Home » Eclipse Projects » Eclipse Platform » How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy?
How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326184] Mon, 10 March 2008 13:08 Go to next message
I know how to make my own annotation types, just need to correctly have
my editor, which inherits TextEditor, to use my own
AnnotationPainter.IDrawingStrategy. Tips and/or example(s) would be
appreciated. Thanks.
Re: How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326190 is a reply to message #326184] Mon, 10 March 2008 20:47 Go to previous messageGo to next message
AL wrote:
To clarify that my annotations implement
org.eclipse.jface.text.source.IAnnotationPresentation, because the
annotation types are dynamically created. Thus, I cannot use extension
points.
Re: How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326264 is a reply to message #326190] Thu, 13 March 2008 07:05 Go to previous messageGo to next message
AL wrote:
> AL wrote:
>> have my editor, which inherits TextEditor, to use my own
> extension points.
See:
org.eclipse.jface.text.source.AnnotationPainter.addDrawingSt rategy(Object,
IDrawingStrategy) and if you are using 3.4:
org.eclipse.jface.text.source.AnnotationPainter.addTextStyle Strategy(Object,
ITextStyleStrategy).
Please note that IAnnotationPresentation is only designed for drawing
onto the vertical ruler and not into the text area (which is handled by
the AnnotationPainter).
Dani
Re: How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326323 is a reply to message #326264] Fri, 14 March 2008 14:36 Go to previous messageGo to next message
Daniel Megert wrote:
> AL wrote:
>> AL wrote:
>>> Hi,
>> extension points.
> See:
The problem is that I can't get to the AnnotationPainter object from
SourceViewerDecorationSupport, since the annotation painter is declared
private and is created by a private method in
SourceViewerDecorationSupport, which does not have an accessor to get
the AnnotationPainter.
Any tips on how to go about this, without making all sorts of
inheritance and overrides? Thx.
> Dani
Re: How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326331 is a reply to message #326323] Sat, 15 March 2008 04:54 Go to previous messageGo to next message
>> AL wrote:
>>> AL wrote:
>>>> Hi,
>>> extension points.
>> See:
> declared private and is created by a private method in
This is just not true. It is created in the protected non-final
createAnnotationPainter() method which you can implement in your own
subclass. You can even first call super to get the default annotation
painter.
Dani
> which does not have an accessor to get the AnnotationPainter.
>> by the AnnotationPainter).
>> Dani
Re: How to have AnnotationPainter use my AnnotationPainter.IDrawingStrategy? [message #326366 is a reply to message #326331] Mon, 17 March 2008 19:05 Go to previous message
> painter.
> Dani
Looked at the wrong places :-)
Previous Topic:Project Explorer not sorted on a refresh
Next Topic:SVN doesn't notice when file changes in my plugin
Current Time: Sat Nov 08 08:00:52 EST 2025
Powered by FUDForum. Page generated in 0.03507 seconds
