Home » Eclipse Projects » Eclipse Platform » Should copy be enabled for linked resources?
Should copy be enabled for linked resources? [message #325968] Tue, 04 March 2008 08:47
I am working on a plugin where I have created a remote file system. When
I add linked resources to this file system into a project, the copy option
is disabled in the Project Explorer. This is good for me, however, you
are still able to copy any folders that contain these linked resources.
This causes a problem because if you then try to paste this folder
somewhere, you get an error message saying: "Copy Problems: While
executing the operation, an exception occurred."
Just to be sure this is not an issue with the way I was implementing my
file system, I installed the Remote System Explorer/Target Management
(RSE) plugin and verified the behavior for this plugin is the same.
So I'm not sure what the correct behavior should be here, and suspect a
bug in eclipse. Should the Project Explorer view prevent the user from
copying folders containing remotely-linked resources? Is this exception
while trying to copy them a bug, or could I be missing something in my
implementation of my file system?
David
Previous Topic:Feture Details Table
Next Topic:[Fwd: Re: [ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.j
Current Time: Thu Jul 24 01:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.02881 seconds
