Home » Eclipse Projects » Eclipse Platform » Executable extension definition for <corresponding class> not found
Executable extension definition for <corresponding class> not found [message #325940] Mon, 03 March 2008 13:33 Go to next message
I've created a sample extension point in one plug-in (say plug-in p1), which
allows the plug-in that it extends to provide a name of a class. The schema
definition of the extension (*.exsd) is attached to this as "test.exsd" for
your reference. Then I created a second plug-in (say plug-in p2) and
extended the above extension point by providing the name of a newly created
class.
After both plug-ins are installed, I executed the following code in the
first plug-in (p1)
IExtensionRegistry extensionRegistry = Platform.getExtensionRegistry();
IExtensionPoint extensionPoint =
extensionRegistry.getExtensionPoint("p1.test");
IExtension[]extensions = extensionPoint.getExtensions();
for(int i = 0; i < extensions.length; i++) {
extensions[i].getContributor().getName();
IConfigurationElement[] configurationElements =
extensions[i].getConfigurationElements();
for(int j = 0; j < configurationElements.length; j++){
try {
configurationElements[j].createExecutableExtension(configura tionElements[j].getAttribute( "att"));
catch (Exception e){
e.printStackTrace();
}// end try-catch block
}// end for loop
}// end for loop
I get the following exception even though class p2.Element11 in deed exists
in the second plug-in (p2) which extended the above extension point.
org.eclipse.core.runtime.CoreException: Executable extension definition for
"p2.Element11" not found.
org.eclipse.core.internal.registry.ConfigurationElement.thro wException(ConfigurationElement.java:62)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:222)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
Then I replaced the following in the above code snippet
configurationElements[j].getAttribute("att"));
with the following (deprecated approach)
extensions[i].getDeclaringPluginDescriptor().getPluginClassL oader().loadClass(configurationElements[j].getAttribute( "att")).newInstance();
Amazingly, the same class "p2.Element11" was loaded successfully by the
second approach.
I would appreciate it very much if somebody could tell me why the first
(new) approach, which is given below, is failing to load the corresponding
class while the second (old) approach is not.
Thanks in advance!
Sudarsha Wijenayake
IBM Rational Software
  • Attachment: test.exsd
    (Size: 2.73KB, Downloaded 211 times)
Re: Executable extension definition for <corresponding class> not found [message #325942 is a reply to message #325940] Mon, 03 March 2008 14:32 Go to previous message
It should be configurationElements[j].createExecutableExtension("att")
.... the attribute name to use, not the value.
createExecutableExtension(*) will instantiate a class contained in the
"att" attribute or the child "att" element, depending on which form is
provided.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Classes missing from plugin dependancy
Next Topic:How to define a new vmarg (-vmargs) in Eclipse?
Current Time: Mon Jul 07 02:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.23687 seconds
