Re: No tooltips for content assist proposals on Linux platform. Yes on WINDOWS XP [message #326665 is a reply to message #326628] |
Thu, 27 March 2008 15:50   |
AL wrote:
> Eric Rizzo wrote:
>> AL wrote:
>>> Hi,
>>> I am using the released version of Eclipse 3.3.2. On WINDOWS XP,
>>> cursoring over a content assist proposal item, a tooltip is shown.
>>> But not on Linux platform. I use Ubuntu. Thanks.
>> First thing is to make sure you are not running Eclipse on gcj -
>> search to find many (way too many) threads in this and the newcomer
>> groups for the details.
> None that I found. I searched "tooltip", "content assist", and "gcj."
> If you have the thread's subject or some keywords, I can search. Thx
It should be easy to find the relavant threads, but gcj is just too
common a term, I guess.
The gist is that running Eclipse on gcj has frequently been the root of
many linux users' Eclipse problems - lots of bizarre behaviors that
ended up being resolved by forcing Eclipse to use the Sun JVM.
You can use Help > About Eclipse > Configuration Details to check the
java.vendor and java.version of the JVM Eclipse is running in.
If it is gcj, force Eclipse to a Sun JVM installation by following the
instructions on this wiki page: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
Re: No tooltips for content assist proposals on Linux platform. Yes on WINDOWS XP [message #326747 is a reply to message #326704] |
Mon, 31 March 2008 10:29  |
AL wrote:
> Tom Schindl wrote:
>> Which content-assistent are you talking about? The one from the
>> Java-Editor or are you really talking about Table/TreeItems. If it is
>> Table/Tree then you can use JFace to show tooltips (native/emulated).
> Java/Editor, basically ContentAssist in the jface text framework.
Is the Javadoc displayed in the Javadoc view? Any log entries?
Dani
>> AL schrieb:
>>>> Are you referring to the tooltip that shows a long item's full text
>>>> when you
>>>> hover over its visible portion? If so then you're seeing a difference
>>>> between the native Table controls. On win32 these tooltips are
>>>> created
>>>> automatically for items that are longer than their parent shell,
>>>> but on gtk
>>>> these tooltips are not auto-created. You should see the same
>>>> difference if
>>>> you hover over long items in the Package Explorer view.
>>>> If this is not what you were referring to then you'll need to
>>>> clarify here.
>>>> Grant
>>> U answered it :-) How do I make the tooltip show up for content
>>> assist proposals in the table?
FUDForum. Page generated in 0.06262 seconds
