Home » Language IDEs » PHP Development Tools (PDT) » PDT not working in 3.3 Europa
PDT not working in 3.3 Europa [message #33109] Tue, 03 July 2007 11:18 Go to next message
Originally posted by: matt.scimedsolutions.com
Hey folks, I have been using the Zend editor for a couple years, and am
trying to move to Eclipse. I have spent many hours trying to get PDT to
work and am aving no luck. There is no PHP perpective, cannot create new
PHP projects etc.. When I look at the Software Upadates->Manage
Configuration I see the PDT installed, but it simply does not work.
I have installed the PDT M1 All-in-one release and still no go. I have
tried this on Window and Mac.
I think I must be missing something simple here.
Any thoughts?
Matt White
Scimed Solutions
919-287-1817
matt@scimedsolutions.com
Re: PDT not working in 3.3 Europa [message #33144 is a reply to message #33109] Tue, 03 July 2007 11:19 Go to previous messageGo to next message
Are you using Java 5.0 ? M1 won't work with anything less.
Dave Kelsey
> Any thoughts?
> Matt White
> Scimed Solutions
> 919-287-1817
Re: PDT not working in 3.3 Europa [message #33312 is a reply to message #33109] Tue, 03 July 2007 20:29 Go to previous messageGo to next message
On Tue, 03 Jul 2007 11:18:19 -0400
> Any thoughts?
Here's what I've done:
Installed JRE6 (1.6.x)
Download Eclipse Classic 3.3 and install it
Manage the configuration of Eclipse and install the WST and all required packages off of that
( Help > Software Updates > Find and Install... > Search for new features to install > Europa Discovery Site > WST )
Install and restart Eclipse
Quit Eclipse
Download the latest nightly of PDT from http://www.eclipse.org/pdt/
install the files into Eclipse:
move to the folder above your eclipse folder
unzip ~/org.eclipse.php_feature-incubation-N20070702.zip
Start Eclipse
Adam Randall adam@lockdownnetworks.com
Senior Software Engineer (866) 844-8080
Lockdown Networks, Inc.
Re: PDT not working in 3.3 Europa [message #33347 is a reply to message #33109] Wed, 04 July 2007 04:30 Go to previous messageGo to next message
I don't get it on Linux Fedora Core 5,
Using Eclipse 3.3 and WST,
I tried JDK 1.6.0_01 ; JRE 1.5.0_12 ; JDK 1.6.0_02
With org.eclipse.php_feature-incubation-N20070703
(And 1M1 with JDK 1.6.0_01)
I have no outline, no formatter (it send all to the left, leaving no
spaces nor tabs), no folding.
(I tried diferents set of preferences)
Did I miss something ?
Re: PDT not working in 3.3 Europa [message #33382 is a reply to message #33347] Wed, 04 July 2007 06:36 Go to previous messageGo to next message
> spaces nor tabs), no folding. (I tried diferents set of preferences)
is this because pdt depends on jem which is not part of Europa (together
with the visual editor)?
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: PDT not working in 3.3 Europa [message #33462 is a reply to message #33382] Wed, 04 July 2007 09:03 Go to previous messageGo to next message
I alse tried the all ni one PDT with 1.5 and 1.6 JRE with the same result.
Maybe the JEM prerquisite should be revisited
About VE, see
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.ve
Re: PDT not working in 3.3 Europa [message #34112 is a reply to message #33462] Fri, 06 July 2007 07:13 Go to previous messageGo to next message
It is working finally.
The problem was that I opened an old project and it wasn't fully recognize
as PHP, even if the icons showed the PHP nature of the files !
I had to do 2 things :
- Change the .project (simply delete it and reimport the project) or
create a new workspace.
- for each file delete the "<?php" header and retype it : the oultine show
up !
refreshing the project or the file didn't do anything !
Notice that moving a file from a directory to another looses its "PHP
nature" : it still has the icons, but no outlines : you will have to
again, retype the "<?php" !
I think that I will fill a bug ...
By the way I am using
java.runtime.version=1.6.0_02-b05
*** Features:
org.eclipse.cvs (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS Client"
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common"
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI"
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200706262000) "EMF Ecore Edit Support"
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI"
org.eclipse.gef (3.3.0.v20070620) "Graphical Editing Framework"
org.eclipse.php_feature (1.0.0.HEAD-79--9qMqC) "PDT Plug-in (Incubation)"
org.eclipse.platform (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse
Platform"
org.eclipse.rcp (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP"
org.eclipse.wst (2.0.0.v200706041905-7C-18k0IWJZ93WDDJlQ60nUjTdJp) "Web
Standard Tools (WST)"
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200706262000) "XML Schema Edit Framework"
Re: PDT not working in 3.3 Europa [message #34147 is a reply to message #34112] Fri, 06 July 2007 12:55 Go to previous message
> recognize as PHP, even if the icons showed the PHP nature of the files !
but the dependence on jem comes out when you try to install PDT from the
update site...
Previous Topic:What kind of deployment is usually used and what is possible?
Next Topic:PHP debugger will not start
Current Time: Sun Nov 16 18:09:00 EST 2025
Powered by FUDForum. Page generated in 0.05393 seconds
