Home » Eclipse Projects » Eclipse Platform » JFace Treeviewer refresh collapses the tree nodes
JFace Treeviewer refresh collapses the tree nodes [message #326557] Tue, 25 March 2008 06:42 Go to next message
Originally posted by: chandra.mayamuthu.gmail.com
Hi All,
I have a problem on refreshing the tree while sorting. The previous
states(expand and collapse) of the tree nodes are not restored properly
after refresh. The refresh method call collapses the tree unconditionally.
Please help me solve this issue
Chandra M
Re: JFace Treeviewer refresh collapses the tree nodes [message #326563 is a reply to message #326557] Tue, 25 March 2008 07:10 Go to previous messageGo to next message
You could try using IResource.refreshLocal(int depth, IProgressMonitor
monitor) on the project/folder/file individually.
"Chandra " <chandra.mayamuthu@gmail.com> wrote in message
news:7a5f917ff3e070939332f782b3e1645a$1@www.eclipse.org...
> Hi All,
> Chandra M
Re: JFace Treeviewer refresh collapses the tree nodes [message #326568 is a reply to message #326563] Tue, 25 March 2008 08:44 Go to previous messageGo to next message
--------------000803020608050705000000
Rahul,
Somehow I don't think this relates to the original question about
refreshing a tree view as opposed to refreshing the workspace.
Chandra,
In my experience, refresh would only collapse the tree if the object has
disappeared. But then I haven't tried sorting. There are more fine
grained methods like add/remove that you might use to refresh the view
if you know specifically what's changed...
>> Hi All,
>> Thanks,
>> Chandra M
<html>
<head>
</head>
Rahul,<br>
<br>
refreshing a tree view as opposed to refreshing the workspace.<br>
<br>
Chandra,<br>
<br>
has disappeared.&nbsp; But then I haven't tried sorting.&nbsp; There are more
fine grained methods like add/remove that you might use to refresh the
view if you know specifically what's changed...<br>
<br>
<br>
Rahul Kamdar wrote:
<blockquote cite="mid:fsamis$an5$1@build.eclipse.org" type="cite">
<pre wrap="">You could try using IResource.refreshLocal(int depth, IProgressMonitor
"Chandra " <a class="moz-txt-link-rfc2396E" href="mailto:chandra.mayamuthu@gmail.com">&lt;chandra.mayamuthu@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:7a5f917ff3e070939332f782b3e1645a$1@www.eclipse.org">news:7a5f917ff3e070939332f782b3e1645a$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi All,
Chandra M
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000803020608050705000000--
Re: JFace Treeviewer refresh collapses the tree nodes [message #326577 is a reply to message #326557] Tue, 25 March 2008 11:54 Go to previous messageGo to next message
We have an open bug about this, if you refer to the fact that refresh() will
not preserve the complete expansion state of the tree when the sort order
changes.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=113675, it explains how to
work around this bug.
Boris
> Hi All,
> Chandra M
Re: JFace Treeviewer refresh collapses the tree nodes [message #326642 is a reply to message #326577] Thu, 27 March 2008 06:56 Go to previous message
Thanks Boris
Previous Topic:createInitialLayout method not called when initializing a new perspective
Next Topic:Tooltips possible for EMF objects in properties view?
Current Time: Fri Nov 21 01:22:48 EST 2025
Powered by FUDForum. Page generated in 0.03892 seconds
