Home » Eclipse Projects » Eclipse Platform » Extension Point Schema
Extension Point Schema [message #326925] Thu, 03 April 2008 04:36 Go to next message
Hi all,
I noticed that the ID and the name of an extension point are defined twice
in the plugin.xml file AND in the schema file.
I also noticed that these IDs are different for one of my Extension point
but everything works well ..
What is the difference between these 2 Id's and names ??
Manu
http://manuelselva.wordpress.com
Re: Extension Point Schema [message #326945 is a reply to message #326925] Thu, 03 April 2008 09:50 Go to previous messageGo to next message
AFAIK they shouldn't be different ... it's like a typo, and while it
won't effect the operation of your extension point (most of the time) it
can cause problems with certain aspects of the PDE tooling.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Extension Point Schema [message #326996 is a reply to message #326945] Fri, 04 April 2008 03:39 Go to previous message
Thanks for the answer Paul
Manu
Previous Topic:Views communicating in the workbench
Next Topic:Size information fdrom IFile
Current Time: Fri Nov 21 04:07:09 EST 2025
Powered by FUDForum. Page generated in 0.06678 seconds
