Home » Eclipse Projects » Eclipse Platform » Invisible Text?
Invisible Text? [message #326130] Fri, 07 March 2008 11:25 Go to next message
Originally posted by: frickson.gibbon.com
I originally posted this in e.t.ve, but was redirected here. They
don't seem to think this is a VE problem.
I just installed eclipse 3.2 (eclipse-platform-3.2-linux-gtk.tar.gz)
on two servers. On one (OpenSUSE 10.2), everything seems to be working
fine. On the other one (SUSE Linux Enterprise Server 10.1), most of
the text is invisible in the editor. After some experimenting, I
discovered that any text following a tab character is invisible.
If I use spaces instead of tabs, it works fine.
I tried changing fonts, sizes, colors, tab size, but nothing helps.
The sample text in "Preferences / C/C++ / Editor / Syntax" is also
mostly invisible.
Any ideas?
Re: Invisible Text? [message #326135 is a reply to message #326130] Fri, 07 March 2008 12:27 Go to previous messageGo to next message
> mostly invisible.
> Any ideas?
This issue just came up last week with another user on the JDT
newsgroup. I don't think he has yet figured out the cause, but you can
follow the discussion here:
http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg2 2255.html
I believe he was going to enter bug report about it, so you should find
it and attach yourself.
Hope this helps,
Eric
Re: Invisible Text? [message #326152 is a reply to message #326135] Sat, 08 March 2008 16:09 Go to previous messageGo to next message
Brian's bug is here.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221363
You should probably take a look at 218575.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=218575
Re: Invisible Text? [message #326326 is a reply to message #326152] Fri, 14 March 2008 16:14 Go to previous message
Originally posted by: wharley.bea.com
"Remy Chi Jian Suen" <remy.suen@gmail.com> wrote in message
news:fquvav$89e$1@build.eclipse.org...
For any tracking this thread: I see from a post in eclipse.tools.jdt that
Brian's bug has been identified and a fix is available.
Previous Topic:Editor - Document Provider error
Next Topic:Callisto Discovery Site -- Enabling Features?
Current Time: Thu Jul 17 15:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
