Home » Eclipse Projects » Eclipse Platform » [Databinding] testing
[Databinding] testing [message #326667] Thu, 27 March 2008 16:33 Go to next message
How should I write my junit tests to test these beans and the binding? I
would like to automate as much as possible. I understand how to write the
tests I need to make sure the beans start with the correct values, but do
not understand how to test the values that could change by the user.
Re: [Databinding] testing [message #326691 is a reply to message #326667] Fri, 28 March 2008 13:13 Go to previous message
Jay,
Could you be more specific about what you're trying to test? If you
want to make sure that a binding is working, you could do something like:
testNameBinding() {
person.setName("test");
IObservableValue model = BeansObservables.observeValue(person, "name");
IObservableValue target = SWTObservables.observeText(personText,
SWT.Modify);
dbc.bind(target, model, null, null);
assertEquals("test", target.getValue());
target.setValue("test2");
assertEquals("test2", model.getValue());
Is this what you had in mind?
If so, take a look at AbstractDefaultRealmTestCase in the tests plugin.
This will ease the burden of testing observables.
Matthew
Previous Topic:[Databinding] databinding arrays and lists of strings
Next Topic:Publishing error on a dynamic web app project
Current Time: Thu Nov 06 03:46:02 EST 2025
Powered by FUDForum. Page generated in 0.05678 seconds
