| Deleting directory fails in the 3.4M5 test suite on Windows Vista ia32. [message #326355] |
Mon, 17 March 2008 11:31 |
Hi!
I don't know if this is the right forum for these kind of problems?
I have a problem with the Eclipse 34M5 test framework, Deleting directory
A Test Framework bug occur in Eclipse 3.4M5 on Windows Vista ia32.
After the UI test suite is done, ANT tries to remove the test-eclipse
work folder, this will fail cause two old java processes are still holding
on to it. The ANT target setup-zip will fail and the next plugin-target
will fail cause the test framework will not be installed properly.
The Milestone test was tested and failed with both JRockit and Sun SDK
1.5.0_14.
The workaround for this problem is to remove the test suite from test.xml
and then run it as a separate test: edit test.xml <!-- antcall target="ui"
This is the error messages from cmd:
genResults:
[copy] Copying 1 file to D:\tests\eclipse-testing_34M5\results\xml
[style] Warning: the task name <style> is deprecated. Use <xslt>
instead.
[style] Transforming into D:\tests\eclipse-testing_34M5\results\html
[style] Processing
D:\tests\eclipse-testing_34M5\results\xml\org.eclipse.ui.
tests_win32.win32.x86.xml to
D:\tests\eclipse-testing_34M5\results\html\org.ecli
pse.ui.tests_win32.win32.x86.html
[style] Loading stylesheet
D:\tests\eclipse-testing_34M5\test-eclipse\eclips
e\plugins\org.eclipse.test\JUNIT.XSL
antui:
junit:
setRuntimeArchive:
init:
setup:
setup-zip:
[delete] Deleting directory D:\tests\eclipse-testing_34M5\test-eclipse
BUILD FAILED
D:\tests\eclipse-testing_34M5\test.xml:296: The following error occurred
while e
xecuting this line:
D:\tests\eclipse-testing_34M5\test.xml:266: The following error occurred
while e
xecuting this line:
D:\tests\eclipse-testing_34M5\test.xml:275: The following error occurred
while e
xecuting this line:
D:\tests\eclipse-testing_34M5\test.xml:37: The following error occurred
while ex
ecuting this line:
D:\tests\eclipse-testing_34M5\test.xml:44: Unable to delete directory
D:\tests\e
Total time: 39 minutes 31 seconds
Should I bug report this?
Rasmus Tehler
FUDForum. Page generated in 0.04196 seconds
