Home » Eclipse Projects » Eclipse Platform » Dynamically open a view and an editor
Dynamically open a view and an editor [message #326180] Mon, 10 March 2008 10:57 Go to next message
Originally posted by: naddeo.marco.educ.di.unito.it
I need to open, dynamically from my Java code, a view that I have defined
in my plug-in. Could someone please show me the way or API that I can call
to accomplish that?
Besides, I need to open, also dynamically from my Java code, a Java file
(a compilation unit) in the editor, precisely in the point of a certain
method (I use in my plug-in the ASTParser and then I have the pointer to
the ASTNode, of MethodDeclaration type, corresponding to the method on
which I want to open the editor). Could you help me?
MN
Re: Dynamically open a view and an editor [message #326183 is a reply to message #326180] Mon, 10 March 2008 12:45 Go to previous message
For showing the view, there's org.eclipse.ui.IWorkbenchPage.showView(String)
For showing an normal editor, there's
org.eclipse.ui.IWorkbenchPage.openEditor(IEditorInput, String) or many
openEditor(*) methods on org.eclipse.ui.ide.IDE You can use openEditor
with an IFile to open the editor, but then you would have to use some
API on that editor to set the cursor to the correct position.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Outline View
Next Topic:StructuredTextEditor hide some contents
Current Time: Fri Sep 12 15:25:14 EDT 2025
Powered by FUDForum. Page generated in 0.04700 seconds
