Home » Eclipse Projects » Eclipse Platform » EFS question ...
EFS question ... [message #326232] Wed, 12 March 2008 10:06 Go to next message
Hi all, hope this is the right forum to ask questions about EFS .
I'm trying to build an example that with the EFS helps will make me build a
view with a representation of what is contained in my DB .
I did actually manage to do it but there is something that I don't not
really like .
When I start my test it starts to ask information about the whole tree - the
problem is that this operation can take a long time if the DB contains more
than a 1000 object ..
Is there a way to (for example) just read the information about the first
"folder" and only once it get expanded read it . I do understand that
eclipse must probably cache information about name and structure . but this
really make totally not usable .
Kar
Re: EFS question ... [message #326236 is a reply to message #326232] Wed, 12 March 2008 10:31 Go to previous messageGo to next message
Kar,
I'm not sure this is entirely avoidable. Eclipse does need to know the
time stamp for each resource the first time so that it can properly do a
refresh should the contents of the tree change outside the control of
the IResource APIs. What specifically is driving the full walk. Is it
indeed this need for an initial sync? I assume it's not actually
loading files but just needs to understand the full folder structure.
If that indeed is taking an unusably long time, you probably need to
rethink your design where the user needs to take explicit actions to
bring folders into view...
> really like .
> Thanks
> Kar
Re: EFS question ... [message #326239 is a reply to message #326236] Wed, 12 March 2008 12:18 Go to previous messageGo to next message
Hi Ed and thanks ...
in the meantime I did actually create a simple treeview with a basic with
viewer.setLabelProvider(new WorkbenchLabelProvider());
viewer.setContentProvider(new BaseWorkbenchContentProvider());
so I get back my tree for free (no icon no anything but it's a starting
point) and items are only loaded when I do expand the folder.
The trouble is ... what shall I do to be able to open an editor on the item
this was free when a linked the "dbfilesystem" to the resource view ...
What shall I do now?
I have tried using what follows
IEditorDescriptor desc2 =
PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or(fileStore.getName());
try
page.openEditor(new FileStoreEditorInput(fileStore), desc2.getId());
catch (PartInitException e)
// TODO Auto-generated catch block
e.printStackTrace();
but I don't get anything ...
can u point me in the right direction or what is the class of the navigator
view so I could probably check what does it do (bear in mind that I know
very little of EFS and I haven't done any cache of the db file locally, but
just implemented the get input/output stream on the filestore)
thanks
Kar
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fr8pgc$464$1@build.eclipse.org...
> Kar,
> refresh should the contents of the tree change outside the control of the
> IResource APIs. What specifically is driving the full walk. Is it indeed
> this need for an initial sync? I assume it's not actually loading files
> but just needs to understand the full folder structure. If that indeed is
> taking an unusably long time, you probably need to rethink your design
> where the user needs to take explicit actions to bring folders into
> view...
>> a view with a representation of what is contained in my DB .
>> really like .
>> the problem is that this operation can take a long time if the DB
>> contains more than a 1000 object ..
>> this really make totally not usable .
>> Thanks
>> Kar
Re: EFS question ... [message #326240 is a reply to message #326239] Wed, 12 March 2008 12:37 Go to previous messageGo to next message
--------------040202050005050507070208
Kar,
This looks like the right way. How are you creating the file store
instance that you pass to the editor?
> try
> thanks
> Kar
>> Kar,
>> view...
>>> really like .
>>> Thanks
>>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
This looks like the right way.&nbsp; How are you creating the file store
instance that you pass to the editor?<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:fr8vp8$9na$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed and thanks ...
try
thanks
Kar
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fr8pgc$464$1@build.eclipse.org">news:fr8pgc$464$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kar,
view...
KarSc wrote:
</pre>
<pre wrap="">Hi all, hope this is the right forum to ask questions about EFS .
really like .
Kar
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040202050005050507070208--
Re: EFS question ... [message #326257 is a reply to message #326240] Thu, 13 March 2008 05:42 Go to previous messageGo to next message
viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
and on the double click on the tree item i'm just opening the editor with
IDE.openEditorOnFileStore(page, fileStore);
i did actually discovered that the problem is different ...
i cannot open only xml file ... follows the exception ....
thanks
kar
org.eclipse.ui.PartInitException: Editor could not be initialized.
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3028)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2617)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:186)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:160)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:378)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:554)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at testefs.views.SampleView$4$1.run(SampleView.java:399)
news:fr90rj$ihq$1@build.eclipse.org...
Kar,
This looks like the right way. How are you creating the file store instance
try
thanks
Kar
Kar,
view...
really like .
Kar
Re: EFS question ... [message #326260 is a reply to message #326257] Thu, 13 March 2008 06:02 Go to previous messageGo to next message
The weird thing is that ... if I do open the file from the mounted EFS (from
resource view) - it works fine ...
or at least I can able to open the file using the xml editor (but when I
save it the document goes in out of sync ... but it has been saved correctly
.... just pressing F5 I get the editor back ...)
this whole thing is driving me crazy ...
hope u can help me
Kar
"KarSc" <carmeloscala@hotmail.com> wrote in message
news:fraste$44k$1@build.eclipse.org...
> thanks
> kar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Kar,
> item
> try
> navigator
> but
> thanks
> Kar
> Kar,
> view...
> really like .
> Thanks
> Kar
Re: EFS question ... [message #326263 is a reply to message #326257] Thu, 13 March 2008 07:03 Go to previous messageGo to next message
checking the ResourceNavigotor I can see that it will actually work on a
IFile ...
still what shall I do to obtain an IFile from a filestore :-S
Kar
> thanks
> kar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Kar,
> item
> try
> navigator
> but
> thanks
> Kar
> Kar,
> view...
> really like .
> Thanks
> Kar
Re: EFS question ... [message #326269 is a reply to message #326257] Thu, 13 March 2008 08:55 Go to previous messageGo to next message
Kar,
Not all editors support the different input types. :-( Use the
debugger to see what the structured text editor is doing with its input.
> thanks
> kar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Kar,
> try
> thanks
> Kar
> Kar,
> view...
> really like .
> Thanks
> Kar
Re: EFS question ... [message #326271 is a reply to message #326260] Thu, 13 March 2008 08:56 Go to previous messageGo to next message
--------------060104060402080606050700
Kar,
In that case it's using an IFile and for sure the editor supports that.
> hope u can help me
> Thanks
> Kar
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
In that case it's using an IFile and for sure the editor supports that.<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frau4f$m4n$1@build.eclipse.org" type="cite">
<pre wrap="">The weird thing is that ... if I do open the file from the mounted EFS (from
hope u can help me
Kar
"KarSc" <a class="moz-txt-link-rfc2396E" href="mailto:carmeloscala@hotmail.com">&lt;carmeloscala@hotmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fraste$44k$1@build.eclipse.org">news:fraste$44k$1@build.eclipse.org</a>...
</pre>
<pre wrap="">viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
thanks
kar
<a class="moz-txt-link-freetext" href="news:fr90rj$ihq$1@build.eclipse.org">news:fr90rj$ihq$1@build.eclipse.org</a>...
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060104060402080606050700--
Re: EFS question ... [message #326272 is a reply to message #326263] Thu, 13 March 2008 08:58 Go to previous messageGo to next message
--------------080101090106060009070802
Kar,
It kind of circles back to your original problem. To make it an IFile,
you need to use EFS as the backing for a view on your database. Maybe
ask the WTP newsgroup about support for different types of input (if
debugging the stack trace doesn't make that clear by inspection).
> IFile ...
> Kar
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
It kind of circles back to your original problem.&nbsp; To make it an IFile,
you need to use EFS as the backing for a view on your database.&nbsp; Maybe
debugging the stack trace doesn't make that clear by inspection).<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frb1l9$a1u$1@build.eclipse.org" type="cite">
<pre wrap="">checking the ResourceNavigotor I can see that it will actually work on a
IFile ...
Kar
</pre>
thanks
kar
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------080101090106060009070802--
Re: EFS question ... [message #326276 is a reply to message #326269] Thu, 13 March 2008 10:17 Go to previous message
Hi Ed and really thanks for all ur help ...
I guess at this point is better for me to stop ... at least since I will
fully understand what I can do to actually get an IFile from an EFS object
I could try to dig and solve the problem for a structure text editor but I'm
sure that the trouble will rise again once someone will use a different
plug-in inside the RCP application for editing any other kind of file .
I did have a look at the Workspace / Workspace root and a bunch of other
classes inside the Resources Plugin but it's a really mess ...
Still thanks for ur help
Ciao
Kar
news:frb880$q1t$1@build.eclipse.org...
> Kar,
> Not all editors support the different input types. :-( Use the debugger
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> indeed
>> is
>> view...
>> really like .
>> Thanks
>> Kar
Previous Topic:multi-width images in Tree
Next Topic:Problem with plugin dependencies
Current Time: Sat Nov 08 13:00:06 EST 2025
Powered by FUDForum. Page generated in 0.05594 seconds
