Home » Eclipse Projects » Eclipse Platform » TableViewer isn't drawing its contents.
TableViewer isn't drawing its contents. [message #326325] Fri, 14 March 2008 16:06 Go to next message
I'm trying to set up a Search view. The result page is a minimally extended
AbstractTextSearchViewPage. The problem I'm having is to get the view to
display anything whatsoever.
It shows the title I gave the page.
It say "Searching..." while my search query is running.
It removes the "Searching..." when my search query finishes.
It queries the results returned by the query.
It queries my label provider, for each column of the table, and for each element.
And then it displays, nothing?
I've been able to turn the first line of the view to gray because I told the
underlying Table widget to setHeadersVisible(true). The rest of the view is
featureless white.
The viewer is querying the input, it is fetching the model elements, it is
even calling my ITableLabelProvider to get the text for each column for each
of the model elements. I have used the debugger to watch the viewer take
those text strings and stick them into TableItem's that go into the
TableColumns that I added to the Table widget that I got from the TableViewer
given to the configureTableViewer() interface of my AbstractTextSearchViewPage
implementation.
Why doesn't it paint the screen? I've tried calling refresh() of various
sorts and doing setRedraw(true) on the table but nothing makes it actually
draw something.
Gary
Re: TableViewer isn't drawing its contents. [message #326330 is a reply to message #326325] Sat, 15 March 2008 03:50 Go to previous messageGo to next message
Please provide a snippet we can run and reproduce.
Tom
> extended AbstractTextSearchViewPage. The problem I'm having is to get
> the view to display anything whatsoever.
> element.
> the underlying Table widget to setHeadersVisible(true). The rest of the
> view is featureless white.
> is even calling my ITableLabelProvider to get the text for each column
> for each of the model elements. I have used the debugger to watch the
> viewer take those text strings and stick them into TableItem's that go
> into the TableColumns that I added to the Table widget that I got from
> the TableViewer given to the configureTableViewer() interface of my
> AbstractTextSearchViewPage implementation.
> various sorts and doing setRedraw(true) on the table but nothing makes
> it actually draw something.
> Gary
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TableViewer isn't drawing its contents. [message #326359 is a reply to message #326330] Mon, 17 March 2008 14:24 Go to previous messageGo to next message
--------------000401080201040303070806
I've created a little plugin , called Cutdown, that is nothing more than a
contribution to the Search dialog. It adds a page called Ada Name Search. If
you run the plugin, bring up the Search dialog, click on the Ada Name Search
Page, and then click on Search, you'll get a Search view result page that has
the correct title, has the gray row for the column titles, but there is no
title text and no result text. There should be four lines of text. If you
set breakpoints in the MatchLabels label provider class you can watch Eclipse
ask for text for all of the columns for all four search results but nothing
gets displayed.
Gary
> Tom
>> each element.
>> told the underlying Table widget to setHeadersVisible(true). The rest
>> of the view is featureless white.
>> it is even calling my ITableLabelProvider to get the text for each
>> column for each of the model elements. I have used the debugger to
>> watch the viewer take those text strings and stick them into
>> TableItem's that go into the TableColumns that I added to the Table
>> widget that I got from the TableViewer given to the
>> implementation.
>> Gary
Content-Type: application/x-tar;
name="Cutdown-Search-Page.tar.gz"
Content-Disposition: inline;
filename="Cutdown-Search-Page.tar.gz"
H4sICAu23kcAA0N1dGRvd24tU2VhcmNoLVBhZ2UudGFyAO19bXAkx3UYVIlS PChRKS4nP1JO
3NxzlMUR2MXiUz4Ad8SBuDsccQB4wPH4dT7Ozvbujm52Zm8+gMORZzOhLFOS 48ipsi3TtKzQ
kspS2RGr4rislH9EssuWXUriiqOkXHLKMSNSSkyXrYrilFNWmPded89Mz8fu 4g7AmSKmyMPO
zOvXX6/fd/cshUHD3XGqQwd4jY9Pjc/OTsPf8YnZ2XH8O16bmqK/8hqqjc/O zE7XZqfg93it
VgNwNn2QjVJX6AeGx9hQi9f7wHHPP4wGHe61JOe/0vXc93MzOIg6xmvj4zMz U0XzX5tIzP/k
7AzAT8xMzQyx8YNoTPp6m8///OmbHZttQ98s11ko1SrjJcYd021YTmuhdHnr 7Nj7SqdPDc9L
8niI+6ZndQMAPjV8bN4xOvyUJKH5Kt3BU9PtdLgTnJqvql/wUCLw8Xc1eVMP Lbux2eUm3Mi7
JShmOA18IOtwvVaFm7bV9Xnl/Y2gYroe/DC2DYLnXlQ5FDC8Voi1+uK2qt3P V9M1DFJlt8Er
Fw3HanI/OHNoNW6abd4x7ro++UAOMVQVhB4XoOJ3puINO2xZzhq9xHoJqABe mw0nXUT9hOqi
Wddo6F7T/9v9Uvzf98wD0wH2Iv8l/8dHR/L/EK7k/JsHpAsOPv+TEzMTNZj/ yanp2tH8H8aV
N/+LZmBtG4HrEU+/+zr66H8TU9MTqfU/A3RwpP8dxtU1zOtGizM593PDw1an 63oB02R80zB5
BaS4G3rwY6UDJZQUd725vCKhVemSFlFZrPuBZ5jB5RWhVmjgrt+yKk0PNJsd 17teORM6DZsv
uU7AbwbQluqJE8PsBNtqc2YoomSmbfg+MwHIc22fBfASqxqzHGaDhsbMXdPm UKw63A3rtmXK
AhFVM8DNnQY8SbWMPTM8fKxapeoUxpWHho9JNEAoAfxpWo5hs83AAw2Zbaxe Preydm3lIbbA
SnItleZiNH7b8HiDWQ4UdkwOuDxsBFfI4kZ15eAcg7LQ62Oy29BNaGRoAgg+ q0atiUqWR6Dd
x25jnaJY2XGdsQuwchuuOUJPHvQ5H3B2juNyCMr95mZEb8y2azWYKKmB0Swh OMyS5+74bPmm
yUnzwzYf88Mu9yqinIKEETgm2gZDGrQtf25fO+d277BvUHAvXYu64IS2PZfo K+BJdFX0THTt
EgdN2REEnaEbJmAe9AioCKaaJtaYvlocFO+mEdqBIJhjElNEd3lNMRxm4WJn jWi1syb8j9WL
F03LhrUZ0JOWtc0dKq9Wj8dtaMY2LCcjaMed6Bow8vRMrF75Uutdut7c7qU4 EXYy9agsFyrW
ofXb0uHOem5HEEk5WtOjohSNze3vUEslT/4/avlWsNgw1mB5XOI+kMwGjNWd KwO95f/UZK02
Fel/U9PwfmJ8pjZ9JP8P4xpI/pN974VOYHV4ZQPWRK7IF1rCtsV3YKQqK8s2 R5/EktuB5c7z
tYRUkU2SdCFwNWKyTrDhudtWY7DCW0bd5qtGndt7KLVXeKrkUboZBNrjgwPv EVCMq1Gkf+UV
OWvZQUENPjc8s42iEyVTJDi34GaTXiEG5AKDlL5oBGY+ifg7QWXzylbhu5Zn dNuW6QsVsxBs
x2oAp5ezMRjUkmuHHadIVd0ADWTFsYJIhid1T8tn8B+s/wYLXNaw/K5t7JKM 8og5+sxtMoMl
uSaTI5LVQvN5a0YlzQ48CKyuWFE+K14oqMIyuGSdBbWRBsDkRYoJKxfXXDm7 unju2uri4+uX
t67B7y2QiFjwNv1L/1SrY2ProQe6CBAYqsddi5vcr8QQSu9NTAZLXsAiDHg8 NxBwCFM1MLDb
bPoDA9vcaWWA1+votmRPXmX61UE65z78AjWP70Rw41dzKhNLUG9Z6MmnSk1M DOjCvl0JrEjS
eAnbQpFvE3SfFAE/EnJvFyeFAVE4PmhxpGkC/bvUSaJ51M4VPqLuCiO8guvg CnHUchFabcMI
DKi1CxUDzQLGOq4j1+cKa0Wiq9JfqeSJhUNMZYl+qsVCjxKUrMZbs9CQtmzL 8B/mu3P9IYEK
+0Mh+cVQMbhYc4mGKuVTNWAUh1DYSeInkpvQS5N0od3I5RmjkMVl0TkNGGek okCBqrI9j6Gg
q5JuUaLHNYyAod9xt0GU+sAIWoLjlGsjlcBd35QdKufVi8NSgNGOcWXKRje3 geoTo1c4wLIN
wNsXsQ/l9PBJBV+fy9vFWC5ju4uw6HPdA8uiGvXC9mTmIsb24Po29zxg4Gn8 kqUAfqlOFaIn
UxkZB9vw+DZC5nN0sdphWcIQ8w5UAs0HRqSYQSWndcPR7KSX4iEyrM2w2wVO 0bB3qauyKQnB
bApFU3EceFjiUmCW2I4FhWAOFDbBoohfIfvZcUMbuBFPLl7F6KAYjo9pgKrA 2JlQ2Lr8RmjY
EffrcGBjDWyN5fCbXZg5YPm7UMa29cYZzi5wzpOqnDHCgh1Xjn1UI80QPs9y 5Bvwr8X9UYWg
PsIMvXgPbu404HmSj4rhiZCZojVZCNUkdDqgdiMqVMyarTvQ1zKUhv5DX+uo znShKdB1cgmI
grbVages4ZoUqjTIU+IKumU+6WRNhZDUCFRgWR2GuwyjhG0vQ2frLjAW1zRh QhwgaajXQFEE
8gDmZgWROdcZLGfAGc11PWyxzq7P7WZf8SJtFU3XStkxSsMS5JnyR0WLMsct 1ds8Oi4IqoxG
NrBLp1URS3+UpZ8ka6mm+UXddW1uOJI8WVnyD2NUcZJ6T2EDS/wKJ7Ff58gY mjCF57gDNGfG
XOSSVBtg5He4beNfy2lYoH9CnWl0UkeC2VmEKfRdWClgRGLJRDWGfz21TBQ7 SqOTNI7LmZxT
Ub1iAmlBw9x3jOtQh+OCHu7A8gbMYLhquKwm0BVbEIpXekzwkmy1rmB0oXU7 g6w+ALImzAnv
h+h+bJhy6oGWFS/HkR6oqS/1AXDXDwJ3gmWgWgxaQDmB2pjrAVxPAafqkU0o lztGRZeyFUXj
nXrqDfTlve/NdAYviWUdTAJOohQ6JopHj/qVXSW9SysbPRrpqdpIkXEg3KNt +MC9GjzDP3py
C1RBVcmIV0ien6YHJB/5agBKH09RC2CFdShJUKEZnBATmGXhStzukdy6CptW TlKb6myatoqx
99SPNCkyfHiWnLS4HM4bSgSjzZlkqQk9I5LqqNp46DUI3EhYxiVJKIPo7iBc ENciFSzgtWcB
InTARIqUMlFZeSSrGLlOrkKUUjiUCoTyHkREw3X+UaBwwRRJ/Ylao5KeWMfy 2x2YLyyAMCQc
EEKX6cJCjUct0iGh+cBGlsVCY213BxHtGIBZDYIy9FGDVKrjQKqEFm5M++32 SZNIoz2uJqFf
kaxqMaiyUWiuIENRM1uWvo1tWZliL7X450R6rcMSQgUEZ1GSCr9p2qEPWiRQ D01sllgqKRRj
Y2shzqjfJq3ecZHJdbugh6I2ibiJqN0wUKS0A9ScZXa1XnyOICZ6QeCVzw3x KuRSiWJjtZxy
RXy1d2MkxlovIY4jt6SWpQzLqRFSsX/WtDw/EH4ewRRcEpwVnLfMVO5YoB52 PbeO1tBo4pcD
FqonpsIlLMKboU9CUk+wU1oCrxXrFF4adkKHjR05gLcLwHaK+xeDewju9QTH JYBXB72CdrcS
uJHPpCKXxpbLyp72Jo0D5rPD7l9g4z3mstNrLjuqW7GqMyYaHj3Y7yoljK0r SbLW6EEvBUkO
T2+5iizuEN0Ol9G7sKOIXUpAFA4kZ6nHefYyuUqloER5Glm2GNcQ4o1CJYwt G2abeSB05EoL
SPySwMxxRyTW2Ykkm8SgPEdMpvBpAzIuEVfUMBfKKgqCxW5VLSammcLZENs+ yTAN53EVxR9Q
mS2URoQkygnop+Ai+yOtIGJOvhpd3wXTDUQYqSPsuoMqQnuXxMmKfOhxAN3N cEAJawTSKeHH
XqwudRfXvy3G/wRM4olK3prS7c/bBzPkaODf7YjH7lDE9hYe8ZSlw06zUomd jIwPxbqBn7Hs
Va1+39r62tja6uZY7fv2edpy1iBOnghl5a8aCjX0tAOjhZJAk568UancEYDT 4DfzZnNJzJ5w
z+QwxkOj7p7DlEvp/UcpJu4Yzd2MEkgIqYySLEAnlimiuRRdk5z8eAIZsvkM wUeZV33H24d5
AZlQ7tE89HKz8ZN7t51FJGYui6y2d2QyIJODbKIQGSzPB4oxFig9hHPyDnEW qDSEc6oHThGk
wVmrA/ldxww6G81TKbiFouGhs1zD0RDJe8WIBVEexzYnJngOK1uL+WubeylP 6AAeDaEgHKLW
Fa+QJuWskLFGEWSZfYEZFw5wdMMDXSa0DS+rKoEVH3khKPSAhqAy62MfxhXp ZWAyKg1yom1s
U6QGowmthDNAoYvbBOUfd0OYcycqBOysU8e3pM75mBwZgCYmejOo90Bk6qQ8 B/LhfnoNBMrj
PtC1GdwLh4GKV4gWsLJGmboDQXsluS6aC44KjeZC9FQ9uI6AFgcFseBNQdgD 3oFq0XbtRiY2
kUgJUso8hut2ZVZE5PX0ddEoqDWDLEqToAAt2ALkhFKBOCPQg3BRwQyeRRMl Cxrdgd4IkhtR
XBlMNRk4zInAK1xqYbUtk7xtRPN+2/WCMdPyzNAKhOoWSPXLk2nEVpCIviXw 4bBIvhb530RS
h5lcyF6cjbxySToisr4GahQqk7DMA6Q2jMCGPm+GNvMtx+RsN7lUO7hWpWMv ZyahAwbGtoAg
VMKzCn0KRwiZcG2+S2Aox4HldmWSTAafgS1ooV0XxO5UxctIW3Jc9EJFdWG2 KTIM1GYz2NBF
Sc0PiGCxja6X4GpVn5OhTG6cjiS/NSDkKqYGZNCBUh24MLzkrdnGsDH1SZBw h3TuqEkwfMAq
TwBvOSGQZ7Btugy3LeCatgLZQvTOCjImTNgUWatw9LYxiRzeZJDxhoWOUsEd MGBMbay7IU6n
4cHfBiIlU7cb+m1B5GK9ZpAhH0mgAq67C+ZBEJrXGYWiObMt+AfTXG3hlDL8 QC27XMULiCQi
SCQ9ShQCqqNB5A0Y+SUDho02qzRD3GENj0pX2lmrZYdEEAwYZt7cj6Fs7A6Q E44V3mPknPsI
RBClPEU68EKeVKTVr5Q0F0z/4KV5nmzKkUsDp54ex1G0WqHHEwl1PYRWAkrV LtijLo3AKgxE
sgLt9MirhJWTNwL/SFIQJzP5tmUerzb6YpzHxjZJ4Rd5EjhdtODFCHBfUBQu HQNozwMbLNYl
Muk5SDUJqmiHGKcIzbZUjYTuggEMTnRVWJ+GEOumQI0UY8Cp/A4yA1k9yPsQ 1gSG8VmHd1wP
NDEYyzY3kNgXbVvDZonmybQQ7ojAkmAlImcWw2zS42WgWCTvMrNBXdUx2a57 Pewyv8t5Y6xt
wIpVzrf1sjMSd4jcbvCoWpuMn+pjtgazfVJmCWBfVGiAw8iAfPRJ5NIqjkaR fOw7yNTQM+5q
6BpuHG/SdLvkzMsXMBWXfX4e+iz7U8YpGSkglSVFiAluzFzKTjZsynRpJSim zmPKbWR7LACh
AZsgrDnuGUPG6/MgdqriM6krYK+UxNNQUa0w00lEUuQ2UF8xKU9USQyZogXi xMS0al8nDj9R
pEJyQwX8yAkU14Ge815jmoiolTH5MB1/09zr6WI8W4gXFhGc0xclNKX8yavs GRbhkQ9hcG7n
4tFdqHH90hFb2GA91buMjKSIeq5Iq6VJuWtkD0apbLTgMJdtN9K+YOhp3aMi A5IwZ7yJA7L4
CuS9YnhoEguYcl6bZH63zA9Npl+XCdMo27yyVVldPruVKC3zvPdWSOZ79yl0 aeXc+WQpmfi9
x1Lp7uE0CbdQCT0ipWxfEhDo5ihlG56AEG6LUraZCRjhhijlNUrMM4CeB/7M PcwIpPlJcZ0I
bBXUH78IKlYi8iTkweY6HKAmEe3Q6aVIREB3pEdEpUGNiH/HWoQa4c1dH6yD CqCsdD2QZDbQ
XknmySGHNUCC88hsUDN++y029CpEttQ2nBZvZPywT17dwyCnkClvLHBjmRuQ HF+NP5LpqeWi
CtOLUnhV9ilmFzumDR2ooK7lg8FwMoFF/BWqRJTnIgMYGDIkrxvJUU4eAZVG oow8sV82jS+K
IZrUqWKVz0fbsc3RxNISYnxBMcDG5CCMMtdugN3QsJoWb2joYggP6Ktj3cRN RRWmekt4S8iD
UFWTLSJVz9MNNjJyo/rJ0wBqlCe77gnhgt46HAcrOM3YeTBiQc2IeosbQjwN nxy5HFiYkW2e
eH+lDfoK9tESuimpKbpiK1p+OvFQI4f1KAMeWtlS+1EimQhdB3aOZOei5Ul5 QIKuhVUJylS6
6Q42hop6nFLUhcWOya9C2yFaE/Ysj7JdtjFRG4EyIyGr63DsiuV34iC08iPE Od8CVmR9p91E
koiSwbYSJVCXsHYninULTxjwHVKBy7scd7rHjtM0PsP2XQ0p2eTYE2gXucFY 2G3AEJI3KN56
REvB9fX+yix3obTCkm+EJk23FW1TgCmAGaHFC/pqJX9aYW1ifjKqPNGWJECI 92rMElRNxo5L
e/ccn+sdRG3KolRnH0hcuQiQ4mBNNbkn/MaEPSLSSJ8yGo2kSh79wJQLlcIk 8l/YqWz6RWRa
ym05mIdKbCQVd0huUoO176f2pKk8bFnRA0yv+Woq50WIIsPzjF3T7e5GlY6y 8VFCTz90pOm8
mQyOiNlEOHQEo6lGpRAq9kkd8+cKRglGu2iIkkPZBEJqCyVnlKVUnTzPSUrS DO9NPA66z/l4
7JDNbgXQ5aK2QQhmPVEyCkpaTjdUT5N0pdJ5xCjpesQddindEapayfh9DCzo vSclIFlVUdYh
LNUVBIseAAnRg0IFYSmW4334rwyrkvscbCeNcRRzZAoHIXulbUgrIi6ATFTy TzxTA4WFhm5H
yhU0nl3ky4o/S/cAZauiZd8BniSScp3rfuSP72hRRXIloyBVDJAKUqiMHgNv brlBgP13KUmW
hVJ0xQGwHCErq8PASpSlkafL6IwaT/zA+RDKS9Gek1Fy00abkchBe0NtbtIV Gx0O5I6CFOnR
TRGQC4UIiqSazpwl0WBaXB69pHlKL/asMa/MTuE8bMShBmdQyVWwx6W8B7sJ deHyXqwgLKDv
Wcw6TXsMXf9hG5SpJ+xXbFPCxtlPy+mgBt5vuzvkIir3O3eBMlDkPzK6uof5 iupJhGLFvZyL
OMiqEl3N0EP9R/gqCl8LN0X8WgV+5bFePDpGKXMUgxbwlpYbxaJQdyMdLJGZ qanDieyATrQ7
TOfPshjyXNxJSuVdSh8j460DeOpoS5nc9w1vN0eLy7Xazy2fSQxlYkN2JqOE GpbefpIg2wHQ
axMg69CfPQDPtHnQoVbT2la8VqJahocTG4Dzj5X4Dj0h6Tv76nf+k+BDB3n+ E7yq1eT5TxOz
k5PTeP7T9PTk0flPh3EVnv8kH1SkKpZQYOcKQNLaWgRHqnwIJnNlEY3BVcsP +hwjtMZ3BKbL
K3d0jhDwf8zOOgdi7iEjMAaBW6WffQ8TwhCRi9H9vpAUzInPEZL2Q8MybLcl nEykeZIan1xx
fQ4NihdklB6mTRG9eeYgncI5Zwslqs7X9eQpJiUBeG07UbZEOdT5OdN0rgjG OqwAQxKlRSZ+
iVTcZNBDQSYOFyf4RuLep1KVZDEoga3GWbV5AFXQFm0AiEVgfj/vmdfddDsV q96peIaIBFeM
Lr+Ja0aunkW4zRDEceG+XBJnppb7EndPjTFheutoo+Iyra7QtkZva+B20Yyl fAJMj8IJoB1A
AgNm2FEGg8ipC3I0r7g6xCUshPhZWbRBxO2AtJZzI2RuV8Rjce2LQGzMC1i5 Niq27CcVMq0I
MpdU0qLCkfMKL2zN2ZXV1dH0i2h4oOuedctFzyZqji0HvTe5eJaW17aWL+Vj AjwwaaD+9sQi
LKXiS29NyzPquCETdGHmg+DgGXxqtHrgi1qVj02jkysyxVASCe3akMeYnAch 4nq7MN91l9Ln
waK4Seo7B9yYkpFDMcSS4a8hVrO4FYQjfpdhdntTTLJoIgp7AVsIK0rkkq0/ rDGZdJm7oR0M
dufN2H7Qzd3TzH7SS29ayaUTB8/5AEMNnVC4Ic7zXM9nuzwV/jiLOVAuJXMa PkxXzCf9URY6
tnWdsyvWLcNryGciK6Utg06WHqZquugHRDMLbGmQcnaUxdkR55th2EIwIz/h YMJ0Eih5iYMR
hvubJe0JQLQH8a1uC8ocEGC1BJx4Axyy6zp+Qo4hKUXaFpsXnpNTOr6ESyTJ x99ioi3d93KO
urkHD0gGXYRknp1mp+L3wtWWr+2ktYpCX1S6trfY2AO5A613FimjtrdfUM/3 TxXMG8SEDYBn
z5LpseKcAXulJRJ/c3hnxlbJ4aKlC25dsPvSaOZlAksm818/3yU35zaeWK2D hc6ThD55j+y/
PPs/O4x39yGIPvb/VG12PLb/J2bQ/h/H738c2f8Hf/W1/wsOA49dmHd3IrB2 tPTKhue2gCX6
F13HKjrZWC+xGRhBmN8GDXAdFiSxtiU8ccjmjcRRv/3K9qgj7udKnoekJ6jy kqRPGqbUWTx7
SMTRVE6u5CjiPagiHk6b9CqIyJar+pjjQshhjdqBwonn6gjhSC6mzz/NXrbw deQVK+KmgoeK
EdDYp2x2T15e1BYYGuLsMWMv3sYlqTlX9tjSUMBrIcKq6VuqD+L9pVRPZNYN KAKy6Ylc3dsD
iuT+dHbcNJxLHMi0nBsdV8JWQem+meyZdHtNAejRqNBJiur+zUvDZ9sZC9p9 amZL5mHnNy7e
7C2Bsi1KEP3+NSlJpPkt07gHyxTJtjO5yvapoUhyA3Pxgl4QU2VElukSrJMs KQODxRw8HSE8
a1zn2Q0z6bVpNBoXZXQ5q0mKyBpm9WdURA1EnvNcqhrVetWs3gSsRmmU1UbZ 1EhWuxyo6MQo
m9lT2UZ1V5adGmWTd1gUaq2Np8rezqq7YtYq6w9f29xa3Lq8mWvThLrCizvk 7G2ePIt2+ChW
+Ffk6qv/313oj67e+n9tYjr6/t8EAOD332YxJHik/x/CVT3xwNg+XsMnnmUr Zy4y2rzWEFvp
8Nn60jrbFPtkgQsBdeFJqPD8knQ3MPQv4IPy0ggU7u7SARgSldetMDAJ3wfv EYS+qyZwkZoc
Je53UYoYHbUjjSQNbaLFBHRMtNuxfNw/sc190E8RFSWj+/iNgwbm/ZrA5fxR ZnnolsFtwtu0
T5FOE8JskzrHLxpwEWFoRBv/ENPlymYl0fD1ZtMyeWV4f0cXhhfU+iKLbdAw q8jAFIFIv/IQ
/S38tMsdfPovozMM8N2YBCR6IQ3LKfpQTfIrMegi3ceIrfR/xhaZZITiDCkv SGyepQCuzHRs
YkKmIw8yVMcYaOFezR4zZJZXnmFGniAV1o1nJsdUS4Z5Y5MrbxiZbHL8IHmg tfrGhVLG05fl
a55MKJswGFRhleuVvpR38yHQ0zCDbEGdhKkK5niotYIqq3chUjOK/Nq1Gams FNqQIjot9foA
w8g5X8ERzzVduRhXoTlKWGJdKv2VOnpND4taMJqEiVqzn25hcg2DipYkp2jj E2jN+15XNDd3
bnv0cDnHH0/ETe54vrCN33UQx2xQxoXRxJRl+niKiitHH2kiFJp5Ei3SXIc1 bXE9KJ+6jPLQ
Ui3I9sxb5sX58UmEYGvlsQgzwpIkyAzbMGPWXACEHo+N5FAt067/BivrjOQA iXrvhKYLxJWY
795p2gQ7A8QV0mEBjNM5MaCSeC7IZoerw/Foj3vgRokremQPM/296PwqmStB NCvOkTHblt2I
juBRm9NwSwGdNoW/ZCSxJ3VnkzhYNotjbsAhLST3HYqlJsk9jq7eQfguFnd6 P7JB0D6hu6TA
SKVBpwN4ig00baOVXCMp8bhAAPHqwF0E6WV0f/4pzQMvJGpCei+A9Cke5GJK H85WF0cfiW8N
wYg2bDwagXaoyE3LRp2ObXPlwDfEeeodkb6tsBmSo17nu3QEG+jf8mggSqcY ZTwwKyOVtDJx
itVYB2ZEfUkkQgcaAmr3Ebg8qMmQ565Ej3dw5x+eztOomnGHovcKnwCRgXyR d15W3WhQS5Rx
MZK71OIvI19SNavdWYJ95PqfkW70/i7knMycoueK2myRt1EkDUvb5GQLYvgH HtBqzc0IT/Zl
+O5po2k5YKSpT1CJEYqP2ovIZUA6KZwCUU08B7nDPjZW0P3B5kO7IUek6Jsk f3kgT0RHNDq4
lzruuEnu8NDPnoTVDD3a6K02UtGeVNvqWIE4DgxP/rFdtytPLMQhxh2ros4M toZLH+SR59t0
XNrNjbsxxKzsWPHxWrR/yhUCyLA7rp89qs7kHjItPDKHPrYEJrPYSAs2U6V4 hJTVIJbRQoZE
fetW9vsb2k0hueKFxloZ67DI7oA/86wGfx94wMo/4jwtPfLFhdaDZgZKtRoJ hDpW9GmAOkjd
61mUtzNPqB9sTg7TKezK2FhP1Okmqe1V4zldyNa3p+nQixeun7wNa/qKPET5 FaVcAcH68gBe
LqUrJnPRiMvDNugcXlKM4k+HyM+Xm4Fns80uN/FUBRW1FTqUOHYrXYBw6wXo EW1D5D2kRypT
rKxUNWzBKDsrmqyn28ov7VAbE5/ZiTXVzMG/AFnxVdYZodNnWgQA8qZUNefJ q0ItBaURv8AQ
K5IjiJz2OC3J90kyylunCo/cCJ67aDPDElX+pHV1lKW6EDe3sKdCvPFAaloR YkFE9DbrrLnX
/tu7vXr4/9Mx8zuOAvTJ/5mcqc0o/39tfGZ2aFz8OfL/H8I10Pff98MJPEhi TMEu2NR2oh5l
V5bpwFAKdC42jO6AnztfOWvZXC+kJeUITy13TKMLLaFDTCgJh1Jz1FeNsY30 zURxjK4e9URU
4jDgwtScTIpK8TfBJUDk/hXOVC2Jh4lTVHYLnaI56Y2Swd7OaPWbXB7qI/fa +75rWkYiBGKp
E13SMg8Kifbock8NRbHEk2kzWp8UsqQkEC1aiN7tR4pNTzKkIzoyVDZI7msO cbICZNkkjthj
f+cpHH37lV4GA/UqXYjlIkr0COTo1vpD62wxDNyxFlIjkZI8QssPwvpBdH4l 3dkUFytItkm5
7vPK/dXr2uB5TbkpYWJ1JkD2vYG0VHumN4kV34oYQVEz971pW64LfLzbb/Qk 2B7HrzArRtR/
D7RJpf9VqFX4ybf9r6OP/jc+NT0l9b/a7CTlf0zWZqeO9L/DuOZP3+zYuNEK TydfKNUq4yVU
dFz0Vi2ULm+dHXtf6fSp4fmIPE4NH4tvOFh+u+y65TQWSmBBlOibgeJntRAQ rGQFqCmZDdyP
HTomnTF84dLytaX1ta3FlbXlS3tH1m2opER+I7Q83tiwwxYYwj0wuWHQDQOF rG45CDtfTXT8
Xs/VQVxq/ddDMJ4rYgdbAGraftbRb/1PRPlfav1PTdWOzn84lEuadBVQodEF MCxWAd3DEqgO
wz8VyzHtsEGnMHVpGVWAZ4w+lfYcXlzeWhxbWTtbzb6qZB9ZsHL96nfkmnor XWr9i+k4mDpA
wo/Pzk4Xrv/xzPqfmJwA+T99MM3Rr7f5+tfn3zcw+FFpWc39rKMP/6/NTsym +f8kkMQR/z+E
69zK2fd9v/GeofcM/Z+hoeVTi19+5T//5bfe/P2P/+V/+Dd/8Odff/Pzz3/1 dz7z+je+9sb5
Bx/5j7/z1esP/ezukx//udtf/tSPfukzH//8hzu/+is/+fVbzRd/6af/3S37 o4/N/vjylBk8
8fGN0521M+ZnP/qVa+d+9Bde/ML3vuvCI6e3L51r37r+4iPnzc//4u99/Wt/ 8vi555+48I8f
u7D7W698+zd+9Q+vrn74uc4v/+LP//qnX35leeLZh+d3zp/0Nh96znjkxx+7 eOtf/8vffmzl
I0+tfvTJtR9+7sbnzsw9/tX/8j8uLDz76PkPP7H6Y6+9+s3zJz/4yNJHrfqH fecjT6z9xA9s
/uxTGz91bfOlxzdeeGrrA9veRz7x0q/8+y///tdff8N8/F985fdefe1rf7xx /iPGYy9fffRj
l9d+qnH1c+ZTv1R/8heefuLl1tOfbvzAv3r00ovm05+yWp/95Kf+/NVX//TV V79x5fHPuTd+
7dzqy+7Nr/rP/tcnrn3yRviZmz/8p7d+5Js7/+SN8Ie+Ef7Q68EP/nf/9h/t PP/aiy+/8c8/
9rsrlz62+8K3dj74Z8986H/feuF/7XzgT3Y+8D9vPPuVF37iL37wQ3/o3Pzi Cz/97Y99+tu1
hWev1F967fU/fvPNN+81Pbytr/v/4q+/Y2jouaFRvME1MXTfLw+949j3nH/l E194/r5nVp97
5RNffOe7j7/7dfY0++I//d5TT5zf2Hjl4aEH3/mlf/vbpdc+9O733Hffre/e +M1/9nfLSx94
o/vN5z7xwjue/r/257/4yfv+9j8YL//N33i+tf493+9/46Xa5m+t/cz87t94 /3/7rtff9ZMj
W5997EP1r31pY/bZ331h5eebf+tnajvf+rXdye5vvuPv/P32fzpvLJ29b2j0 vv+3eKP0wXd+
1z9cffb8c42VL7y3/PfG/+y5+//aj7EL7771+B89/evvYisvsT/48q7/4NDQ 3MBdVvw/Vuz2
f1j78P+J2qzi/5MTM5MTaP9PTEwf8f/DuAa1/09LyzoGnaxM0BtBOaeEB26e ghYIoOn7Xddy
At1Cly44Pz57pXQqKjOP6fXZdAu09+W2dDpBzGgYDp4gloEkoz0Gzj9yIVuM dnQulACSIahM
4s/CRZ2EOqANJ6fHR5nR7dJfi/7mlBFR5YUSZihnX5/KPJm/f2wsOwQmDr1Q 1vDs0tpMlUbi
GjTjGo4F6m5Z7IFR38BQvJjj7HvM7ThPUzQBfajN5LQfTwLdNN0uDKAp8OR3 xDQcMWzLDuZg
AxlteC6d6l5UYmwsMfFVnHlxP1+NxvnU3RCX8K2qo3Q1MtuWD3uSWv4JCHsi ul7Fko1c0lEU
hOr6E24R3MFSmT6RamxzJnO+qpjGvWZ/b/tLyf/IeXMAddyJ/Y/nvxzZ/wd/ Zeb/4uLaytnl
za3KxbP7VUff+M/kVLz/tzaN+t/szJH/91Cui4ZjNbkfjD0q9LqTDFTA4TMh pmyPqZfRuwn1
BqXMSSaJh2FwZcxy1MvN3U7dtS1TA5qTW1cCwLOAioCCTlYcV70ozoV3vZPR SUTRo+FLIqgz
JmBPaqHd0BodLjzKJ/VKiN5huWdzbNW4tbuJ6e0naRvZ20I4RfEfyzkg7+9e +D+uf+T/tdmp
I//voVzJ+Vf5n/tdx+DzPzkxOz2F/H9q6kj+H11H19F1dB1dR9fRdXQdXUfX vl//HxMLeTIA
yAAA
--------------000401080201040303070806--
Re: TableViewer isn't drawing its contents. [message #326547 is a reply to message #326359] Mon, 24 March 2008 18:36 Go to previous message
Anyone have any hints for things to try here?
It seems very strange that the widgets are getting set up
but they aren't drawing anything.
Gary
Previous Topic:Reuse icons
Next Topic:addPropertyChangeListener(IPropertyChangeListener) not working
Current Time: Fri Sep 19 01:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.04941 seconds
