Home » Eclipse Projects » Eclipse Platform » FireHandlerChanged doesn't work from non-GUI thread
FireHandlerChanged doesn't work from non-GUI thread [message #326712] Sun, 30 March 2008 23:13 Go to next message
In 3.3.2, when a handler calls #fireHandlerChanged in a thread that
isn't the GUI thread, then associated menu items do not get updated. The
call appears to just get ignored. So currently the only way to
enable/disable menu items in response to background events (e.g. message
received over the network), is to asyncExec the fireHandlerChanged call,
which strikes me as awkward.
Is this behavior by design or is this a bug?
Jasper.
Re: FireHandlerChanged doesn't work from non-GUI thread [message #326724 is a reply to message #326712] Mon, 31 March 2008 07:34 Go to previous messageGo to next message
Jasper,
Given that SWT checks that all display/widget access is done on the
display's thread, this seems like a necessary thing...
> The call appears to just get ignored. So currently the only way to
> message received over the network), is to asyncExec the
> fireHandlerChanged call, which strikes me as awkward.
> Jasper.
Re: FireHandlerChanged doesn't work from non-GUI thread [message #326735 is a reply to message #326712] Mon, 31 March 2008 08:56 Go to previous messageGo to next message
While all access to services must be in the UI thread (everything from
the workbench is required to be accessed from the UI thread unless it
states otherwise) this behaviour is a bug, since
org.eclipse.core.commands technically has nothing to do with the UI.
Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=210862 fixed in 3.4
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: FireHandlerChanged doesn't work from non-GUI thread [message #326740 is a reply to message #326724] Mon, 31 March 2008 09:04 Go to previous messageGo to next message
Ed,
It seems like a pretty severe drawback to me. Imo, this is an(other)
example of how the Command/Handler/MenuItem approach of not
re-evaluating enablement state unless the framework is explicitly
notified of a change to such state, is in practice not as flexible a
setup as the old Actions approach in which enablement was always checked
immediately prior to re-rendering.
In the latter approach, it was irrelevant which thread set the
enablement. In the current approach, the caller needs to be aware of
what thread it's in, which is odd, and needs to async the call, making
it impossible to avoid a dependency on SWT.
My $0.02 worth :-)
Jasper.
Ed Merks wrote:
> Jasper,
>> Thanks,
>> Jasper.
Re: FireHandlerChanged doesn't work from non-GUI thread [message #326741 is a reply to message #326735] Mon, 31 March 2008 09:10 Go to previous messageGo to next message
Paul,
Your message crossed mine. Cool that it's fixed.
Jasper.
> PW
Re: FireHandlerChanged doesn't work from non-GUI thread [message #326743 is a reply to message #326740] Mon, 31 March 2008 09:40 Go to previous message
Jasper wrote:
> Ed,
Actions don't do this either, they only re-check their state under a
limited set of circumstances. They're the worst combination of MVC in
one class.
Actually, it did matter ... simply that ActionContributionItem added the
non-UI thread protection ages ago, and it was missed in
CommandContributionItem.
Later,
PW
Paul Webster
Previous Topic:Multiple selections without Shift- and Ctrl-keys?
Next Topic:Thread dump in eclipse console?
Current Time: Thu Jul 17 19:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.03910 seconds
