Home » Eclipse Projects » Eclipse Platform » workspace.findFilesForLocation ?
workspace.findFilesForLocation ? [message #326363] Mon, 17 March 2008 16:41 Go to next message
I need to find files by filename, eg given "foo.java" I want all files
in the workspace that have <path>/foo.java.
This looks hopeful:
public IFile[] findFilesForLocation(IPath location)
Returns the handles of all files that are mapped to the given path in
the local file system. Returns an empty array if there are none. The
path should be absolute; a relative path will be treated as absolute.
The path segments need not be valid names. The resulting files may not
currently exist.
But it does not work, and the phrase "relative path will be treated as
absolute" is not at all helpful. What does that mean? "Apples will be
treated as oranges": do I get orange juice or apple juice?
If this function does not lookup files like I want, can anyone suggest a
function that might to it? Otherwise I have to sweep the workstation for
file names and create/maintain a table I guess.
John.
Re: workspace.findFilesForLocation ? [message #326364 is a reply to message #326363] Mon, 17 March 2008 17:14 Go to previous messageGo to next message
John,
It means that a path a/b will be treated as /a/b (or as c:/a/b on
windows). You could use an IResourceVisitor if you want to visit all
resource that match a particular path pattern. Of course a visitor and
this method only search the workspace itself, not your whole file system.
> This looks hopeful:
> currently exist.
> a function that might to it? Otherwise I have to sweep the workstation
> for file names and create/maintain a table I guess.
> John.
Re: workspace.findFilesForLocation ? [message #326391 is a reply to message #326364] Tue, 18 March 2008 13:16 Go to previous message
Thanks Ed for saving me some time. I implemented the visitor to build a
lookup table and hope my IResourceChangeListener will keep it up to date.
John.
Ed Merks wrote:
> John,
>> This looks hopeful:
>> currently exist.
>> Thanks,
>> John.
Previous Topic:Synchronously delete project
Next Topic:How to connect the debug console to my debugger ???
Current Time: Wed Nov 05 04:25:07 EST 2025
Powered by FUDForum. Page generated in 0.03228 seconds
