Home » Eclipse Projects » Eclipse Platform » using keybindings, menus, and context in a fragment
using keybindings, menus, and context in a fragment [message #326960] Thu, 03 April 2008 13:08 Go to next message
I have a fragment, which defines a context, menu, commands, handlers and
keybindings. This works when I run the project through eclipse to debug,
but when I do a build and run the program, I no longer see my toolbar and
menu. I get a NotDefinedException for the context. Can I define the menus
in the fragment? The fragment is to contribute a page and menus to several
of our editors. In the page, I have the code:
IContextService contextService = (IContextService)
getSite().getService(IContextService.class);
contextService.activateContext("com.mycompany.context");
And have that context defined in fragment.xml for my fragment. Is there
anything I need to do to set any dependencies?
Re: using keybindings, menus, and context in a fragment [message #326966 is a reply to message #326960] Thu, 03 April 2008 14:10 Go to previous messageGo to next message
When a fragment is available, its classpath and XML appear just as if
they were in the host plugin. Start your deployed app with -console and
do an 'ss'
What is the state of your plugin? What is the state of your fragment?
BTW: it doesn't really make sense to reference something concrete like a
context or command from a plugin that's defined in a fragment ... since
if the fragment is not there, you'll get killed.
Although it is acceptable to check a command or context to see if
they're defined first.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: using keybindings, menus, and context in a fragment [message #326970 is a reply to message #326966] Thu, 03 April 2008 14:32 Go to previous messageGo to next message
what do you mean by state?
The page that holds that context code is all in the fragment.
Sorry I'm a newbie.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:ft368k$dad$1@build.eclipse.org...
>> menus in the fragment? The fragment is to contribute a page and menus to
>> several of our editors. In the page, I have the code:
> When a fragment is available, its classpath and XML appear just as if they
> were in the host plugin. Start your deployed app with -console and do an
> 'ss'
> context or command from a plugin that's defined in a fragment ... since if
> Although it is acceptable to check a command or context to see if they're
> defined first.
> Later,
> PW
> Paul Webster
Re: using keybindings, menus, and context in a fragment [message #326971 is a reply to message #326966] Thu, 03 April 2008 14:39 Go to previous messageGo to next message
Its like it doesnt understand org.eclipse.ui.menus. I am using 3.3.1.1.
The toolbar should appear based on which editor is open, and that is not
being shown. When I go to the page that sets the context, it gets this
error":
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent
identifier from an undefined context. com.mycompany.context
at org.eclipse.core.commands.contexts.Context.getParentId(Conte xt.java:201)
org.eclipse.jface.bindings.BindingManager.createFilteredCont extTreeFor(BindingManager.java:825)
org.eclipse.jface.bindings.BindingManager.recomputeBindings( BindingManager.java:1720)
org.eclipse.jface.bindings.BindingManager.contextManagerChan ged(BindingManager.java:689)
org.eclipse.core.commands.contexts.ContextManager.fireContex tManagerChanged(ContextManager.java:152)
org.eclipse.core.commands.contexts.ContextManager.addActiveC ontext(ContextManager.java:96)
org.eclipse.ui.internal.contexts.ContextAuthority.updateCont ext(ContextAuthority.java:765)
org.eclipse.ui.internal.contexts.ContextAuthority.activateCo ntext(ContextAuthority.java:179)
org.eclipse.ui.internal.contexts.ContextService.activateCont ext(ContextService.java:88)
org.eclipse.ui.internal.contexts.SlaveContextService.doActiv ateContext(SlaveContextService.java:279)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:164)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:133)
org.eclipse.ui.internal.contexts.SlaveContextService.activat eContext(SlaveContextService.java:122)
com.mycompany.ToolhelpEditorPage.addLongHelpTextEditorTab(To olhelpEditorPage.java:114)
at com.mycompany.ToolhelpEditorPage.createTabs(ToolhelpEditorPa ge.java:92)
com.mycompany.AbstractTabbedFormPage.createFormContent(Abstr actTabbedFormPage.java:80)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:151 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormP age.java:149)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor .java:488)
com.mycompany.AbstractMetadataEditor.pageChange(AbstractMeta dataEditor.java:998)
org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(Mul tiPageEditorPart.java:239)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 06)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3227)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:20 05)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:316)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> 'ss'
> defined first.
> Later,
> PW
> Paul Webster
Re: using keybindings, menus, and context in a fragment [message #326972 is a reply to message #326970] Thu, 03 April 2008 15:11 Go to previous messageGo to next message
the state output by -console followed by ss (installed, resolved,
active, etc).
So ToolhelpEditorPage is defined in the fragment as well? BTW the below
error indicates that the org.eclipse.ui.contexts definition for
com.mycompany.context is not available to ToolhelpEditorPage. I'm
surprised the system was able to load the class from your fragment but
not the extension.
> error":
parent
> at
> at
> at
Are there any errors in your error log before this one? What are the
first 2 or 3 errors after the !SESSION marker?
PW
Paul Webster
Re: using keybindings, menus, and context in a fragment [message #326975 is a reply to message #326972] Thu, 03 April 2008 15:28 Go to previous messageGo to next message
Before opening editor:
12 RESOLVED com.mycompany.eclipse.toolhelp_0.1.4
Master=13
13 <<LAZY>> com.mycompany.eclipse.ui_0.1.4
Fragments=11, 12
13 changes to ACTIVE once I open the editor.
I created a second toolbar in the fragment.xml to remove some of the
complexity of my original one. This shows up when I'm testing using eclipse
to launch, but not after I do a build and run it that way.
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="toolbar:org.eclipse.ui.main.toolbar">
<toolbar id="com.mycompany.eclipse.toolbar2">
<command
commandId="org.eclipse.ui.file.print"
name="print"
categoryId="org.eclipse.ui.category.file"
tooltip="myprint"
</command>
</toolbar>
</menuContribution>
</extension>
news:ft39r5$5ip$1@build.eclipse.org...
> the state output by -console followed by ss (installed, resolved, active,
> etc).
> surprised the system was able to load the class from your fragment but not
> the extension.
> > error":
> parent
> > at
> > at
> > at
> PW
> Paul Webster
Re: using keybindings, menus, and context in a fragment [message #327006 is a reply to message #326975] Fri, 04 April 2008 09:19 Go to previous message
> Master=13
> Fragments=11, 12
That shouldn't be a problem ... I have a fragment, and my
menuContribution shows up in my deployed RCP app even when the fragment
is RESOLVED:
20 ACTIVE z.ex.mailplus_1.0.0
Fragments=21
21 RESOLVED z.ex.mailplus.frag_1.0.0
Master=20
How are you generating your RCP app? i.e. I sucked my product into a
Product Configuration editor (based on plugins) and exported it from there.
Does your config.ini in your deployed RCP app list all of your bundles,
including the fragments in the osgi.bundles property? It probably does,
if you can see yoru fragment com.mycompany.eclipse.toolhelp_0.1.4
deployed and RESOLVED.
Does your fragment have singleton:=true in its MANIFEST.MF? If not,
that would prevent the fragment.xml from being read even though the
plugin is resolved.
PW
Paul Webster
Previous Topic:With -Xmx951M Eclipse fails to start
Next Topic:creating a runnable rcp app using headless pde build
Current Time: Tue Nov 18 17:15:41 EST 2025
Powered by FUDForum. Page generated in 0.05136 seconds
