Home » Eclipse Projects » Eclipse Platform » Using IHandlerService in modal dialog
Using IHandlerService in modal dialog [message #326343] Sun, 16 March 2008 14:08 Go to next message
Originally posted by: newsgroups.atante.pl
I've used the following code in tabbed editor ()
IWorkbenchPartSite site =
PlatformUI.getWorkbench().getActivePage().getActivePart().ge tSite();
IHandlerService handlerService = (IHandlerService)
site.getService(IHandlerService.class);
to register my actions via:
IHandlerActivation activation = handlerService.activateHandler(
myAction.getActionDefinitionId(),
new ActionHandler(myAction)
and it works.
Now I want to do the same but for currently opened modal dialog window.
Which object should I use to register? What object will give me getService()
method?
Or is there any other approach?
Piotr Górny, Atante
http://www.atante.pl
Re: Using IHandlerService in modal dialog [message #326603 is a reply to message #326343] Wed, 26 March 2008 05:09 Go to previous messageGo to next message
Any suggestions would be appreciated :-)
Piotr Górny, Atante
Re: Using IHandlerService in modal dialog [message #326613 is a reply to message #326343] Wed, 26 March 2008 10:37 Go to previous message
> getService() method?
In 3.4 we were looking at support for creating your own site
(IServiceLocatorCreator) but it doesn't look like it's ready for prime time.
For a dialog, you would have to use:
PlatformUI.getWorkbench().getService(IHandlerService.class); This is
the global handler service.
You can activate your handler using this service, but you will have to
deactivate it yourself as your dialog closes.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:visibleWhen expression is not always evaluated when a custom source changes
Next Topic:save an IFigure to a gif
Current Time: Tue Jul 22 00:42:08 EDT 2025
Powered by FUDForum. Page generated in 0.02589 seconds
