Home » Eclipse Projects » Eclipse Platform » StructuredTextEditor and code completion
StructuredTextEditor and code completion [message #326088] Fri, 07 March 2008 04:37 Go to next message
Originally posted by: alexjaquet.gmail.com
I need to add the code completion feature within a StructuredTextEditor
is there any documentation I can read or does anyone have already do
this work ?
Thanks for your advice.
Alexandre
Re: StructuredTextEditor and code completion [message #326095 is a reply to message #326088] Fri, 07 March 2008 05:02 Go to previous messageGo to next message
I see an article about de code completion here
http://wiki.eclipse.org/FAQ_How_do_I_add_Content_Assist_to_m y_editor%3F
And found some code there
http://www.google.com/codesearch?hl=en&q=show:7vc44WIFVK E:bhXBMftasZk:yC8Jo0ZNTP4&sa=N&ct=rd&cs_p=http:/ /devresource.hp.com/drc/technical_white_papers/eclipeditor/M yEditor3.zip&cs_f=MyEditor3/src/MyEditor/editors/MySourc eViewerConfig.java&start=1
Is it possible to use a dtd / xsd for the tag we want to add the
completion ?
Alexandre
Re: StructuredTextEditor and code completion [message #326101 is a reply to message #326095] Fri, 07 March 2008 05:20 Go to previous messageGo to next message
Alexandre,
I think WTP's XML editor uses the XSD model for XML completion.
> completion ?
> Alexandre
Re: StructuredTextEditor and code completion [message #326111 is a reply to message #326101] Fri, 07 March 2008 08:05 Go to previous message
Thanks Ed for your response, did you know how can I import a xsd to
let's know the structured text editor content assist what can be
proposed to the user ?
I m searching for resource but didn't find anything for the structured
text editor :(
Alexandre
Previous Topic:Customizing cheat sheets
Next Topic:How to overwrite text in about dialogs
Current Time: Fri Oct 24 17:32:53 EDT 2025
Powered by FUDForum. Page generated in 0.04022 seconds
