Home » Eclipse Projects » Eclipse Platform » [DataBinding]
[DataBinding] [message #325986] Wed, 05 March 2008 03:28 Go to next message
Originally posted by: housh_housh.yahoo.com
what is the scope of an DataBindingContext when I use it in an RCP app?
Can I put all my Bindings in one place or is there a BindingContext for
every Plugin?
thx,
ex
Re: [DataBinding] DataBindingContext scope [message #326019 is a reply to message #325986] Wed, 05 March 2008 17:31 Go to previous message
Typically a DataBindingContext has the same scope as the editor or view
it is used for. In the case of wizards, you could use one DBC for the
whole wizard or one for each individual page.
> every Plugin?
You could do either of these--DataBinding or RCP do not force you one
way or another. However I think you are approaching the problem from
the wrong perspective: you want to consolidate your domain objects (the
model), not bindings. At each point where the UI needs to hook into
your model, create a DBC and create your bindings. When that UI element
is closed, the DBC should be disposed.
Hope this helps,
Matthew
Previous Topic:get the standard context menu on custom objects
Next Topic:IProcess listener?
Current Time: Wed Oct 22 18:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
