Home » Eclipse Projects » Eclipse Platform » SafeRunnerDialog and modality
SafeRunnerDialog and modality [message #326625] Wed, 26 March 2008 12:05 Go to next message
In a preference page, I have this code to show possible exceptions to the
end user:
SafeRunnable.run(new SafeRunnable() {
public void run() throws Exception {
The preference page is inside the preferences dialog, which is modal.
The problem is that the SafeRunnableDialog appears disabled and behind the
preferences dialog.
The cause is probably that the parent of the notifying dialog is the mian
workbench window, instead of the preferences dialog.
I'm using Eclipse 3.3.2, Java 1.6 and Windows XP.
It's impossible for me to solve this from my plugin, as the
SafeRunnableDialog is not public, unless I duplicate all the code.
If accessible, maybe I could try SafeRunnableDialog.configureShell()
Thanks in advance for any help.
Re: SafeRunnerDialog and modality [message #326649 is a reply to message #326625] Thu, 27 March 2008 08:47 Go to previous messageGo to next message
Is there any better alternative to show exceptions to the end user in a
modal dialog?
> end user:
> preferences dialog.
Re: SafeRunnerDialog and modality [message #326892 is a reply to message #326649] Wed, 02 April 2008 12:56 Go to previous message
Try StatusManager.getManager().handle(status, StatusManager.SHOW). Usually,
it is not a good idea to open a modal dialog (error dialog or not) from deep
down in your code, because this will run the event loop and therefore any
asyncExecs that may be queued up. These asyncExecs could then change your
environment in drastic ways - for example, think about the case where the
update manager has finished installing new plug-ins and prompts you to
restart the workbench.
Boris
"David Perez" <craquerpro@yahoo.es> wrote in message
news:cd61b897bc7575fa38b10845143a5c8d$1@www.eclipse.org...
> modal dialog?
>> end user:
Previous Topic:Trouble with: "org.osgi.framework.BundleException: The activator X.y for bundle X is invalid&qu
Next Topic:Search step-by-step tutorial for writing web service (and deploy to AppServer)
Current Time: Sat Jul 26 10:03:22 EDT 2025
Powered by FUDForum. Page generated in 0.03968 seconds
