| SWT TableColumn.pack doesn't make columns wider [message #326400] | Tue, 18 March 2008 15:02  |  |
| Eclipse User  |  |  |  |  | I am running on Windows XP Professional 2002 Service Pack 2.
 I have an SWT table that is populated by a TableViewer.  The table has one
 column.  After the contents of the column is updated, the code calls
 TableColumn.pack to resize the column so the entire text of the item
 appears in the column.  The first time the column is packed everything
 works mostly ok.  The column size is a bit too short to accommodate the
 entire text of the longest item. (I would like to know how to fix this one
 but my other problem is more pressing.)
 However, when a new wider item is added to the top of the table where a
 narrower item used to be, pack doesn't make the column any wider.   The
 column stays the same width.  I tried adding a header and double clicking
 on the header would only make the column smaller.  It would not increase
 the width.
 I stepped into the TableColumn.pack method and saw that when it went to
 Windows to get the width of the new item, it returned the narrower width
 of the item that used to be there.
 It seems as if the underlying windows GUI widget still thinks it has the
 old text.  Is there any method that I can call before pack to refresh the
 widths of the underlying windows GUI widgets before I call pack.
 Here's the code to create the table and viewers.
 * Table for editing this path.
 Table                   pathTable;
 * Viewer that populate the path table.
 TableViewer             pathTableViewer;
 * Column containing directories in the path.
 TableColumn             dirColumn;
 pathTable = toolkit.createTable(tableComp, SWT.SINGLE);
 pathTable.setLinesVisible(true);
 pathTableViewer = new TableViewer(pathTable);
 pathTableViewer.setContentProvider(new
 ResolvedPathContentProvider(resolver));
 pathTableViewer.setLabelProvider(new LabelProvider());
 dirColumn = new TableColumn(pathTable,SWT.LEFT);
 dirColumn.setText("Directory");
 dirColumn.setResizable(true);
 Thanks very much for your help!
 Carolyn
FUDForum. Page generated in 0.05799 seconds
