Home » Eclipse Projects » Eclipse Platform » JVM crash on editor view opening
| JVM crash on editor view opening [message #326640] |
Thu, 27 March 2008 06:19  |
--nextPart10231507.jmxeK4eo1x
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
Hi!
At one sad moment I have discovered JVM crashes when I create any new or
open any already created file (java, xml, ... - any) in editor view. I have
tried to find appropriate cases in bugs and via googling without success.
Eclipse tried are 3.3.1 and 3.3.1.1, x86_64 arch. Crash file is attached.
Have tried:
- clean reinstall,
- clean project dir,
- different X11 (KDE, fluxbox), different JDK (1.5, 1.6),
- manual install (with prebuilt .so files),
- Gentoo official way install (swt is installed from sources).
Nothing helps. No any other "strange signs in system".
Please, help!
Must I supply additional info?
Content-Type: text/plain; name="hs_err_pid19534.log"
Content-Disposition: attachment; filename="hs_err_pid19534.log"
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00002b0b38d37c0d, pid=19534, tid=1076017488
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b19 mixed mode linux-amd64)
# Problematic frame:
# C [libc.so.6+0x60c0d] fgets+0x2d
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000040112c00): JavaThread "main" [_thread_in_native, id=19538, stack(0x000000004012b000,0x000000004022c000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xffffffffc4cb6730
Registers:
RAX=0x00002aaac4cb6730, RBX=0xffffffffc4cb6730, RCX=0x0000000000000000, RDX=0xffffffffc4cb6730
RSP=0x0000000040227100, RBP=0x0000000040227120, RSI=0x0000000000000400, RDI=0x0000000040227120
R8 =0x0000000000000400, R9 =0x0000000000000001, R10=0x0000000000000000, R11=0x00002b0b38d37be0
R12=0xffffffffc4cb6730, R13=0x0000000040227128, R14=0x0000000040227558, R15=0x00002aaac5651758
RIP=0x00002b0b38d37c0d, EFL=0x0000000000010216, CSGSFS=0x0000000000000033, ERR=0x0000000000000005
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x0000000040227100)
0x0000000040227100: 00002aaad76642db 00002aaacda470c0
0x0000000040227110: ffffffffc4cb6730 00002aaad765eab0
0x0000000040227120: 00000002402270e0 0000000000000000
0x0000000040227130: 00002aaa00000000 0000000000000000
0x0000000040227140: 0000000000000000 0000000000000000
0x0000000040227150: 0000000000000000 0000000000000000
0x0000000040227160: 00002aaad765af20 00002b0b3859c464
0x0000000040227170: 0000000000000001 73002aaac405a2a0
0x0000000040227180: 0000000040227140 0000000040227620
0x0000000040227190: 00002aaad765af8d 00002b0b3859c464
0x00000000402271a0: 0000000000000001 00002b0b38ad2000
0x00000000402271b0: 0000000040227170 0000000040227620
0x00000000402271c0: 00002aaad765af82 00002b0b3859c464
0x00000000402271d0: 0000000000000000 00002b0bffffffff
0x00000000402271e0: 00000000402271a0 000000004010b5b0
0x00000000402271f0: 0000000000000004 0000000000000008
0x0000000040227200: 00000000c53b745f 00002b0b38599e4c
0x0000000040227210: 00000000402271d0 00002b0b38cda884
0x0000000040227220: 00002aaad765af5a 0000001f3859c464
0x0000000040227230: 000000000314edd1 0000000040227250
0x0000000040227240: 00000000402273b8 00002b0b38cdab50
0x0000000040227250: 0000000000000000 00002aaac5d188c0
0x0000000040227260: 00002b0b38ad24a8 00002aaad81cf55e
0x0000000040227270: 00002b0b38ce7048 00002aaad81cf338
0x0000000040227280: 0000000500000000 0000000100000782
0x0000000040227290: 0000000000000001 00002b0b38599ab1
0x00000000402272a0: 00000000402273f0 00002aaac5d18760
0x00000000402272b0: 000000000000000d 0000000000000032
0x00000000402272c0: 00000000eec83511 00002b0b38599e4c
0x00000000402272d0: 0000000000000000 00002aaacf13ee2c
0x00000000402272e0: 00002aaa00000005 0000001100000000
0x00000000402272f0: 0000000003bb20d4 0000000040227310
Instructions: (pc=0x00002b0b38d37c0d)
0x00002b0b38d37bfd: d3 0f 8e 21 01 00 00 83 fe 01 0f 84 36 01 00 00
0x00002b0b38d37c0d: 8b 02 66 85 c0 78 53 48 8b 92 88 00 00 00 64 4c
Stack: [0x000000004012b000,0x000000004022c000], sp=0x0000000040227100, free space=1008k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
v ~BufferBlob::Interpreter
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
v ~BufferBlob::StubRoutines (1)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aaad2df4000 JavaThread "Worker-4" [_thread_blocked, id=19563, stack(0x000000004143e000,0x000000004153f000)]
0x00002aaad4e7a000 JavaThread "Worker-3" [_thread_blocked, id=19562, stack(0x000000004133d000,0x000000004143e000)]
0x00002aaad508c800 JavaThread "Worker-2" [_thread_blocked, id=19561, stack(0x000000004113b000,0x000000004123c000)]
0x00002aaad2c31000 JavaThread "Worker-1" [_thread_blocked, id=19560, stack(0x000000004103a000,0x000000004113b000)]
0x00002aaac4d27800 JavaThread "Java indexing" daemon [_thread_blocked, id=19559, stack(0x000000004123c000,0x000000004133d000)]
0x00002aaad4375400 JavaThread "Worker-0" [_thread_blocked, id=19556, stack(0x0000000040f39000,0x000000004103a000)]
0x00002aaac41c2800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=19553, stack(0x0000000040e38000,0x0000000040f39000)]
0x00002aaac41c1000 JavaThread "State Saver" [_thread_blocked, id=19552, stack(0x0000000040d37000,0x0000000040e38000)]
0x00002aaac41e7000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=19551, stack(0x0000000040c36000,0x0000000040d37000)]
0x00002aaac402c800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=19547, stack(0x0000000040a34000,0x0000000040b35000)]
0x00002aaac4029c00 JavaThread "CompilerThread1" daemon [_thread_blocked, id=19546, stack(0x0000000040933000,0x0000000040a34000)]
0x00002aaac4028400 JavaThread "CompilerThread0" daemon [_thread_in_native, id=19545, stack(0x0000000040832000,0x0000000040933000)]
0x00002aaac4026c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=19544, stack(0x0000000040731000,0x0000000040832000)]
0x00002aaac4000c00 JavaThread "Finalizer" daemon [_thread_blocked, id=19543, stack(0x0000000040630000,0x0000000040731000)]
0x00002aaac80de000 JavaThread "Reference Handler" daemon [_thread_blocked, id=19542, stack(0x000000004052f000,0x0000000040630000)]
=>0x0000000040112c00 JavaThread "main" [_thread_in_native, id=19538, stack(0x000000004012b000,0x000000004022c000)]
Other Threads:
0x00002aaac80d8c00 VMThread [stack: 0x000000004042e000,0x000000004052f000] [id=19541]
0x00002aaac402e800 WatcherThread [stack: 0x0000000040b35000,0x0000000040c36000] [id=19548]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 76096K, used 42557K [0x00002aaabe920000, 0x00002aaac3e70000, 0x00002aaac3e70000)
eden space 64128K, 56% used [0x00002aaabe920000,0x00002aaac0c57be0,0x00002aaac27c0000)
from space 11968K, 54% used [0x00002aaac32c0000,0x00002aaac39178b0,0x00002aaac3e70000)
to space 11264K, 0% used [0x00002aaac27c0000,0x00002aaac27c0000,0x00002aaac32c0000)
PSOldGen total 87424K, used 10311K [0x00002aaab3e70000, 0x00002aaab93d0000, 0x00002aaabe920000)
object space 87424K, 11% used [0x00002aaab3e70000,0x00002aaab4881e28,0x00002aaab93d0000)
PSPermGen total 47360K, used 47213K [0x00002aaaaea70000, 0x00002aaab18b0000, 0x00002aaab3e70000)
object space 47360K, 99% used [0x00002aaaaea70000,0x00002aaab188b7c8,0x00002aaab18b0000)
Dynamic libraries:
40000000-40009000 r-xp 00000000 08:03 1191955 /opt/sun-jdk-1.6.0.05/bin/java
40108000-4010a000 rwxp 00008000 08:03 1191955 /opt/sun-jdk-1.6.0.05/bin/java
4010a000-4012b000 rwxp 4010a000 00:00 0 [heap]
4012b000-4012e000 ---p 4012b000 00:00 0
4012e000-4022c000 rwxp 4012e000 00:00 0
4022c000-4022d000 ---p 4022c000 00:00 0
4022d000-4032d000 rwxp 4022d000 00:00 0
4032d000-4032e000 ---p 4032d000 00:00 0
4032e000-4042e000 rwxp 4032e000 00:00 0
4042e000-4042f000 ---p 4042e000 00:00 0
4042f000-4052f000 rwxp 4042f000 00:00 0
4052f000-40532000 ---p 4052f000 00:00 0
40532000-40630000 rwxp 40532000 00:00 0
40630000-40633000 ---p 40630000 00:00 0
40633000-40731000 rwxp 40633000 00:00 0
40731000-40734000 ---p 40731000 00:00 0
40734000-40832000 rwxp 40734000 00:00 0
40832000-40835000 ---p 40832000 00:00 0
40835000-40933000 rwxp 40835000 00:00 0
40933000-40936000 ---p 40933000 00:00 0
40936000-40a34000 rwxp 40936000 00:00 0
40a34000-40a37000 ---p 40a34000 00:00 0
40a37000-40b35000 rwxp 40a37000 00:00 0
40b35000-40b36000 ---p 40b35000 00:00 0
40b36000-40c36000 rwxp 40b36000 00:00 0
40c36000-40c39000 ---p 40c36000 00:00 0
40c39000-40d37000 rwxp 40c39000 00:00 0
40d37000-40d3a000 ---p 40d37000 00:00 0
40d3a000-40e38000 rwxp 40d3a000 00:00 0
40e38000-40e3b000 ---p 40e38000 00:00 0
40e3b000-40f39000 rwxp 40e3b000 00:00 0
40f39000-40f3c000 ---p 40f39000 00:00 0
40f3c000-4103a000 rwxp 40f3c000 00:00 0
4103a000-4103d000 ---p 4103a000 00:00 0
4103d000-4113b000 rwxp 4103d000 00:00 0
4113b000-4113e000 ---p 4113b000 00:00 0
4113e000-4123c000 rwxp 4113e000 00:00 0
4123c000-4123f000 ---p 4123c000 00:00 0
4123f000-4133d000 rwxp 4123f000 00:00 0
4133d000-41340000 ---p 4133d000 00:00 0
41340000-4143e000 rwxp 41340000 00:00 0
4143e000-41441000 ---p 4143e000 00:00 0
41441000-4153f000 rwxp 41441000 00:00 0
2aaaaaaab000-2aaaaaaac000 r-xs 00009000 08:07 1065269 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.launcher_ 1.0.1.R33x_v20070828.jar
2aaaaaaac000-2aaaaaaae000 r-xs 00013000 08:07 1065288 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.common_3. 3.0.v20070426.jar
2aaaaaaae000-2aaaaaab0000 r-xs 00015000 08:07 1065232 /usr/lib64/eclipse-3.3/plugins/org.eclipse.update.configurat or_3.2.101.R33x_v20070810.jar
2aaaaaab0000-2aaaaaab2000 r-xs 00010000 08:07 1065265 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.runtime_3.3. 100.v20070530.jar
2aaaaaadc000-2aaaaaae4000 r-xp 00000000 08:03 1175918 /lib64/librt-2.7.so
2aaaaaae4000-2aaaaace3000 ---p 00008000 08:03 1175918 /lib64/librt-2.7.so
2aaaaace3000-2aaaaace4000 r-xp 00007000 08:03 1175918 /lib64/librt-2.7.so
2aaaaace4000-2aaaaace5000 rwxp 00008000 08:03 1175918 /lib64/librt-2.7.so
2aaaaace5000-2aaaaace6000 r-xp 2aaaaace5000 00:00 0
2aaaaace6000-2aaaaace7000 rwxp 2aaaaace6000 00:00 0
2aaaaace7000-2aaaaacee000 r-xp 00000000 08:03 1191900 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/native_threads/libhpi.so
2aaaaacee000-2aaaaadef000 ---p 00007000 08:03 1191900 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/native_threads/libhpi.so
2aaaaadef000-2aaaaadf1000 rwxp 00008000 08:03 1191900 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/native_threads/libhpi.so
2aaaaadf1000-2aaaaadf2000 rwxp 2aaaaadf1000 00:00 0
2aaaaadf2000-2aaaaadfa000 rwxs 00000000 08:03 48975 /tmp/hsperfdata_root/19534
2aaaaae22000-2aaaaae36000 r-xp 00000000 08:03 1175642 /lib64/libnsl-2.7.so
2aaaaae36000-2aaaab035000 ---p 00014000 08:03 1175642 /lib64/libnsl-2.7.so
2aaaab035000-2aaaab036000 r-xp 00013000 08:03 1175642 /lib64/libnsl-2.7.so
2aaaab036000-2aaaab037000 rwxp 00014000 08:03 1175642 /lib64/libnsl-2.7.so
2aaaab037000-2aaaab039000 rwxp 2aaaab037000 00:00 0
2aaaab039000-2aaaab040000 r-xp 00000000 08:03 1175639 /lib64/libnss_compat-2.7.so
2aaaab040000-2aaaab23f000 ---p 00007000 08:03 1175639 /lib64/libnss_compat-2.7.so
2aaaab23f000-2aaaab240000 r-xp 00006000 08:03 1175639 /lib64/libnss_compat-2.7.so
2aaaab240000-2aaaab241000 rwxp 00007000 08:03 1175639 /lib64/libnss_compat-2.7.so
2aaaab241000-2aaaab24a000 r-xp 00000000 08:03 1175631 /lib64/libnss_nis-2.7.so
2aaaab24a000-2aaaab44a000 ---p 00009000 08:03 1175631 /lib64/libnss_nis-2.7.so
2aaaab44a000-2aaaab44b000 r-xp 00009000 08:03 1175631 /lib64/libnss_nis-2.7.so
2aaaab44b000-2aaaab44c000 rwxp 0000a000 08:03 1175631 /lib64/libnss_nis-2.7.so
2aaaab44c000-2aaaab456000 r-xp 00000000 08:03 1175360 /lib64/libnss_files-2.7.so
2aaaab456000-2aaaab655000 ---p 0000a000 08:03 1175360 /lib64/libnss_files-2.7.so
2aaaab655000-2aaaab656000 r-xp 00009000 08:03 1175360 /lib64/libnss_files-2.7.so
2aaaab656000-2aaaab657000 rwxp 0000a000 08:03 1175360 /lib64/libnss_files-2.7.so
2aaaab657000-2aaaab664000 r-xp 00000000 08:03 1191873 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libverify.so
2aaaab664000-2aaaab763000 ---p 0000d000 08:03 1191873 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libverify.so
2aaaab763000-2aaaab766000 rwxp 0000c000 08:03 1191873 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libverify.so
2aaaab766000-2aaaab78e000 r-xp 00000000 08:03 1191867 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libjava.so
2aaaab78e000-2aaaab88e000 ---p 00028000 08:03 1191867 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libjava.so
2aaaab88e000-2aaaab895000 rwxp 00028000 08:03 1191867 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libjava.so
2aaaab895000-2aaaab8a3000 r-xp 00000000 08:03 1191902 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libzip.so
2aaaab8a3000-2aaaab9a5000 ---p 0000e000 08:03 1191902 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libzip.so
2aaaab9a5000-2aaaab9a8000 rwxp 00010000 08:03 1191902 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libzip.so
2aaaab9a8000-2aaaabc89000 rwxp 2aaaab9a8000 00:00 0
2aaaabc89000-2aaaae9a9000 rwxp 2aaaabc89000 00:00 0
2aaaae9a9000-2aaaae9b5000 rwxp 2aaaae9a9000 00:00 0
2aaaae9b5000-2aaaaea69000 rwxp 2aaaae9b5000 00:00 0
2aaaaea69000-2aaaaea6c000 r-xs 00012000 08:07 1226784 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.intro.universa l_3.2.100.v20070530A/universal.jar
2aaaaea70000-2aaab18b0000 rwxp 2aaaaea70000 00:00 0
2aaab18b0000-2aaab3e70000 rwxp 2aaab18b0000 00:00 0
2aaab3e70000-2aaab93d0000 rwxp 2aaab3e70000 00:00 0
2aaab93d0000-2aaabe920000 rwxp 2aaab93d0000 00:00 0
2aaabe920000-2aaac3e70000 rwxp 2aaabe920000 00:00 0
2aaac3e70000-2aaac3e88000 rwxp 2aaac3e70000 00:00 0
2aaac3e88000-2aaac3e9a000 rwxp 2aaac3e88000 00:00 0
2aaac3e9a000-2aaac3ec5000 rwxp 2aaac3e9a000 00:00 0
2aaac3ec5000-2aaac3eef000 rwxp 2aaac3ec5000 00:00 0
2aaac3eef000-2aaac3f1a000 rwxp 2aaac3eef000 00:00 0
2aaac3f1a000-2aaac3f46000 rwxp 2aaac3f1a000 00:00 0
2aaac3f46000-2aaac3f71000 rwxp 2aaac3f46000 00:00 0
2aaac3f71000-2aaac3f89000 rwxp 2aaac3f71000 00:00 0
2aaac3f89000-2aaac3f9b000 rwxp 2aaac3f89000 00:00 0
2aaac3f9b000-2aaac3fc3000 rwxp 2aaac3f9b000 00:00 0
2aaac3fc3000-2aaac3fc6000 rwxs 00000000 00:08 819203 /SYSV00000000 (deleted)
2aaac3fc6000-2aaac3fd3000 r-xp 00000000 08:07 3781598 /usr/share/fonts/ttf-bitstream-vera/VeraMono.ttf
2aaac3fd3000-2aaac3fdf000 r-xp 00000000 08:07 3781602 /usr/share/fonts/ttf-bitstream-vera/VeraMoBd.ttf
2aaac3fdf000-2aaac3fed000 r-xp 00000000 08:07 3781604 /usr/share/fonts/ttf-bitstream-vera/VeraMoIt.ttf
2aaac3fed000-2aaac3ffb000 r-xp 00000000 08:07 3781609 /usr/share/fonts/ttf-bitstream-vera/VeraMoBI.ttf
2aaac4000000-2aaac747e000 rwxp 2aaac4000000 00:00 0
2aaac747e000-2aaac8000000 ---p 2aaac747e000 00:00 0
2aaac8000000-2aaac8100000 rwxp 2aaac8000000 00:00 0
2aaac8100000-2aaac828a000 r-xs 02ded000 08:03 1142570 /opt/sun-jdk-1.6.0.05/jre/lib/rt.jar
2aaac828a000-2aaacccd3000 r-xp 00000000 08:07 817604 /usr/lib64/locale/locale-archive
2aaacccd3000-2aaaccfd3000 rwxp 2aaacccd3000 00:00 0
2aaaccfd3000-2aaaccfde000 r-xp 00000000 08:07 1133599 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_64_1.0.2.R331_v20071019/eclipse_1021.so
2aaaccfde000-2aaacd1dd000 ---p 0000b000 08:07 1133599 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_64_1.0.2.R331_v20071019/eclipse_1021.so
2aaacd1dd000-2aaacd1de000 r-xp 0000a000 08:07 1133599 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_64_1.0.2.R331_v20071019/eclipse_1021.so
2aaacd1de000-2aaacd1df000 rwxp 0000b000 08:07 1133599 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_64_1.0.2.R331_v20071019/eclipse_1021.so
2aaacd20f000-2aaacd5b2000 r-xp 00000000 08:07 741083 /usr/lib64/libgtk-x11-2.0.so.0.1200.9
2aaacd5b2000-2aaacd7b2000 ---p 003a3000 08:07 741083 /usr/lib64/libgtk-x11-2.0.so.0.1200.9
2aaacd7b2000-2aaacd7b9000 r-xp 003a3000 08:07 741083 /usr/lib64/libgtk-x11-2.0.so.0.1200.9
2aaacd7b9000-2aaacd7bd000 rwxp 003aa000 08:07 741083 /usr/lib64/libgtk-x11-2.0.so.0.1200.9
2aaacd7bd000-2aaacd7bf000 rwxp 2aaacd7bd000 00:00 0
2aaacd7bf000-2aaacd7d7000 r-xp 00000000 08:07 739349 /usr/lib64/libgdk_pixbuf-2.0.so.0.1200.9
2aaacd7d7000-2aaacd9d7000 ---p 00018000 08:07 739349 /usr/lib64/libgdk_pixbuf-2.0.so.0.1200.9
2aaacd9d7000-2aaacd9d8000 r-xp 00018000 08:07 739349 /usr/lib64/libgdk_pixbuf-2.0.so.0.1200.9
2aaacd9d8000-2aaacd9d9000 rwxp 00019000 08:07 739349 /usr/lib64/libgdk_pixbuf-2.0.so.0.1200.9
2aaacd9d9000-2aaacdad9000 rwxp 2aaacd9d9000 00:00 0
2aaacdad9000-2aaacdb19000 r-xp 00000000 08:07 739475 /usr/lib64/libgobject-2.0.so.0.1600.1
2aaacdb19000-2aaacdd19000 ---p 00040000 08:07 739475 /usr/lib64/libgobject-2.0.so.0.1600.1
2aaacdd19000-2aaacdd1a000 r-xp 00040000 08:07 739475 /usr/lib64/libgobject-2.0.so.0.1600.1
2aaacdd1a000-2aaacdd1b000 rwxp 00041000 08:07 739475 /usr/lib64/libgobject-2.0.so.0.1600.1
2aaacdd1b000-2aaacdd1c000 rwxp 2aaacdd1b000 00:00 0
2aaacdd1c000-2aaacddae000 r-xp 00000000 08:07 739767 /usr/lib64/libgdk-x11-2.0.so.0.1200.9
2aaacddae000-2aaacdfad000 ---p 00092000 08:07 739767 /usr/lib64/libgdk-x11-2.0.so.0.1200.9
2aaacdfad000-2aaacdfb1000 r-xp 00091000 08:07 739767 /usr/lib64/libgdk-x11-2.0.so.0.1200.9
2aaacdfb1000-2aaacdfb3000 rwxp 00095000 08:07 739767 /usr/lib64/libgdk-x11-2.0.so.0.1200.9
2aaacdfb3000-2aaacdfbd000 r-xp 00000000 08:07 739912 /usr/lib64/libpangocairo-1.0.so.0.2000.0
2aaacdfbd000-2aaace1bc000 ---p 0000a000 08:07 739912 /usr/lib64/libpangocairo-1.0.so.0.2000.0
2aaace1bc000-2aaace1bd000 r-xp 00009000 08:07 739912 /usr/lib64/libpangocairo-1.0.so.0.2000.0
2aaace1bd000-2aaace1be000 rwxp 0000a000 08:07 739912 /usr/lib64/libpangocairo-1.0.so.0.2000.0
2aaace1be000-2aaace1ff000 r-xp 00000000 08:07 741080 /usr/lib64/libpango-1.0.so.0.2000.0
2aaace1ff000-2aaace3ff000 ---p 00041000 08:07 741080 /usr/lib64/libpango-1.0.so.0.2000.0
2aaace3ff000-2aaace401000 r-xp 00041000 08:07 741080 /usr/lib64/libpango-1.0.so.0.2000.0
2aaace401000-2aaace402000 rwxp 00043000 08:07 741080 /usr/lib64/libpango-1.0.so.0.2000.0
2aaace402000-2aaace505000 r-xp 00000000 08:07 737523 /usr/lib64/libX11.so.6.2.0
2aaace505000-2aaace704000 ---p 00103000 08:07 737523 /usr/lib64/libX11.so.6.2.0
2aaace704000-2aaace706000 r-xp 00102000 08:07 737523 /usr/lib64/libX11.so.6.2.0
2aaace706000-2aaace70b000 rwxp 00104000 08:07 737523 /usr/lib64/libX11.so.6.2.0
2aaace70b000-2aaace70d000 r-xp 00000000 08:07 737761 /usr/lib64/libXcomposite.so.1.0.0
2aaace70d000-2aaace90c000 ---p 00002000 08:07 737761 /usr/lib64/libXcomposite.so.1.0.0
2aaace90c000-2aaace90e000 rwxp 00001000 08:07 737761 /usr/lib64/libXcomposite.so.1.0.0
2aaace90e000-2aaace910000 r-xp 00000000 08:07 737758 /usr/lib64/libXdamage.so.1.1.0
2aaace910000-2aaaceb0f000 ---p 00002000 08:07 737758 /usr/lib64/libXdamage.so.1.1.0
2aaaceb0f000-2aaaceb11000 rwxp 00001000 08:07 737758 /usr/lib64/libXdamage.so.1.1.0
2aaaceb11000-2aaaceb16000 r-xp 00000000 08:07 737619 /usr/lib64/libXfixes.so.3.1.0
2aaaceb16000-2aaaced15000 ---p 00005000 08:07 737619 /usr/lib64/libXfixes.so.3.1.0
2aaaced15000-2aaaced17000 rwxp 00004000 08:07 737619 /usr/lib64/libXfixes.so.3.1.0
2aaaced17000-2aaaced34000 r-xp 00000000 08:07 737697 /usr/lib64/libatk-1.0.so.0.2209.1
2aaaced34000-2aaacef33000 ---p 0001d000 08:07 737697 /usr/lib64/libatk-1.0.so.0.2209.1
2aaacef33000-2aaacef36000 r-xp 0001c000 08:07 737697 /usr/lib64/libatk-1.0.so.0.2209.1
2aaacef36000-2aaacef37000 rwxp 0001f000 08:07 737697 /usr/lib64/libatk-1.0.so.0.2209.1
2aaacef37000-2aaacef3a000 r-xp 00000000 08:07 739861 /usr/lib64/libgmodule-2.0.so.0.1600.1
2aaacef3a000-2aaacf139000 ---p 00003000 08:07 739861 /usr/lib64/libgmodule-2.0.so.0.1600.1
2aaacf139000-2aaacf13a000 r-xp 00002000 08:07 739861 /usr/lib64/libgmodule-2.0.so.0.1600.1
2aaacf13a000-2aaacf13b000 rwxp 00003000 08:07 739861 /usr/lib64/libgmodule-2.0.so.0.1600.1
2aaacf13b000-2aaacf211000 r-xp 00000000 08:07 741062 /usr/lib64/libglib-2.0.so.0.1600.1
2aaacf211000-2aaacf411000 ---p 000d6000 08:07 741062 /usr/lib64/libglib-2.0.so.0.1600.1
2aaacf411000-2aaacf412000 r-xp 000d6000 08:07 741062 /usr/lib64/libglib-2.0.so.0.1600.1
2aaacf412000-2aaacf413000 rwxp 000d7000 08:07 741062 /usr/lib64/libglib-2.0.so.0.1600.1
2aaacf413000-2aaacf414000 rwxp 2aaacf413000 00:00 0
2aaacf414000-2aaacf482000 r-xp 00000000 08:07 739132 /usr/lib64/libcairo.so.2.16.1
2aaacf482000-2aaacf682000 ---p 0006e000 08:07 739132 /usr/lib64/libcairo.so.2.16.1
2aaacf682000-2aaacf684000 r-xp 0006e000 08:07 739132 /usr/lib64/libcairo.so.2.16.1
2aaacf684000-2aaacf685000 rwxp 00070000 08:07 739132 /usr/lib64/libcairo.so.2.16.1
2aaacf685000-2aaacf6b3000 r-xp 00000000 08:07 739515 /usr/lib64/libfontconfig.so.1.3.0
2aaacf6b3000-2aaacf8b3000 ---p 0002e000 08:07 739515 /usr/lib64/libfontconfig.so.1.3.0
2aaacf8b3000-2aaacf8b4000 r-xp 0002e000 08:07 739515 /usr/lib64/libfontconfig.so.1.3.0
2aaacf8b4000-2aaacf8b5000 rwxp 0002f000 08:07 739515 /usr/lib64/libfontconfig.so.1.3.0
2aaacf8b5000-2aaacf8c5000 r-xp 00000000 08:07 740468 /usr/lib64/libXext.so.6.4.0
2aaacf8c5000-2aaacfac4000 ---p 00010000 08:07 740468 /usr/lib64/libXext.so.6.4.0
2aaacfac4000-2aaacfac5000 r-xp 0000f000 08:07 740468 /usr/lib64/libXext.so.6.4.0
2aaacfac5000-2aaacfac6000 rwxp 00010000 08:07 740468 /usr/lib64/libXext.so.6.4.0
2aaacfac6000-2aaacfacf000 r-xp 00000000 08:07 737611 /usr/lib64/libXrender.so.1.3.0
2aaacfacf000-2aaacfcce000 ---p 00009000 08:07 737611 /usr/lib64/libXrender.so.1.3.0
2aaacfcce000-2aaacfcd0000 rwxp 00008000 08:07 737611 /usr/lib64/libXrender.so.1.3.0
2aaacfcd0000-2aaacfcd8000 r-xp 00000000 08:07 740110 /usr/lib64/libXi.so.6.0.0
2aaacfcd8000-2aaacfed8000 ---p 00008000 08:07 740110 /usr/lib64/libXi.so.6.0.0
2aaacfed8000-2aaacfeda000 rwxp 00008000 08:07 740110 /usr/lib64/libXi.so.6.0.0
2aaacfeda000-2aaacfee1000 r-xp 00000000 08:07 737710 /usr/lib64/libXrandr.so.2.1.0
2aaacfee1000-2aaad00e0000 ---p 00007000 08:07 737710 /usr/lib64/libXrandr.so.2.1.0
2aaad00e0000-2aaad00e2000 rwxp 00006000 08:07 737710 /usr/lib64/libXrandr.so.2.1.0
2aaad00e2000-2aaad00eb000 r-xp 00000000 08:07 737662 /usr/lib64/libXcursor.so.1.0.2
2aaad00eb000-2aaad02ea000 ---p 00009000 08:07 737662 /usr/lib64/libXcursor.so.1.0.2
2aaad02ea000-2aaad02ec000 rwxp 00008000 08:07 737662 /usr/lib64/libXcursor.so.1.0.2
2aaad02ec000-2aaad0317000 r-xp 00000000 08:07 741082 /usr/lib64/libpangoft2-1.0.so.0.2000.0
2aaad0317000-2aaad0516000 ---p 0002b000 08:07 741082 /usr/lib64/libpangoft2-1.0.so.0.2000.0
2aaad0516000-2aaad0517000 r-xp 0002a000 08:07 741082 /usr/lib64/libpangoft2-1.0.so.0.2000.0
2aaad0517000-2aaad0518000 rwxp 0002b000 08:07 741082 /usr/lib64/libpangoft2-1.0.so.0.2000.0
2aaad0518000-2aaad059e000 r-xp 00000000 08:07 737834 /usr/lib64/libfreetype.so.6.3.16
2aaad059e000-2aaad079d000 ---p 00086000 08:07 737834 /usr/lib64/libfreetype.so.6.3.16
2aaad079d000-2aaad07a2000 r-xp 00085000 08:07 737834 /usr/lib64/libfreetype.so.6.3.16
2aaad07a2000-2aaad07a3000 rwxp 0008a000 08:07 737834 /usr/lib64/libfreetype.so.6.3.16
2aaad07a3000-2aaad07b7000 r-xp 00000000 08:03 1175341 /lib64/libz.so.1.2.3
2aaad07b7000-2aaad09b6000 ---p 00014000 08:03 1175341 /lib64/libz.so.1.2.3
2aaad09b6000-2aaad09b8000 rwxp 00013000 08:03 1175341 /lib64/libz.so.1.2.3
2aaad09b8000-2aaad09ba000 r-xp 00000000 08:07 737542 /usr/lib64/libXau.so.6.0.0
2aaad09ba000-2aaad0bb9000 ---p 00002000 08:07 737542 /usr/lib64/libXau.so.6.0.0
2aaad0bb9000-2aaad0bbb000 rwxp 00001000 08:07 737542 /usr/lib64/libXau.so.6.0.0
2aaad0bbb000-2aaad0bc0000 r-xp 00000000 08:07 738298 /usr/lib64/libXdmcp.so.6.0.0
2aaad0bc0000-2aaad0dbf000 ---p 00005000 08:07 738298 /usr/lib64/libXdmcp.so.6.0.0
2aaad0dbf000-2aaad0dc1000 rwxp 00004000 08:07 738298 /usr/lib64/libXdmcp.so.6.0.0
2aaad0dc1000-2aaad0e31000 r-xp 00000000 08:07 738436 /usr/lib64/libdirectfb-1.1.so.0.1.0
2aaad0e31000-2aaad1030000 ---p 00070000 08:07 738436 /usr/lib64/libdirectfb-1.1.so.0.1.0
2aaad1030000-2aaad1032000 r-xp 0006f000 08:07 738436 /usr/lib64/libdirectfb-1.1.so.0.1.0
2aaad1032000-2aaad1034000 rwxp 00071000 08:07 738436 /usr/lib64/libdirectfb-1.1.so.0.1.0
2aaad1034000-2aaad1035000 rwxp 2aaad1034000 00:00 0
2aaad1035000-2aaad103e000 r-xp 00000000 08:07 740586 /usr/lib64/libfusion-1.1.so.0.1.0
2aaad103e000-2aaad123d000 ---p 00009000 08:07 740586 /usr/lib64/libfusion-1.1.so.0.1.0
2aaad123d000-2aaad123e000 r-xp 00008000 08:07 740586 /usr/lib64/libfusion-1.1.so.0.1.0
2aaad123e000-2aaad123f000 rwxp 00009000 08:07 740586 /usr/lib64/libfusion-1.1.so.0.1.0
2aaad123f000-2aaad1252000 r-xp 00000000 08:07 740582 /usr/lib64/libdirect-1.1.so.0.1.0
2aaad1252000-2aaad1452000 ---p 00013000 08:07 740582 /usr/lib64/libdirect-1.1.so.0.1.0
2aaad1452000-2aaad1453000 r-xp 00013000 08:07 740582 /usr/lib64/libdirect-1.1.so.0.1.0
2aaad1453000-2aaad1454000 rwxp 00014000 08:07 740582 /usr/lib64/libdirect-1.1.so.0.1.0
2aaad1454000-2aaad145a000 r-xp 00000000 08:07 739381 /usr/lib64/libglitz-glx.so.1.0.0
2aaad145a000-2aaad1659000 ---p 00006000 08:07 739381 /usr/lib64/libglitz-glx.so.1.0.0
2aaad1659000-2aaad165a000 r-xp 00005000 08:07 739381 /usr/lib64/libglitz-glx.so.1.0.0
2aaad165a000-2aaad165b000 rwxp 00006000 08:07 739381 /usr/lib64/libglitz-glx.so.1.0.0
2aaad165b000-2aaad167e000 r-xp 00000000 08:07 737551 /usr/lib64/libpng12.so.0.25.0
2aaad167e000-2aaad187e000 ---p 00023000 08:07 737551 /usr/lib64/libpng12.so.0.25.0
2aaad187e000-2aaad187f000 r-xp 00023000 08:07 737551 /usr/lib64/libpng12.so.0.25.0
2aaad187f000-2aaad1880000 rwxp 00024000 08:07 737551 /usr/lib64/libpng12.so.0.25.0
2aaad1880000-2aaad18b1000 r-xp 00000000 08:07 738139 /usr/lib64/libpixman-1.so.0.9.6
2aaad18b1000-2aaad1ab0000 ---p 00031000 08:07 738139 /usr/lib64/libpixman-1.so.0.9.6
2aaad1ab0000-2aaad1ab1000 r-xp 00030000 08:07 738139 /usr/lib64/libpixman-1.so.0.9.6
2aaad1ab1000-2aaad1ab2000 rwxp 00031000 08:07 738139 /usr/lib64/libpixman-1.so.0.9.6
2aaad1ab2000-2aaad1b9e000 r-xp 00000000 08:07 1079257 /usr/lib64/gcc/x86_64-pc-linux-gnu/4.2.3/libstdc++.so.6.0.9
2aaad1b9e000-2aaad1d9e000 ---p 000ec000 08:07 1079257 /usr/lib64/gcc/x86_64-pc-linux-gnu/4.2.3/libstdc++.so.6.0.9
2aaad1d9e000-2aaad1da5000 r-xp 000ec000 08:07 1079257 /usr/lib64/gcc/x86_64-pc-linux-gnu/4.2.3/libstdc++.so.6.0.9
2aaad1da5000-2aaad1da7000 rwxp 000f3000 08:07 1079257 /usr/lib64/gcc/x86_64-pc-linux-gnu/4.2.3/libstdc++.so.6.0.9
2aaad1da7000-2aaad1dba000 rwxp 2aaad1da7000 00:00 0
2aaad1dba000-2aaad1dc7000 r-xp 00000000 08:03 1191400 /lib64/libgcc_s.so.1
2aaad1dc7000-2aaad1fc6000 ---p 0000d000 08:03 1191400 /lib64/libgcc_s.so.1
2aaad1fc6000-2aaad1fc7000 r-xp 0000c000 08:03 1191400 /lib64/libgcc_s.so.1
2aaad1fc7000-2aaad1fc8000 rwxp 0000d000 08:03 1191400 /lib64/libgcc_s.so.1
2aaad1fc8000-2aaad20fe000 r-xp 00000000 08:07 740774 /usr/lib64/libxml2.so.2.6.31
2aaad20fe000-2aaad22fd000 ---p 00136000 08:07 740774 /usr/lib64/libxml2.so.2.6.31
2aaad22fd000-2aaad2305000 r-xp 00135000 08:07 740774 /usr/lib64/libxml2.so.2.6.31
2aaad2305000-2aaad2307000 rwxp 0013d000 08:07 740774 /usr/lib64/libxml2.so.2.6.31
2aaad2307000-2aaad2308000 rwxp 2aaad2307000 00:00 0
2aaad2308000-2aaad2330000 r-xp 00000000 08:07 740352 /usr/lib64/libglitz.so.1.0.0
2aaad2330000-2aaad2530000 ---p 00028000 08:07 740352 /usr/lib64/libglitz.so.1.0.0
2aaad2530000-2aaad2531000 r-xp 00028000 08:07 740352 /usr/lib64/libglitz.so.1.0.0
2aaad2531000-2aaad2532000 rwxp 00029000 08:07 740352 /usr/lib64/libglitz.so.1.0.0
2aaad2532000-2aaad25a6000 r-xp 00000000 08:07 768590 /usr/lib64/opengl/xorg-x11/lib/libGL.so.1.2
2aaad25a6000-2aaad27a6000 ---p 00074000 08:07 768590 /usr/lib64/opengl/xorg-x11/lib/libGL.so.1.2
2aaad27a6000-2aaad27ae000 r-xp 00074000 08:07 768590 /usr/lib64/opengl/xorg-x11/lib/libGL.so.1.2
2aaad27ae000-2aaad27b1000 rwxp 0007c000 08:07 768590 /usr/lib64/opengl/xorg-x11/lib/libGL.so.1.2
2aaad27b1000-2aaad27b3000 rwxp 2aaad27b1000 00:00 0
2aaad27b3000-2aaad27b8000 r-xp 00000000 08:07 740119 /usr/lib64/libXxf86vm.so.1.0.0
2aaad27b8000-2aaad29b7000 ---p 00005000 08:07 740119 /usr/lib64/libXxf86vm.so.1.0.0
2aaad29b7000-2aaad29b9000 rwxp 00004000 08:07 740119 /usr/lib64/libXxf86vm.so.1.0.0
2aaad29b9000-2aaad29c3000 r-xp 00000000 08:07 737718 /usr/lib64/libdrm.so.2.3.0
2aaad29c3000-2aaad2bc2000 ---p 0000a000 08:07 737718 /usr/lib64/libdrm.so.2.3.0
2aaad2bc2000-2aaad2bc3000 r-xp 00009000 08:07 737718 /usr/lib64/libdrm.so.2.3.0
2aaad2bc3000-2aaad2bc4000 rwxp 0000a000 08:07 737718 /usr/lib64/libdrm.so.2.3.0
2aaad2bc4000-2aaad2c24000 rwxs 00000000 00:08 851972 /SYSV00000000 (deleted)
2aaad2c29000-2aaad2e29000 rwxp 2aaad2c29000 00:00 0
2aaad2e29000-2aaad2e53000 r-xp 00000000 08:07 768661 /usr/lib64/gtk-2.0/2.10.0/engines/libqtcurve.so
2aaad2e53000-2aaad3053000 ---p 0002a000 08:07 768661 /usr/lib64/gtk-2.0/2.10.0/engines/libqtcurve.so
2aaad3053000-2aaad3054000 r-xp 0002a000 08:07 768661 /usr/lib64/gtk-2.0/2.10.0/engines/libqtcurve.so
2aaad3054000-2aaad3055000 rwxp 0002b000 08:07 768661 /usr/lib64/gtk-2.0/2.10.0/engines/libqtcurve.so
2aaad3055000-2aaad3056000 rwxp 2aaad3055000 00:00 0
2aaad3057000-2aaad305a000 r-xp 00000000 08:07 4447751 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
2aaad305a000-2aaad325a000 ---p 00003000 08:07 4447751 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
2aaad325a000-2aaad325b000 r-xp 00003000 08:07 4447751 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
2aaad325b000-2aaad325c000 rwxp 00004000 08:07 4447751 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
2aaad325c000-2aaad32bc000 rwxs 00000000 00:08 786434 /SYSV00000000 (deleted)
2aaad32bc000-2aaad32ca000 r-xs 000cf000 08:07 1065293 /usr/lib64/eclipse-3.3/plugins/org.eclipse.osgi_3.3.1.R33x_v 20070828.jar
2aaad32ca000-2aaad32dd000 r-xp 00000000 08:03 1191895 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnet.so
2aaad32dd000-2aaad33de000 ---p 00013000 08:03 1191895 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnet.so
2aaad33de000-2aaad33e1000 rwxp 00014000 08:03 1191895 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnet.so
2aaad33e1000-2aaad33e8000 r-xp 00000000 08:03 1191889 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnio.so
2aaad33e8000-2aaad34e7000 ---p 00007000 08:03 1191889 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnio.so
2aaad34e7000-2aaad34e9000 rwxp 00006000 08:03 1191889 /opt/sun-jdk-1.6.0.05/jre/lib/amd64/libnio.so
2aaad34e9000-2aaad34ec000 r-xs 00015000 08:07 1065263 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.preferenc es_3.2.100.v20070522.jar
2aaad34ec000-2aaad3573000 r-xs 00800000 08:07 1065305 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.ui_3.3.1.r331 _v20070906.jar
2aaad3573000-2aaad3583000 r-xs 000dd000 08:07 1065216 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde.core_3.3.1.v2 0070912-0800.jar
2aaad3583000-2aaad35a0000 r-xs 00433000 08:07 3881244 /usr/share/icu4j/lib/icu4j.jar
2aaad35a0000-2aaad35a2000 r-xs 00003000 08:07 1065230 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.runtime.comp atibility.auth_3.2.100.v20070502.jar
2aaad35a2000-2aaad35a6000 r-xs 00015000 08:07 1065210 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.navigator.reso urces_3.3.1.M20070831-2000.jar
2aaad35a6000-2aaad35a8000 r-xs 00005000 08:07 1065252 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.variables_3. 2.0.v20070426.jar
2aaad35a8000-2aaad35a9000 r-xs 00000000 08:07 1065260 /usr/lib64/eclipse-3.3/plugins/org.eclipse.update.core.linux _3.2.0.v20070615.jar
2aaad35a9000-2aaad35b4000 r-xs 0007b000 08:07 1065307 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde.ui.templates_ 3.3.0.v20070608-1300.jar
2aaad35b4000-2aaad35b6000 r-xs 00006000 08:07 1065266 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.http.serv let_1.0.1.R33x_v20070816.jar
2aaad35b6000-2aaad35b9000 r-xs 0002e000 08:07 4251535 /usr/share/jsch/lib/jsch.jar
2aaad35b9000-2aaad35bc000 r-xs 00014000 08:07 1065237 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.commands_3.3 .0.I20070605-0010.jar
2aaad35bc000-2aaad35c0000 r-xs 00020000 08:07 1065306 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.console_3.2.1. v20070824_r331.jar
2aaad35c0000-2aaad35c3000 r-xs 0000e000 08:07 1065238 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.views_3.2.101. M20070910-0800b.jar
2aaad35c3000-2aaad35ca000 r-xs 00030000 08:07 1065221 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.databinding_ 1.0.1.M20070822-0800.jar
2aaad35ca000-2aaad35cc000 r-xs 0000f000 08:07 1065281 /usr/lib64/eclipse-3.3/plugins/org.apache.lucene.analysis_1. 9.1.v200706181610.jar
2aaad35cc000-2aaad35d0000 r-xs 00022000 08:07 1065310 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.registry_ 3.3.1.R33x_v20070802.jar
2aaad35d0000-2aaad35d2000 r-xs 00015000 08:07 1065242 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ant.core_3.1.200. v20070522.jar
2aaad35d2000-2aaad35d3000 r-xs 00007000 08:07 1065253 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.http.regi stry_1.0.0.v20070608.jar
2aaad35d3000-2aaad35d5000 r-xs 0000b000 08:07 3959354 /usr/share/tomcat-servlet-api-2.4/lib/jsp-api.jar
2aaad35d5000-2aaad35de000 r-xs 0005f000 08:07 1065211 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ltk.ui.refactorin g_3.3.1.r331_v20070829.jar
2aaad35de000-2aaad35df000 r-xs 00002000 08:07 1065226 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.junit4.runtim e_1.0.100.v20070606-0010.jar
2aaad35df000-2aaad35e1000 r-xs 00013000 08:07 1065301 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.runtime.comp atibility_3.1.200.v20070502.jar
2aaad35e1000-2aaad35e2000 r-xs 00006000 08:07 1065294 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.net_1.0.1.r3 3x_20070709.jar
2aaad35e2000-2aaad35e5000 r-xs 00011000 08:07 1065241 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.app_1.0.1 .R33x_v20070828.jar
2aaad35e5000-2aaad35e6000 r-xs 00001000 08:07 1065220 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.jsp.jaspe r.registry_1.0.0.v20070607.jar
2aaad35e6000-2aaad35e9000 r-xs 00008000 08:07 1065292 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.core.manipula tion_1.1.0.v20070606-0010.jar
2aaad35e9000-2aaad362a000 r-xs 00348000 08:07 1065270 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde.ui_3.3.1.v200 70912-0800.jar
2aaad362a000-2aaad3631000 r-xs 0003e000 08:07 1065246 /usr/lib64/eclipse-3.3/plugins/org.eclipse.debug.core_3.3.1. v20070731_r331.jar
2aaad3631000-2aaad3633000 r-xs 00008000 08:07 1065217 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.filesystem_1 .1.0.v20070606.jar
2aaad3633000-2aaad3638000 r-xs 0001e000 08:07 1065231 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde.runtime_3.3.0 .v20070608-1300.jar
2aaad3638000-2aaad3639000 r-xs 00000000 08:07 1065291 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.boot_3.1.100 .v20060603.jar
2aaad3639000-2aaad363b000 r-xs 00005000 08:07 1065302 /usr/lib64/eclipse-3.3/plugins/org.eclipse.update.scheduler_ 3.2.100.v20070615.jar
2aaad363b000-2aaad363d000 r-xs 00002000 08:07 1065285 /usr/lib64/eclipse-3.3/plugins/org.eclipse.help.appserver_3. 1.200.v20070510.jar
2aaad363d000-2aaad3641000 r-xs 00016000 08:07 1065248 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.filebuffers_ 3.3.1.r331_v20070829.jar
2aaad3641000-2aaad3643000 r-xs 00007000 08:07 1065268 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.net_1.0.0.I200 70516.jar
2aaad3643000-2aaad365b000 r-xs 00112000 08:07 1065233 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.ui_3.3.1.r33 x_20070730.jar
2aaad365b000-2aaad3664000 r-xs 00051000 08:07 1065201 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.core_3.3.1.r 33x_20070807.jar
2aaad3664000-2aaad3667000 r-xs 00015000 08:07 3959339 /usr/share/tomcat-servlet-api-2.4/lib/servlet-api.jar
2aaad3667000-2aaad3668000 r-xs 00002000 08:07 1065251 /usr/lib64/eclipse-3.3/plugins/org.eclipse.cvs_1.0.0.v200706 06.jar
2aaad3668000-2aaad3672000 r-xs 0007e000 08:07 1065212 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.cvs.core_3.3 .1.r33x_20070724.jar
2aaad3672000-2aaad369c000 r-xs 001ca000 08:07 1065296 /usr/lib64/eclipse-3.3/plugins/org.eclipse.debug.ui_3.3.1.v2 0070731_r331.jar
2aaad369c000-2aaad369e000 r-xs 00010000 08:07 1065284 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.expressions_ 3.3.0.v20070606-0010.jar
2aaad369e000-2aaad36de000 r-xs 00330000 08:07 1065225 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.workbench_3.3. 1.M20070921-1200.jar
2aaad36de000-2aaad36f1000 r-xs 000d3000 08:07 1065276 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jface_3.3.1.M2007 0910-0800b.jar
2aaad36f1000-2aaad36f4000 r-xs 0000d000 08:07 1065299 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde_3.3.1.R33x_r2 0070920.jar
2aaad36f4000-2aaad36f8000 r-xs 0003b000 08:07 1065262 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.launching_3.3 .1.v20070808_r331.jar
2aaad36f8000-2aaad3702000 r-xs 00065000 08:07 1065219 /usr/lib64/eclipse-3.3/plugins/org.eclipse.search_3.3.1.r331 _v20070831-0800.jar
2aaad3702000-2aaad3713000 r-xs 000f8000 08:07 3877292 /usr/share/swt-3/lib/swt.jar
2aaad3713000-2aaad371d000 r-xs 00071000 08:07 1065275 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.workbench.text editor_3.3.1.r331_v20070806.jar
2aaad371d000-2aaad3720000 r-xs 0001e000 08:07 1065312 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.externaltools_ 3.1.200.v20070416.jar
2aaad3720000-2aaad3729000 r-xs 0005c000 08:07 1065223 /usr/lib64/eclipse-3.3/plugins/org.eclipse.help.ui_3.3.1.v20 070726_33x.jar
2aaad3729000-2aaad372e000 r-xs 0003d000 08:07 1065235 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.intro_3.2.101. v20070827_33x.jar
2aaad372e000-2aaad372f000 r-xs 00002000 08:07 1065239 /usr/lib64/eclipse-3.3/plugins/org.eclipse.pde.junit.runtime _3.3.0.v20070608-1300.jar
2aaad372f000-2aaad3731000 r-xs 0000b000 08:07 1065224 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.cvs.ssh_3.2. 100.I20061208.jar
2aaad3731000-2aaad3735000 r-xs 0001b000 08:07 1065264 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui_3.3.1.M2007091 0-0800b.jar
2aaad3735000-2aaad3736000 r-xs 00001000 08:07 1065244 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.filesystem.l inux.x86_64_1.0.100.v20070510.jar
2aaad3736000-2aaad3738000 r-xs 00009000 08:07 1065315 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.ide.applicatio n_1.0.0.I20070530-0100.jar
2aaad3738000-2aaad373d000 r-xs 00017000 08:07 1065261 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jface.databinding _1.1.1.M20070910-0800b.jar
2aaad373d000-2aaad373f000 r-xs 0000d000 08:07 1065304 /usr/lib64/eclipse-3.3/plugins/org.eclipse.osgi.util_3.1.200 .v20070605.jar
2aaad373f000-2aaad3746000 r-xs 0009f000 08:07 1065256 /usr/lib64/eclipse-3.3/plugins/org.mortbay.jetty_5.1.11.v200 706111724.jar
2aaad3746000-2aaad374d000 r-xs 0004e000 08:07 1065300 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.apt.core_3.3. 1.R33x_v20070831-0435.jar
2aaad374d000-2aaad374e000 r-xs 00004000 08:07 1065295 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jsch.core_1.0.0.I 20070426.jar
2aaad374e000-2aaad3758000 r-xs 00086000 08:07 1065308 /usr/lib64/eclipse-3.3/plugins/org.eclipse.update.core_3.2.1 01.R33x_v20070911.jar
2aaad3758000-2aaad375b000 r-xs 0001a000 08:07 1065214 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.resources.co mpatibility_3.2.100.v20070502.jar
2aaad375b000-2aaad375d000 r-xs 00003000 08:07 1065287 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.jsp.jaspe r_1.0.1.R33x_v20070816.jar
2aaad375d000-2aaad3760000 r-xs 00012000 08:07 1065243 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.views.properti es.tabbed_3.3.1.M20070831-0800.jar
2aaad3760000-2aaad3762000 r-xs 0000d000 08:07 1065247 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.apt.ui_3.3.1. R33x_v20070801-1930.jar
2aaad3762000-2aaad3768000 r-xs 00037000 08:07 1065228 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ltk.core.refactor ing_3.3.1.r331_v20070829.jar
2aaad3768000-2aaad376b000 r-xs 00019000 08:07 3959331 /usr/share/commons-el/lib/commons-el.jar
2aaad376b000-2aaad377c000 r-xs 000f1000 08:07 1065274 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ant.ui_3.2.200.v2 0070825_r331.jar
2aaad377c000-2aaad3784000 r-xs 0005f000 08:07 3958704 /usr/share/lucene-1.9/lib/lucene.jar
2aaad3784000-2aaad378b000 r-xs 00045000 08:07 1065257 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.cheatsheets_3. 3.0.v20070507.jar
2aaad378b000-2aaad378d000 r-xs 00011000 08:07 1065267 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.jobs_3.3.1.R 33x_v20070709.jar
2aaad378d000-2aaad378f000 r-xs 0000b000 08:07 4251653 /usr/share/commons-logging/lib/commons-logging.jar
2aaad378f000-2aaad37a0000 r-xs 000b6000 08:07 1065282 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jface.text_3.3.1. r331_v20070629.jar
2aaad37a0000-2aaad37a2000 r-xs 00008000 08:07 1065273 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt_3.3.0.v200706 07-1300.jar
2aaad37a2000-2aaad37a7000 r-xs 0003e000 08:07 1065272 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.forms_3.3.0.v2 0070511.jar
2aaad37a7000-2aaad37a9000 r-xs 00011000 08:07 1065227 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.contenttype_ 3.2.100.v20070319.jar
2aaad37a9000-2aaad37af000 r-xs 00035000 08:07 1065314 /usr/lib64/eclipse-3.3/plugins/org.eclipse.osgi.services_3.1 .200.v20070605.jar
2aaad37af000-2aaad37c0000 r-xs 0018a000 08:07 1065290 /usr/lib64/eclipse-3.3/plugins/org.apache.jasper_5.5.17.v200 706111724.jar
2aaad37c0000-2aaad37c5000 r-xs 00026000 08:07 1065215 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.browser_3.2.10 0.v20070524A.jar
2aaad37c5000-2aaad37c6000 r-xs 00002000 08:07 1065309 /usr/lib64/eclipse-3.3/plugins/org.eclipse.rcp_3.2.0.v200706 12.jar
2aaad37c6000-2aaad37cb000 r-xs 00046000 08:07 1065218 /usr/lib64/eclipse-3.3/plugins/org.eclipse.help.base_3.3.1.v 20070813_33x.jar
2aaad37cb000-2aaad37f1000 r-xs 003c0000 08:07 1065213 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.core_3.3.1.v_ 780_R33x.jar
2aaad37f1000-2aaad37f4000 r-xs 00014000 08:07 1065279 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.presentations. r21_3.2.100.I20070605-0010.jar
2aaad37f4000-2aaad3811000 r-xs 0015f000 08:07 1065208 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.cvs.ui_3.3.1 .r33x_20070807.jar
2aaad3811000-2aaad3812000 r-xs 00005000 08:07 1065280 /usr/lib64/eclipse-3.3/plugins/org.eclipse.team.cvs.ssh2_3.2 .100.I20070604.jar
2aaad3812000-2aaad381c000 r-xs 00074000 08:07 1065259 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.editors_3.3.1. r331_v20070629.jar
2aaad381c000-2aaad3826000 r-xs 00099000 08:07 1065245 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.resources_3. 3.0.v20070604.jar
2aaad3826000-2aaad3832000 r-xs 00092000 08:07 1065255 /usr/lib64/eclipse-3.3/plugins/org.eclipse.compare_3.3.1.r33 x_20070906.jar
2aaad3832000-2aaad3834000 r-xs 00007000 08:07 1065222 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.databinding. beans_1.0.1.M20070910-0800b.jar
2aaad3834000-2aaad383b000 r-xs 00042000 08:07 1065303 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.navigator_3.3. 2.M20071022-1600a.jar
2aaad383b000-2aaad383d000 r-xs 0000e000 08:07 1065324 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jsch.ui_1.0.1.r33 x_20070709.jar
2aaad383d000-2aaad3840000 r-xs 0001d000 08:07 1065283 /usr/lib64/eclipse-3.3/plugins/org.eclipse.help_3.3.1.v20070 726_33x.jar
2aaad3840000-2aaad384a000 r-xs 0006a000 08:07 1065286 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.junit_3.3.1.r 331_v20070829.jar
2aaad384a000-2aaad384f000 r-xs 00031000 08:07 1065240 /usr/lib64/eclipse-3.3/plugins/org.eclipse.text_3.3.0.v20070 606-0010.jar
2aaad384f000-2aaad3855000 r-xs 00066000 08:07 1065200 /usr/lib64/eclipse-3.3/plugins/org.eclipse.help.webapp_3.3.1 .v20070823_33x.jar
2aaad3855000-2aaad3872000 r-xs 0017e000 08:07 1065297 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.ide_3.3.1.M200 70910-0800b.jar
2aaad3872000-2aaad388b000 r-xs 00110000 08:07 1065258 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.debug.ui_3.2. 101.v20070718_r331.jar
2aaad388b000-2aaad388e000 r-xs 00009000 08:07 1065289 /usr/lib64/eclipse-3.3/plugins/org.eclipse.jdt.junit.runtime _3.3.0.v20070606-0010.jar
2aaad388e000-2aaad3890000 r-xs 00003000 08:07 1065313 /usr/lib64/eclipse-3.3/plugins/org.eclipse.equinox.http.jett y_1.0.1.R33x_v20070816.jar
2aaad3890000-2aaad389a000 r-xs 0006f000 08:07 1065298 /usr/lib64/eclipse-3.3/plugins/org.eclipse.update.ui_3.2.100 .v20070615.jar
2aaad389a000-2aaad3921000 r-xp 00000000 08:07 3929069 /usr/share/fonts/dejavu/DejaVuSans-Bold.ttf
2aaad3962000-2aaad5240000 rwxp 2aaad3962000 00:00 0
2aaad5240000-2aaad5241000 r-xs 00001000 08:07 1096025 /usr/lib64/eclipse-3.3/plugins/org.eclipse.core.runtime.comp atibility.registry_3.2.100.v20070316/runtime_registry_compat ibility.jar
2aaad5241000-2aaad546e000 rwxp 2aaad5241000 00:00 0
2aaad546e000-2aaad546f000 r-xs 00000000 08:07 1065205 /usr/lib64/eclipse-3.3/plugins/org.eclipse.ui.workbench.comp atibility_3.2.0.I20070319-0010/compatibility.jar
2aaad546f000-2aaad54b3000 r-xp 00000000 08:07 740402 /usr/lib64/libswt-gtk-3347.so
2aaad54b3000-2aaad56b2000 ---p 00044000 08:07 740402 /usr/lib64/libswt-gtk-3347.so
2aaad56b2000-2aaad56b3000 r-xp 00043000 08:07 740402 /usr/lib64/libswt-gtk-3347.so
2aaad56b3000-2aaad56b7000 rwxp 00044000 08:07 740402 /usr/lib64/libswt-gtk-3347.so
2aaad56b7000-2aaad56b8000 rwxp 2aaad56b7000 00:00 0
2aaad56b8000-2aaad5725000 r-xp 00000000 08:07 740779 /usr/lib64/libswt-pi-gtk-3347.so
2aaad5725000-2aaad5924000 ---p 0006d000 08:07 740779 /usr/lib64/libswt-pi-gtk-3347.so
2aaad5924000-2aaad5925000 r-xp 0006c000 08:07 740779 /usr/lib64/libswt-pi-gtk-3347.so
2aaad5925000-2aaad5927000 rwxp 0006d000 08:07 740779 /usr/lib64/libswt-pi-gtk-3347.so
2aaad5927000-2aaad5929000 rwxp 2aaad5927000 00:00 0
2aaad5959000-2aaad595d000 r-xp 00000000 08:07 741063 /usr/lib64/libgthread-2.0.so.0.1600.1
2aaad595d000-2aaad5b5c000 ---p 00004000 08:07 741063 /usr/lib64/libgthread-2.0.so.0.1600.1
2aaad5b5c000-2aaad5b5d000 r-xp 00003000 08:07 741063 /usr/lib64/libgthread-2.0.so.0.1600.1
2aaad5b5d000-2aaad5b5e000 rwxp 00004000 08:07 741063 /usr/lib64/libgthread-2.0.so.0.1600.1
2aaad5b5e000-2aaad5b63000 r-xp 00000000 08:07 737658 /usr/lib64/libXtst.so.6.1.0
2aaad5b63000-2aaad5d62000 ---p 00005000 08:07 737658 /usr/lib64/libXtst.so.6.1.0
2aaad5d62000-2aaad5d64000 rwxp 00004000 08:07 737658 /usr/lib64/libXtst.so.6.1.0
2aaad5d64000-2aaad5d66000 r-xp 00000000 08:07 1226925 /usr/lib64/eclipse-3.3/configuration/org.eclipse.osgi/bundle s/74/1/.cp/os/linux/x86_64/liblocalfile_1_0_0.so
2aaad5d66000-2aaad5f65000 ---p 00002000 08:07 1226925 /usr/lib64/eclipse-3.3/configuration/org.eclipse.osgi/bundle s/74/1/.cp/os/linux/x86_64/liblocalfile_1_0_0.so
2aaad5f65000-2aaad5f66000 r-xp 00001000 08:07 1226925 /usr/lib64/eclipse-3.3/configuration/org.eclipse.osgi/bundle s/74/1/.cp/os/linux/x86_64/liblocalfile_1_0_0.so
2aaad5f66000-2aaad5f67000 rwxp 00002000 08:07 1226925 /usr/lib64/eclipse-3.3/configuration/org.eclipse.osgi/bundle s/74/1/.cp/os/linux/x86_64/liblocalfile_1_0_0.so
2aaad5f67000-2aaad5f98000 r-xs 00000000 08:06 392200 /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-x86-6 4.cache-2
2aaad5f98000-2aaad5fc9000 r-xs 00000000 08:06 392233 /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-x86-6 4.cache-2
2aaad5fc9000-2aaad5fdf000 r-xs 00000000 08:06 387857 /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-x86-6 4.cache-2
2aaad5fdf000-2aaad5fe3000 r-xs 00000000 08:06 391117 /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86-6 4.cache-2
2aaad5fe3000-2aaad5ffc000 r-xs 00000000 08:06 392201 /var/cache/fontconfig/4b5cf4386f1cde02a336ba961b4ac82d-x86-6 4.cache-2
2aaad5ffc000-2aaad6005000 r-xs 00000000 08:06 393122 /var/cache/fontconfig/12b26b760a24f8b4feb03ad48a333a72-x86-6 4.cache-2
2aaad6005000-2aaad6009000 r-xs 00000000 08:06 389647 /var/cache/fontconfig/f229987021d35643e031bb32719a07d5-x86-6 4.cache-2
2aaad6009000-2aaad600c000 r-xs 00000000 08:06 388045 /var/cache/fontconfig/d722f191fc173fb8c13c8ea6f285de40-x86-6 4.cache-2
2aaad600c000-2aaad601f000 r-xs 00000000 08:06 389723 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86-6 4.cache-2
2aaad601f000-2aaad6027000 r-xs 00000000 08:06 387484 /var/cache/fontconfig/4460665c0f3e88acdd4c85aa2f409b99-x86-6 4.cache-2
2aaad6027000-2aaad602a000 r-xs 00000000 08:06 389747 /var/cache/fontconfig/76fa4b957c916922374347f144bde9da-x86-6 4.cache-2
2aaad602a000-2aaad602c000 r-xs 00000000 08:06 389758 /var/cache/fontconfig/4835c57e1100af85fc034b1656dee950-x86-6 4.cache-2
2aaad602c000-2aaad6035000 r-xs 00000000 08:06 389762 /var/cache/fontconfig/acc285bc1956c3c4bc7afb41d537a85a-x86-6 4.cache-2
2aaad6035000-2aaad603d000 r-xs 00000000 08:06 393121 /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-x86-6 4.cache-2
2aaad603d000-2aaad60cf000 r-xp 00000000 08:07 3929075 /usr/share/fonts/dejavu/DejaVuSans.ttf
2aaad60cf000-2aaad60d1000 r-xp 00000000 08:07 852099 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
2aaad60d1000-2aaad62d0000 ---p 00002000 08:07 852099 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
2aaad62d0000-2aaad62d1000 r-xp 00001000 08:07 852099 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
2aaad62d1000-2aaad62d2000 rwxp 00002000 08:07 852099 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
2aaad62d2000-2aaad62d9000 r-xs 00110000 08:03 1142515 /opt/sun-jdk-1.6.0.05/jre/lib/resources.jar
2aaad62d9000-2aaad64c4000 rwxp 2aaad62d9000 00:00 0
2aaad64c4000-2aaad64cb000 r-xp 00000000 08:07 740404 /usr/lib64/libswt-atk-gtk-3347.so
2aaad64cb000-2aaad66ca000 ---p 00007000 08:07 740404 /usr/lib64/libswt-atk-gtk-3347.so
2aaad66ca000-2aaad66cb000 r-xp 00006000 08:07 740404 /usr/lib64/libswt-atk-gtk-3347.so
2aaad66cb000-2aaad66cc000 rwxp 00007000 08:07 740404 /usr/lib64/libswt-atk-gtk-3347.so
2aaad66cc000-2aaad66d9000 r-xp 00000000 08:07 740423 /usr/lib64/libswt-cairo-gtk-3347.so
2aaad66d9000-2aaad68d8000 ---p 0000d000 08:07 740423 /usr/lib64/libswt-cairo-gtk-3347.so
2aaad68d8000-2aaad68d9000 r-xp 0000c000 08:07 740423 /usr/lib64/libswt-cairo-gtk-3347.so
2aaad68d9000-2aaad68da000 rwxp 0000d000 08:07 740423 /usr/lib64/libswt-cairo-gtk-3347.so
2aaad68da000-2aaad6d79000 rwxp 2aaad68da000 00:00 0
2aaad6d79000-2aaad6df4000 r-xp 00000000 08:07 3929065 /usr/share/fonts/dejavu/DejaVuSans-Oblique.ttf
2aaad6df4000-2aaad6e6f000 r-xp 00000000 08:07 3929067 /usr/share/fonts/dejavu/DejaVuSans-BoldOblique.ttf
2aaad7053000-2aaad7453000 rwxp 2aaad7053000 00:00 0
2aaad7453000-2aaad7457000 r-xp 00000000 08:07 343402 /usr/lib64/gtk-2.0/2.10.0/printbackends/libprintbackend-file .so
2aaad7457000-2aaad7656000 ---p 00004000 08:07 343402 /usr/lib64/gtk-2.0/2.10.0/printbackends/libprintbackend-file .so
2aaad7656000-2aaad7657000 r-xp 00003000 08:07 343402 /usr/lib64/gtk-2.0/2.10.0/printbackends/libprintbackend-file .so
2aaad7657000-2aaad7658000 rwxp 000
| Re: JVM crash on editor view opening [message #326687 is a reply to message #326640] |
Fri, 28 March 2008 10:11   |
Hi Andrew,
Long shot: Is your MALLOC_CHECK_ environment variable set to 2? And if so,
does changing its value to 0 help?
Your attached dump does not contain anything too helpful, so all I can
suggest is to try a recent 3.4-stream build like
http://download.eclipse.org/eclipse/downloads/drops/I2008032 7-2251/index.php,
and if this still fails then log a report with SWT (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT ).
Grant
"Andrew Gaydenko" <a@gaydenko.com> wrote in message
news:fsfsbe$tkq$1@build.eclipse.org...
> Hi!
have
> Have tried:
> - clean reinstall,
> Please, help!
| Re: JVM crash on editor view opening [message #326700 is a reply to message #326640] |
Fri, 28 March 2008 23:28  |
Andrew Gaydenko wrote:
> Hi!
> have tried to find appropriate cases in bugs and via googling without
> success. Eclipse tried are 3.3.1 and 3.3.1.1, x86_64 arch. Crash file is
> attached.
Thanks to all for suggestions! I have found SWT to be runtime-incompatible
with gtk+-2.12.9. After downgrading to 2.12.8 the problem has gone.
Sorry for noise.
Current Time: Mon Nov 24 19:55:05 EST 2025
Powered by FUDForum. Page generated in 0.04160 seconds
