Home » Eclipse Projects » Eclipse Platform » Handler, activeWhen, PropertyTester and multiple selections
Handler, activeWhen, PropertyTester and multiple selections [message #326332] Sat, 15 March 2008 05:02 Go to next message
Hi everyone!
I'm using a handler for a command that should be active when the
internal state of the selected item is 'unlocked'. 'unlocked' is a user
defined value and checked with a PropertyTester class.
My problem: when I selected multiple items and one of them has the state
'locked' the handler is not active. I understand: an and condition :-)
but can I change this to an or condition?
Thanks for reading and solutions!
Timo
Re: Handler, activeWhen, PropertyTester and multiple selections [message #326335 is a reply to message #326332] Sat, 15 March 2008 11:27 Go to previous messageGo to next message
> Hi everyone!
> I'm using a handler for a command that should be active when the internal
> state of the selected item is 'unlocked'. 'unlocked' is a user defined
> 'locked' the handler is not active. I understand: an and condition :-) but
<activeWhen>
<with variable="selection">
<iterate operator="or">
<test property="...your property..." value="unlocked"/>
</iterate>
</with>
</activeWhen>
should do.
Uwe Stieber
Re: Handler, activeWhen, PropertyTester and multiple selections [message #326500 is a reply to message #326335] Fri, 21 March 2008 03:52 Go to previous message
Thanks! That's it!
Uwe Stieber schrieb:
>> Hi everyone!
> <activeWhen>
> </iterate>
> </with>
> </activeWhen>
> should do.
> Uwe Stieber
Previous Topic:Unit Testing
Next Topic:relative path inside a plugin
Current Time: Sat Nov 22 18:08:26 EST 2025
Powered by FUDForum. Page generated in 0.04207 seconds
