Home » Eclipse Projects » Eclipse Platform » [DataBinding] DOM & XAML binding and bugs correction
[DataBinding] DOM & XAML binding and bugs correction [message #325928] Mon, 03 March 2008 09:13 Go to next message
I have starting to refactor TK-UI (see at http://tk-ui.sourceforge.net/)
API to manage binding between DOM (element, attribute...) and UI (Swing,
SWT) with JFace Databinding.
Just for information, TK-UI is API where you can describe your UI with XML
(XUL, XHTML, XForms...).
1. DOM & XAML binding
Today I can manage XHTML grammar where HTML element are bounded with UI
SWT or Swing with JFace Databinding (ex : <input type="text" value="bla
bla bla"> is rendered with SWT Text and SWT TextObservableValue is bounded
with AttrObservableValue (IObservableValue wich observe value of DOM
Attribute).
I have started too to manage binding with attribute expression like XAML :
Today I can manage this XHTML content :
<input id="MyTextBox" type="text" value="bla bla bla />
<input type="text" value="{Binding ElementName=MyTextBox, Path=value}" />
So the second input text is bounded with value attribute of the first
input.
Another sample is
<input type="checkbox" id="checkViewTextBox" checked="true" />
<input type="text" visible="{Binding ElementName=checkViewTextBox,
Path=checked}" />
When checkbox is checked, the input text is visible and false otherwise.
2. SWT JFace Databinding bugs/new features
I would like to say I have correct some bugs into SWT JFace Databinding
(see at
http://uface.googlecode.com/svn/trunk/org.ufacekit.ui.jface. databinding/)
ButtonObservableText => observe text of SWT Button.
ButtonObservableValue=> correction bug to initialise selectionValue filed into
ButtonObservableValue constructor.
ComboEditableObservableValue=> observe editable value of Combo (only
doGetValue works)
SliderObservableValue => observe slider value. See
org.ufacekit.ui.jface.databinding.example.properties.backgro und.BindBetweenSliderAndTextBackground
sample. There are 3 sliders (R, G, B) which manage background property of
SWT Text.
3. Bind events
I have created bind events project at
http://uface.googlecode.com/svn/trunk/org.ufacekit.ui.databi nding.events/
which extends DatabindingContext to manage binding between two kind of
event.
For instance with that, I can bind SWT event with DOM event. So I can bind
SWT MouseEvent with DOM MouseEvent. If you are interested by this toipc, I
could tell you more.
Regards Angelo
Re: [DataBinding] DOM & XAML binding and bugs correction [message #325932 is a reply to message #325928] Mon, 03 March 2008 09:54 Go to previous messageGo to next message
> (see at
> http://uface.googlecode.com/svn/trunk/org.ufacekit.ui.jface. databinding/) :
> filed into ButtonObservableValue constructor.
> doGetValue works)
> of SWT Text.
IMHO you should contribute those bugs/features back upstream (create
bugzillas for each of them).
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [DataBinding] DOM & XAML binding and bugs correction [message #325951 is a reply to message #325932] Tue, 04 March 2008 02:28 Go to previous messageGo to next message
Hi Tom,
Ok I will do that as soon as I have time.
Are you interested by my work about DOM and UI Databinding?
Regards Angelo
Re: [DataBinding] DOM & XAML binding and bugs correction [message #325952 is a reply to message #325951] Tue, 04 March 2008 02:48 Go to previous messageGo to next message
Hi Angelo,
Just to clarify what I meant. You should only contribute the SWT
bugfixes to upstream Eclipse-Projects.
Tom
Angelo schrieb:
> Hi Tom,
> Regards Angelo
Re: [DataBinding] DOM & XAML binding and bugs correction [message #325953 is a reply to message #325952] Tue, 04 March 2008 03:01 Go to previous messageGo to next message
Ok, I will do that.
Re: [DataBinding] DOM & XAML binding and bugs correction [message #326032 is a reply to message #325952] Wed, 05 March 2008 23:57 Go to previous messageGo to next message
What about bug fixes to the data binding plug-ins?
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fqius7$rsj$1@build.eclipse.org...
> Hi Angelo,
> Just to clarify what I meant. You should only contribute the SWT bugfixes
> Tom
> Angelo schrieb:
>> Hi Tom,
>> Regards Angelo
Re: [DataBinding] DOM & XAML binding and bugs correction [message #326042 is a reply to message #326032] Thu, 06 March 2008 03:53 Go to previous message
I meant those ;-) The bugfixes for SWT-Observables!
Tom
>> Hi Angelo,
>> Tom
>> Angelo schrieb:
>>> Hi Tom,
>>> Regards Angelo
Previous Topic:Shared instance of refresh icon?
Next Topic:Deleting all lines starting with // in all the java files of a java project
Current Time: Fri Nov 07 11:16:35 EST 2025
Powered by FUDForum. Page generated in 0.05415 seconds
