to do to set any dependencies?
| Re: using keybindings, menus, and context in a fragment [message #326966 is a reply to message #326960] |
Thu, 03 April 2008 14:10   |
When a fragment is available, its classpath and XML appear just as if
they were in the host plugin. Start your deployed app with -console and
do an 'ss'
What is the state of your plugin? What is the state of your fragment?
BTW: it doesn't really make sense to reference something concrete like a
context or command from a plugin that's defined in a fragment ... since
if the fragment is not there, you'll get killed.
Although it is acceptable to check a command or context to see if
they're defined first.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
| Re: using keybindings, menus, and context in a fragment [message #326970 is a reply to message #326966] |
Thu, 03 April 2008 14:32   |
what do you mean by state?
The page that holds that context code is all in the fragment.
Sorry I'm a newbie.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:ft368k$dad$1@build.eclipse.org...
>> menus in the fragment? The fragment is to contribute a page and menus to
>> several of our editors. In the page, I have the code:
> When a fragment is available, its classpath and XML appear just as if they
> were in the host plugin. Start your deployed app with -console and do an
> 'ss'
> context or command from a plugin that's defined in a fragment ... since if
> Although it is acceptable to check a command or context to see if they're
> defined first.
> Later,
> PW
> Paul Webster
| Re: using keybindings, menus, and context in a fragment [message #326971 is a reply to message #326966] |
Thu, 03 April 2008 14:39   |
Its like it doesnt understand org.eclipse.ui.menus. I am using 3.3.1.1.
The toolbar should appear based on which editor is open, and that is not
being shown. When I go to the page that sets the context, it gets this
error":
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent
identifier from an undefined context. com.mycompany.context
at org.eclipse.core.commands.contexts.Context.getParentId(Conte xt.java:201)
org.eclipse.jface.bindings.BindingManager.createFilteredCont extTreeFor(BindingManager.java:825)
org.eclipse.jface.bindings.BindingManager.recomputeBindings( BindingManager.java:1720)
org.eclipse.jface.bindings.BindingManager.contextManagerChan ged(BindingManager.java:689)
org.eclipse.core.commands.contexts.ContextManager.fireContex tManagerChanged(ContextManager.java:152)
org.eclipse.core.commands.contexts.ContextManager.addActiveC ontext(ContextManager.java:96)
org.eclipse.ui.internal.contexts.ContextAuthority.updateCont ext(ContextAuthority.java:765)
org.eclipse.ui.internal.contexts.ContextAuthority.activateCo ntext(ContextAuthority.java:179)
org.eclipse.ui.internal.contexts.ContextService.activateCont ext(ContextService.java:88)
org.eclipse.ui.internal.contexts.SlaveContextService.doActiv ateContext(SlaveContextService.java:279)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:164)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:133)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:122)
com.mycompany.ToolhelpEditorPage.addLongHelpTextEditorTab(To olhelpEditorPage.java:114)
at com.mycompany.ToolhelpEditorPage.createTabs(ToolhelpEditorPa ge.java:92)
com.mycompany.AbstractTabbedFormPage.createFormContent(Abstr actTabbedFormPage.java:80)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:151 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormP age.java:149)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor .java:488)
com.mycompany.AbstractMetadataEditor.pageChange(AbstractMeta dataEditor.java:998)
org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(Mul tiPageEditorPart.java:239)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 06)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3227)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:20 05)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:316)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> 'ss'
> defined first.
> Later,
> PW
> Paul Webster
| Re: using keybindings, menus, and context in a fragment [message #326975 is a reply to message #326972] |
Thu, 03 April 2008 15:28   |
Before opening editor:
12 RESOLVED com.mycompany.eclipse.toolhelp_0.1.4
Master=13
13 <<LAZY>> com.mycompany.eclipse.ui_0.1.4
Fragments=11, 12
13 changes to ACTIVE once I open the editor.
ToolhelpEditorPage is defined in the fragment as well
I created a second toolbar in the fragment.xml to remove some of the
complexity of my original one. This shows up when I'm testing using eclipse
to launch, but not after I do a build and run it that way.
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="toolbar:org.eclipse.ui.main.toolbar">
<toolbar id="com.mycompany.eclipse.toolbar2">
<command
commandId="org.eclipse.ui.file.print"
name="print"
categoryId="org.eclipse.ui.category.file"
tooltip="myprint"
</command>
</toolbar>
</menuContribution>
</extension>
news:ft39r5$5ip$1@build.eclipse.org...
> the state output by -console followed by ss (installed, resolved, active,
> etc).
> So ToolhelpEditorPage is defined in the fragment as well? BTW the below
> error indicates that the org.eclipse.ui.contexts definition for
> com.mycompany.context is not available to ToolhelpEditorPage. I'm
> surprised the system was able to load the class from your fragment but not
> the extension.
> > error":
> parent
> > at
> > at
> > at
> Are there any errors in your error log before this one? What are the
> first 2 or 3 errors after the !SESSION marker?
> PW
> Paul Webster
Current Time: Sun Nov 09 06:32:07 EST 2025
Powered by FUDForum. Page generated in 0.04553 seconds
