Home » Eclipse Projects » Eclipse Platform » Synchronously delete project
Synchronously delete project [message #326354] Mon, 17 March 2008 11:24 Go to next message
Hello folks,
during running a JUnit Test (where I create test projects to work on
during the tests) I am getting a ResourceException that a project already
exists because the deletion is not finished yet from the last tearDown()
method invocation.
Is the IResource.delete method returning after the resource (and its
children) are deleted or is it deleting the IResource asynchronously in a
seperate Thread?
If it is done in another thread how can I know when and if the resource is
really deleted?
Re: Synchronously delete project [message #326358 is a reply to message #326354] Mon, 17 March 2008 12:51 Go to previous messageGo to next message
Marko,
You're sure the teardown didn't fail? I think delete should be
synchronous...
Marko T. wrote:
> Hello folks,
> already exists because the deletion is not finished yet from the last
> tearDown() method invocation.
> in a seperate Thread?
> resource is really deleted?
Re: Synchronously delete project [message #326360 is a reply to message #326354] Mon, 17 March 2008 14:40 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Marko T." <Marko.Tomljenovic@de.bosch.com> wrote in message
news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org...
> Hello folks,
> method invocation.
Hi, Marko. I've seen that happen quite a lot. I finally gave up trying to
figure it out, and just tweaked my test code so that every project gets a
unique name (based on incrementing a counter, e.g., TestProject0001,
TestProject0002...).
Re: Synchronously delete project [message #326361 is a reply to message #326360] Mon, 17 March 2008 15:24 Go to previous messageGo to next message
--------------010903030104010002060604
Walter,
I wonder if there are underlying OS file system delays involved...
>> Hello folks,
>> method invocation.
<html>
<head>
</head>
Walter,<br>
<br>
I wonder if there are underlying OS file system delays involved...<br>
&nbsp;<br>
<br>
<blockquote cite="mid:frmduc$vu7$1@build.eclipse.org" type="cite">
<pre wrap="">"Marko T." <a class="moz-txt-link-rfc2396E" href="mailto:Marko.Tomljenovic@de.bosch.com">&lt;Marko.Tomljenovic@de.bosch.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org">news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello folks,
method invocation.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010903030104010002060604--
Re: Synchronously delete project [message #326389 is a reply to message #326361] Tue, 18 March 2008 12:44 Go to previous message
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:frmgib$olr$1@build.eclipse.org...
It may possibly also have to do with the Java indexer thread?
Previous Topic:Remove filter input from Wizard
Next Topic:workspace.findFilesForLocation ?
Current Time: Wed Nov 12 18:25:48 EST 2025
Powered by FUDForum. Page generated in 0.03529 seconds
