Home » Eclipse Projects » Eclipse Platform » Table Viewer Vs Nebula Grid Viewer
Table Viewer Vs Nebula Grid Viewer [message #326351] Mon, 17 March 2008 10:01 Go to next message
In our RCP application, we already have implmented Nebula grid viewer. As
it is still in Alpha stage, we thought we will hang on to the stable
Eclipse 3.3's Table Viewer. For that I have to make sure that all
features(we have implemented with Nebula grid viewer's help) provided in
nebula grid viewer is available in Table Viewer.
So, I just need to know, is cell selection possible in Table Viewer as in
Grid table viewer?
One more thing I found in Table Viewer is that, I just cant set the
visible state of a column in Table Viewer as in Nebuila grid viewer, which
looks curious on navigation thorugh hidden columns! And also the column
count will always be the same with or without hidden columns! Isn't it?
Supreetha
Re: Table Viewer Vs Nebula Grid Viewer [message #326365 is a reply to message #326351] Mon, 17 March 2008 17:27 Go to previous messageGo to next message
Supreetha H R schrieb:
> Hello,
> As it is still in Alpha stage, we thought we will hang on to the stable
> in Grid table viewer?
Yes. See
http://wiki.eclipse.org/JFaceSnippets#Snippet026TreeViewerTa bEditing
> which looks curious on navigation thorugh hidden columns! And also the
> column count will always be the same with or without hidden columns!
> Isn't it?
Well this is a limitation you'll be facing in 3.3 code base but it is
gone in 3.4.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Table Viewer Vs Nebula Grid Viewer [message #326367 is a reply to message #326365] Tue, 18 March 2008 00:05 Go to previous messageGo to next message
Hello Tom,
Thanks for the reply... Sorry, i missed to ask whether multi cell
selection is possible in table Viewer. We are providing cut/copy/paste
operations in grid, and user can select single cell or multi cells in a
column or from various columns and cut/copy the contents from them. So is
this feature supported in 3.3 Table Viewer?
Supreetha
Re: Table Viewer Vs Nebula Grid Viewer [message #326378 is a reply to message #326367] Tue, 18 March 2008 09:59 Go to previous message
> Hello Tom,
> is this feature supported in 3.3 Table Viewer?
No not yet it was on my list for 3.4 but I failed because of Time
constraints.
Tom
Previous Topic:Plugin.getDefault().getDescriptor().getInstallURL() is deprecated
Next Topic:how to add formatted text in a table cell.
Current Time: Wed Dec 03 06:02:32 EST 2025
Powered by FUDForum. Page generated in 0.05446 seconds
