Home » Eclipse Projects » Eclipse Platform » Problems completing the web service client wizard
Problems completing the web service client wizard [message #326319] Fri, 14 March 2008 14:20 Go to next message
Originally posted by: slatteryd002.hawaii.rr.com
I'm having problems using the web service client wizard. Sometimes it
works, but when it doesn't, it is a problem on the final dialog.
On the first dialog, I copy/paste the wsdl url for the service definition
from a browser window.
Client type: Java Proxy (default)
Configuration:
Server: Tomcat v5.5 Server
Web service runtime: Apache Axis2
Client project: <my eclipse dynamic web project>
Monitor the Web service: unchecked (default)
Overwrite files without warning: checked (default)
When I click Next to go to the Axis2 Client Web Service Configuration
dialog, when it works, the combo boxes are filled in. ATM, they're all
blank except the Databinding Name, which defaults to ADB. Once, I was
able to get it to work by trying different values for the Web service
runtime selection on the previous dialog. It's not working this time
though.
Any ideas?
Aloha,
Doug
-- Nothing is impossible if I'mPossible
Re: Problems completing the web service client wizard [message #326340 is a reply to message #326319] Sat, 15 March 2008 14:47 Go to previous message
Problem solved...
There was an attribute name conflict between one of the selections on the
wizard that didn't match the corresponding value in the wsdl url.
Aloha,
Doug
Previous Topic:refreshLocal synchronous?
Next Topic:Rename project programmatically
Current Time: Wed Jul 16 23:52:28 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
